2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: const-constraints on struct rset method arguments
To: <[email protected]>
Date: Mon, 6 Mar 2017 13:17:03 -0600
Hello Ben,
I won't comment on the wider topic of your proposed changes, but with regard to the motor record specifically, I agree with the changes I see in your motor module fork; https://github.com/bfrk/motor.
I suggest that these changes be added to motorRecord.cc
537c537
< static long init_record(dbCommon* arg, int pass)
> static long init_record(motorRecord *pmr, int pass)
539d538
<     motorRecord *pmr = (motorRecord *) arg;
1188c1187
< static long process(dbCommon *arg)
> static long process(motorRecord *pmr)
1190d1188
since this workaround is no longer needed, and without the above changes, init_record() and process() become unresolved external references.
I have successfully built your motor module fork against your EPICSbase 3.16 branch (after making the above changes to motorRecord.cc). I plan on running an IOC and actually driving a motor. I'll let you know my results when available.
The most controversial issue is that the use of the conditional compilation macro EPICS_VERSION_INT will make this version of the motor record incompatible with EPICSbase versions < 3.15. It should not be too difficult to change conditional compilation macro usage so that EPICSbase 3.14, 3.15 and 3.16 are supported.
Ron
Prev: Jenkins build is still unstable: epics-base-3.14-win32s #181 APS Jenkins
Next: Re: Concerns about link-support-2 branch Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: const-constraints on struct rset method arguments Benjamin Franksen
Next: Jenkins build became unstable: epics-base-3.14-win32s #180 APS Jenkins
