Hi Andrew,
On Mon, Jan 16, 2017 at 6:53 PM, Andrew Johnson <[email protected]> wrote: On 01/15/2017 12:01 PM, Ralph Lange wrote: Well, "man bind" suggests that the call to bind() may return five different error codes. I don't know if completely removing the restriction is maybe opening things up a bit too wide. I would opt for adding EACCESS to the clause as the more conservative approach. This code is run as part of opening a new connection; thus it is not really performance relevant. Cheers, ~Ralph
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
