2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS R3.15.5 IOC crashes for DBR_CTRL_CHAR request with 1 array element
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 1 Apr 2017 12:12:56 -0400
I've opened https://bugs.launchpad.net/epics-base/+bug/1678494
On 04/01/2017 09:20 AM, Kasemir, Kay wrote:
> Hi:
> When reading a "long string" PV as DBR_CTRL_CHAR with 1 array element,
> an EPICS 3.15.5 IOC crashes.
> Has been OK with R3.14.x.
> Example C client and stack trace of server is below. Basically, CA
> server seems to try return all elements of the CHAR array, but the
> buffer only allows for the 1 requested.
> Why I ran into this:
> Older IOCs, i.e. most of those in operation ;-),  don't support
> DBE_PROPERTY.
> So clients fetch the DBR_CTRL_native_type once, then subscribe to
> for example DBR_STS_* for the complete array.
> When fetching the initial meta data, they don't need the complete value.
> In fact for large arrays it would be wasteful to keep a copy of the
> whole outdated array, just need the meta data and then one instance of
> the 'current' array.
> Thanks,
> Kay
> Example C code that crashes IOC:
> /* USAGE: cademo SomePV.INP$
>  * Fetches a "long string" channel as DBR_CTRL_CHAR[1].
>  * OK for R4.14.*, crashes R3.15.5
> #include <stdio.h>
> #include <string.h>
> #include <epicsStdlib.h>
> #include <epicsString.h>
> #include <cadef.h>
> int main (int argc, char *argv[])
>     const char *name = argv[1];
>     int result;
>     chid chid;
>     struct dbr_ctrl_char value;
>     puts(name);
>     result = ca_context_create(ca_disable_preemptive_callback);
>     SEVCHK(result, "connect");
>     result = ca_create_channel(name, 0, 0, 0, &chid);
>     SEVCHK(result, "create");
>     result = ca_pend_io(2.0);
>     SEVCHK(result, "pend create");
>     result = ca_array_get(DBR_CTRL_CHAR, 1, chid, &value);
>     SEVCHK(result, "get");
>     SEVCHK(result, "pend get");
>     ca_context_destroy();
>     return result;
> For an IOC created via `makeBaseApp.pl -t example`, when reading
> `$(user):ai1.INP$`, the IOC crashes while placing the value,
> `$(user):calcExample1.VAL NPP NMS`, in the ca-get return buffer:
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 0x7fffd75f8700 (LWP 4974)]
> 0x00007ffff66eb795 in __strncpy_sse2_unaligned () from /lib64/libc.so.6
> Missing separate debuginfos, use: debuginfo-install
> glibc-2.17-157.el7.x86_64 libgcc-4.8.5-11.el7.x86_64
> libstdc++-4.8.5-11.el7.x86_64 ncurses-libs-5.9-13.20130511.el7.x86_64
> readline-6.2-9.el7.x86_64
> (gdb) bt
> #0  0x00007ffff66eb795 in __strncpy_sse2_unaligned () from /lib64/libc.so.6
> #1  0x00007ffff7735ebf in getLinkValue (paddr=0x7fffe4013020,
>     nRequest=<optimized out>, pbuf=0x7ffff7e53035
> "training:calcExample1.VAL NPP NMS",
>     dbrType=<optimized out>) at ../../../src/ioc/db/dbAccess.c:773
> #2  dbGet (paddr=paddr@entry=0x7fffe4013020, dbrType=dbrType@entry=2,
> pbuffer=<optimized out>,
>     options=options@entry=0x7fffd75f76e0,
> nRequest=nRequest@entry=0x7fffd75f7c30,
>     pflin=pflin@entry=0x0) at ../../../src/ioc/db/dbAccess.c:857
> #3  0x00007ffff773888c in dbChannelGet (chan=chan@entry=0x7fffe4013018,
> type=type@entry=2,
>     pbuffer=<optimized out>, options=options@entry=0x7fffd75f76e0,
>     nRequest=nRequest@entry=0x7fffd75f7c30, pfl=pfl@entry=0x0)
>     at ../../../src/ioc/db/dbChannel.c:668
> #4  0x00007ffff774b8d3 in dbChannel_get_count
>     buffer_type=<optimized out>, pbuffer=0x7ffff7e53020,
>     pfl=pfl@entry=0x0) at ../../../src/ioc/db/db_access.c:685
> #5  0x00007ffff776f6c2 in read_reply (pfl=0x0, eventsRemaining=1,
> dbch=0x7fffe4013018,
>     pArg=0x7fffd75f7c50) at ../../../src/ioc/rsrv/camessage.c:587
> #6  read_notify_action (mp=<optimized out>, pPayload=<optimized out>,
> client=<optimized out>)
>     at ../../../src/ioc/rsrv/camessage.c:800
> #7  0x00007ffff77708df in camessage (client=client@entry=0x7fffec000f90)
>     at ../../../src/ioc/rsrv/camessage.c:2628
> #8  0x00007ffff776d26c in camsgtask (pParm=0x7fffec000f90)
>     at ../../../src/ioc/rsrv/camsgtask.c:129
> #9  0x00007ffff727a58c in start_routine (arg=0x7fffe0001130)
>     at ../../../src/libCom/osi/os/posix/osdThread.c:403
> #10 0x00007ffff6441dc5 in start_thread () from /lib64/libpthread.so.0
> #11 0x00007ffff674d73d in clone () from /lib64/libc.so.6
Re: EPICS R3.15.5 IOC crashes for DBR_CTRL_CHAR request with 1 array element Michael Davidsaver
EPICS R3.15.5 IOC crashes for DBR_CTRL_CHAR request with 1 array element Kasemir, Kay
Prev: EPICS R3.15.5 IOC crashes for DBR_CTRL_CHAR request with 1 array element Kasemir, Kay
Next: Re: EPICS R3.15.5 IOC crashes for DBR_CTRL_CHAR request with 1 array element Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
