On 05/08/2017 03:59 PM, APS Jenkins wrote:
> See <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/97/display/redirect>
> perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
> /bin/sh: line 1: 47257 Abort trap: 6 perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
> make[2]: [epicsAtomicTest.tap] Error 134 (ignored)
> src/libCom/test/O.darwin-x86/epicsAtomicTest.tap ..........
> Failed 29/50 subtests
> Test Summary Report
> src/libCom/test/O.darwin-x86/epicsAtomicTest.tap (Wstat: 0 Tests: 21 Failed: 0)
> Parse errors: Bad plan. You planned 50 tests but ran 21.
> Files=82, Tests=10637, 1 wallclock secs ( 0.72 usr 0.07 sys + 0.07 cusr 0.11 csys = 0.97 CPU)
> Result: FAIL
So this time for a change epicsAtomicTest hung completely instead of
dying with an obscure malloc() failure. I tried to attach lldb to the
process, but couldn't get it to stick:
pop-vm$ lldb -p 47257
(lldb) process attach --pid 47257
error: attach failed: lost connection
I hoped that sending it a SIGABRT would cause it to core-dump, but no luck.
Any other ideas how to debug this problem (which only seems to happen
when Jenkins runs this test on the Mac build agent) would be appreciated...
- Andrew
- Build failed in Jenkins: epics-base-3.16-mac-test #97 APS Jenkins
Re: Problem with the iptables DNAT filter Andrew Johnson
<2017>
2025
2026
Jenkins build is back to normal : epics-base-3.16-mac-test #98 APS Jenkins
<2017>
2025
2026
