2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: windows build/test failures
To: <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>
Date: Sat, 6 May 2017 17:50:57 +0000
Hi Michael,
Visual Studio C runtime used 3 digit exponents by default prior to VS 2015, but you can change this behaviour.
https://msdn.microsoft.com/en-us/library/0fatw238(v=vs.120).aspx
in VS 2015 the above function is withdrawn and 2 digit exponents are used, so you'd need to protect any usage of this function with something like
#if defined(_WIN32)  && defined(_MSC_VER) && (_MSC_VER < 1900)
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Michael Davidsaver
Sent: 06 May 2017 02:02
To: Andrew Johnson; Ralph Lange; EPICS core-talk
Subject: Re: windows build/test failures
the dllimport/export issue is fixed.  My mistake in including epicsExport.h in the wrong place.
The test failure is at least diagnosed:
> not ok 739 - cvtFloatToString(1e+08, 6) == 12 (13) -> "1.000000e+008"
>     ok 739 - cvtFloatToString(1e+08, 6) == 12 (12) -> "1.000000e+08"
An extra zero in the exponent.  I don't see this as a blocker for a pre-release.
I also fixed an issue with the filterTestHarness and filter registration.  The RTEMS tests, individual and test harnesses, now pass for me with qemu.
On 05/05/2017 08:43 AM, Michael Davidsaver wrote:
> After I merged the link-support and int64 code last night two windows
> issues turned up.  Some assistance would be appreciated as I can't
> reproduce these myself.
> One is a dll import/export error which I can not make sense of as
> dbFastGetConvertRoutine should be marked with dllimport in this file,
> but doesn't appear to be (to my limited knowledge):
>> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release -version:3.16      -out:dbTestIoc.dll -implib:dbTestIoc.lib        arrRecord.obj xRecord.obj dbLinkdset.obj xLink.obj devx.obj jlinkz.obj      ../../../../../lib/win32-x86/dbCore.lib  ../../../../../lib/win32-x86/ca.lib  ../../../../../lib/win32-x86/Com.lib
>>    Creating library dbTestIoc.lib and object dbTestIoc.exp jlinkz.obj
>> : error LNK2001: unresolved external symbol _dbFastGetConvertRoutine
>> jlinkz.obj : error LNK2001: unresolved external symbol
>> _dbFastPutConvertRoutine dbTestIoc.dll : fatal error LNK1120: 2
>> unresolved externals
> https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/106/console
> The other is a test failure.  It doesn't print enough for me to be
> able to say what the issue is.
>> src/libCom/test/O.windows-x64-static/cvtFastTest.tap ..............
>> not ok 724 - cvtFloatToString(1e+08, 1) == 7 not ok 727 -
>> cvtFloatToString(1e+08, 2) == 8 not ok 730 - cvtFloatToString(1e+08,
>> 3) == 9 not ok 733 - cvtFloatToString(1e+08, 4) == 10 not ok 736 -
>> cvtFloatToString(1e+08, 5) == 11 not ok 739 - cvtFloatToString(1e+08,
>> 6) == 12 Failed 6/1062 subtests
> https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s-test/69/console
Re: windows build/test failures Michael Davidsaver
Prev: Jenkins build is back to normal : epics-base-3.16-win32s-test #73 APS Jenkins
Next: Re: windows build/test failures Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: windows build/test failures Michael Davidsaver
