Hi Andrew,
On Fri, Nov 4, 2016 at 4:28 PM, Johnson, Andrew N. <[email protected]> wrote: On Nov 4, 2016, at 8:20 AM, Ralph Lange <[email protected]> wrote: Yes, why not. It's true that the templates will be used primarily for applications (i.e. local things) and the .local mechanism is more targeted to modules that are in a public repository and shared between developers with different environments and setups. (The setup will most likely be the same at one installation.) But to show people a suggestion of how to do that, improve uniformity, since configuring a bunch of modules using one file might be useful even for a local application, and since it doesn't do any harm when the .local files don't exist, sure. Should I include a .gitignore (and .hgignore, .cvsignore etc.) files in the templates as well while I'm at it? No. Choosing a VCS and configuring it should be left to the user. Each installation typically has a common ignore file for all modules, and the *.local pattern should be added there. Thanks for that suggestion! ~Ralph
| ANJ, 06 Nov 2016 |
Home
News
About
Talk
Base
Modules
Extensions
