Hi Ralph,
I just tested removing the extern "C" from NDArrayPool.cpp and it compiles OK but fails when linking simDetector.
make[5]: Entering directory 'J:/epics/devel/areaDetector-2-6/ADSimDetector/iocs/simDetectorIOC/simDetectorApp/src/O.windows-x64-static'
link -nologo -incremental:no -opt:ref -release /MACHINE:X64 -out:simDetectorApp.exe simDetectorApp_registerRecordDeviceDriver.obj simDetectorAppMain.obj
../../../../../lib/windows-x64-static/simDetector.lib J:/epics/devel/areaDetector-2-6/ADCore/lib/windows-x64-static/ADBase.lib J:/epics/devel/areaDetector-2-6/ADCore/lib/windows-
x64-static/NDPlugin.lib J:/epics/devel/areaDetector-2-6/ADCore/lib/windows-x64-static/ntndArrayConverter.lib H:/epics-devel/epicsV4/EPICS-CPP-4.6.0/normativeTypesCPP/lib/windows-
x64-static/nt.lib H:/epics-devel/epicsV4/EPICS-CPP-4.6.0/pvDatabaseCPP/lib/windows-x64-static/pvDatabase.lib H:/epics-devel/epicsV4/EPICS-CPP-4.6.0/pvAccessCPP/lib/windows-x64-st
atic/pvAccess.lib H:/epics-devel/epicsV4/EPICS-CPP-4.6.0/pvDataCPP/lib/windows-x64-static/pvData.lib J:/epics/devel/areaDetector-2-6/ADCore/lib/windows-x64-static/ntndArrayConver
ter.lib J:/epics/devel/areaDetector-2-6/ADSupport/lib/windows-x64-static/netCDF.lib J:/epics/devel/areaDetector-2-6/ADSupport/lib/windows-x64-static/tiff.lib J:/epics/devel/area
Detector-2-6/ADSupport/lib/windows-x64-static/jpeg.lib J:/epics/devel/areaDetector-2-6/ADSupport/lib/windows-x64-static/xml2.lib J:/epics/devel/areaDetector-2-6/ADSupport/lib/win
dows-x64-static/NeXus.lib J:/epics/devel/areaDetector-2-6/ADSupport/lib/windows-x64-static/hdf5.lib J:/epics/devel/areaDetector-2-6/ADSupport/lib/windows-x64-static/szip.lib J:/
epics/devel/areaDetector-2-6/ADSupport/lib/windows-x64-static/zlib.lib J:/epics/devel/asyn-4-31/lib/windows-x64-static/asyn.lib J:/epics/devel/autosave-5-7-1/lib/windows-x64-stat
ic/autosave.lib J:/epics/devel/busy-1-6-1/lib/windows-x64-static/busy.lib J:/epics/devel/calc-3-6-1/lib/windows-x64-static/calc.lib J:/epics/devel/devIocStats-3-1-14/lib/windows
-x64-static/devIocStats.lib J:/epics/devel/sscan-2-10-2/lib/windows-x64-static/sscan.lib J:/epics/devel/seq-2-2-4/lib/windows-x64-static/seq.lib J:/epics/devel/seq-2-2-4/lib/win
dows-x64-static/pv.lib H:/epics-devel/base-3.15.5/lib/windows-x64-static/dbRecStd.lib H:/epics-devel/base-3.15.5/lib/windows-x64-static/dbCore.lib H:/epics-devel/base-3.15.5/lib
/windows-x64-static/ca.lib H:/epics-devel/base-3.15.5/lib/windows-x64-static/Com.lib gdi32.lib oleaut32.lib psapi.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Creating library simDetectorApp.lib and object simDetectorApp.exp
NDPlugin.lib(NDFileHDF5LayoutXML.obj) : warning LNK4217: locally defined symbol xmlFree imported in function "private: int __cdecl hdf5::LayoutXML::parse_root(void)" (?parse_root@LayoutXML@hdf5@@AEAAHXZ)
simDetectorApp_registerRecordDeviceDriver.obj : error LNK2019: unresolved external symbol pvar_int_eraseNDAttributes referenced in function "void __cdecl `dynamic initializer for 'vardefs''(void)" (??__Evardefs@@YAXXZ)
simDetectorApp.exe : fatal error LNK1120: 1 unresolved externals
H:/epics-devel/base-3.15.5/configure/RULES_BUILD:201: recipe for target 'simDetectorApp.exe' failed
make[5]: *** [simDetectorApp.exe] Error 1120
