On 04/26/2017 05:52 AM, Heinz Junkes wrote:
> -static pthread_key_t getpthreadInfo;
> +__thread epicsThreadOSD *tls_pthreadInfo;
Well, the main potential issue I see is the '__thread' qualifier is not
part of standard (until C11 when it is spelled 'thread_local'). I know
that GCC and clang have supported this for some time. Have you (or
Andrew) confirmed support with sun studio? I find references which
suggest that this has been supported for some time there as well.
https://blogs.oracle.com/x86be/entry/thread_local_storage_support_in
https://docs.oracle.com/cd/E19205-01/819-5267/bkaeg/index.html
Other points:
* the duplicate definition of 'struct epicsEventOSD' should avoided.
* Why prefer prink to fprintf in some, but not all cases? I suspect
that fprintf will work for all cases in this file, or alternately
#define printf in terms of printk.
I've also pushed some changes to fix building against RTEMS 4.10. I
haven't been able to run test this yet.
- Re: changes to libCom/osi/os/osdThread.c to be used for RTEMS 4.12 Heinz Junkes
- changes to libCom/osi/os/osdThread.c to be used for RTEMS 4.12 Heinz Junkes
Build failed in Jenkins: epics-base-3.16-win32-test #53 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-mac-test #79 APS Jenkins
<2017>
2025
2026
<2017>
2025
2026
