2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c
To: [email protected]
Date: Thu, 20 Apr 2017 13:27:29 +0200
With RTEMS (4.11.99, aka 4.12) setting the IP_MULTICAST_LOOP for the loopback gives
Had to use sizeof char as argument for the IP_MULTICAST_LOOP setsockopt call.
Changed it to
        int intTrue = 1;
        if (setsockopt (beaconSocket, SOL_SOCKET, SO_BROADCAST,
                        (char *)&intTrue, sizeof(intTrue))<0) {
            cantProceed("CAS: online socket set up error\n");
#ifdef IP_ADD_MEMBERSHIP
#if defined(__rtems__)
            char flag = 1;
#else
            int flag = 1;
#endif
            if (setsockopt(beaconSocket, IPPROTO_IP, IP_MULTICAST_LOOP,
                           (char *)&flag, sizeof(flag))<0) {
                char sockErrBuf[64];
                epicsSocketConvertErrnoToString (
                            sockErrBuf, sizeof ( sockErrBuf ) );
                errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
#endif
    /* populate the interface address list (default is empty) */
rtems@epics:~/EPICS/add-rtems-4.12-api$ diff -Naur src/ioc/rsrv/caservertask.c /tmp/caservertask.c
--- src/ioc/rsrv/caservertask.c	2017-04-20 13:21:40.613544330 +0200
+++ /tmp/caservertask.c	2017-04-20 13:23:06.537549469 +0200
@@ -307,17 +307,13 @@
-#if defined(__rtems__)
-	    char flag = 1;
-#else
             int flag = 1;
-#endif
-                errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
+                errlogPrintf("rsrv: failed to set mcast loopback\n");
 #endif
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Prev: Build failed in Jenkins: epics-base-3.15-win32s-test #103 APS Jenkins
Next: Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-win64 #289 APS Jenkins