make[5]: Leaving directory 'J:/epics/devel/areaDetector-2-6/ADSimDetector/iocs/simDetectorIOC/simDetectorApp/src/O.windows-x64-static'
H:/epics-devel/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static' failed
make[4]: *** [install.windows-x64-static] Error 2
make[4]: Leaving directory 'J:/epics/devel/areaDetector-2-6/ADSimDetector/iocs/simDetectorIOC/simDetectorApp/src'
H:/epics-devel/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[3]: *** [src.install] Error 2
make[3]: Leaving directory 'J:/epics/devel/areaDetector-2-6/ADSimDetector/iocs/simDetectorIOC/simDetectorApp'
H:/epics-devel/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'simDetectorApp.install' failed
make[2]: *** [simDetectorApp.install] Error 2
make[2]: Leaving directory 'J:/epics/devel/areaDetector-2-6/ADSimDetector/iocs/simDetectorIOC'
H:/epics-devel/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'simDetectorIOC.install' failed
make[1]: *** [simDetectorIOC.install] Error 2
make[1]: Leaving directory 'J:/epics/devel/areaDetector-2-6/ADSimDetector/iocs'
H:/epics-devel/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'iocs.install' failed
make: *** [iocs.install] Error 2
So it appears the extern "C" is required on Windows. It links fine on Linux without extern "C".
Sent: Tuesday, March 21, 2017 7:31 AM
To: Ralph Lange; EPICS Core Talk
Subject: RE: epicsExport.h on Windows
Hi Ralph,
I don't use epicsExportAddress very much. But I just did a search of all of synApps, including areaDetector, and found this:
corvette:~/devel>find . -name '*.cpp' -exec grep -H epicsExportAddress {} \;
./areaDetector-2-6/ADCore/ADApp/ADSrc/NDArrayPool.cpp:extern "C" {epicsExportAddress(int, eraseNDAttributes);}
./motor-6-9/motorApp/NPointSrc/C300MotorDriver.cpp:extern "C" {epicsExportAddress(int, C300Tolerance);}
./motor-6-9/motorApp/OmsAsynSrc/omsMAXv.cpp:extern "C" {epicsExportAddress(int, motorMAXvdebug);}
./motor-6-9/motorApp/OmsAsynSrc/omsMAXvEncFunc.cpp:extern "C" {epicsExportAddress(int, motorMAXvEncFuncdebug);}
./motor-6-9/motorApp/OmsAsynSrc/omsMAXnet.cpp:extern "C" {epicsExportAddress(int, motorMAXnetdebug);}
./motor-6-9/motorApp/OmsAsynSrc/omsBaseController.cpp:extern "C" {epicsExportAddress(int, motorOMSBASEdebug);}
So all instances are indeed wrapped in extern "C".
A search of base 3.14.12.5, 3.15.5, and EPICS V4 4.6.0 finds no occurrences of epicsExportAddress in .cpp files.
From: [email protected] [[email protected]] on behalf of Ralph Lange [[email protected]]
Sent: Tuesday, March 21, 2017 7:16 AM
To: EPICS Core Talk
Subject: epicsExport.h on Windows
Dear Core-Talkers,
For a device support partly written in C++, we have been getting a pull request for Windows builds that adds extern "C" declarations around EPICS exports, e.g.
-epicsExportAddress(double, connectInterval);
+extern "C" {
+ epicsExportAddress(double, connectInterval);
with the comment
I am afraid that the extern statements in epicsExport.h are ignored by VS compiler when expanding the epicsRegisterFunction macro. Therefore they need to be repeated here otherwise we get a linking failure when building test IOC.
As my Windows experience is very limited - is there a better way to handle that?
~Ralph
- epicsExport.h on Windows Ralph Lange
- RE: epicsExport.h on Windows Mark Rivers
Re: epicsExport.h on Windows Michael Davidsaver
<2017>
2025
2026
<2017>
2025
2026
