2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fwd: bugfix of PCAS library
To: Andrew Johnson <[email protected]>, EPICS core-talk <[email protected]>
Date: Wed, 10 May 2017 12:00:16 +0200
I agree this is a quick fix by duplicating code and refactoring is needed.
One idea I had was to add an API virtual function "getValueSizeElements" to gdd, in analog to "getDataSizeElements". But that would make gdd interface depend on gddAppTable, which might be a bad practice.
On 05/10/2017 12:57 AM, Andrew Johnson wrote:
Unless anyone objects I propose to cherry-pick this commit onto the 3.14
branch. As Xiaoqiang says in the commit message this change has already
been implemented in the monitorResponse methods; this adds the same code
to the readResponse and readNotifyResponse methods, and while I don't
claim to understand the PCAS code in detail I can see that the same
change is likely to be needed there for the PCAS to support dynamic
arrays properly.
Thanks Xiaoqiang!
- Andrew
-------- Forwarded Message --------
Subject: bugfix of PCAS library
Date: Fri, 5 May 2017 13:21:50 +0200
To: tech-talk <[email protected]>
The problem was discovered using a PCASpy server application.
https://github.com/paulscherrerinstitute/pcaspy/issues/43
A short summary is that the pcas library calculate the wrong size if a
container type gdd is returned by a server application, in a read action
with zero requested count.
The proposed change has been verified to fix the issue.
https://github.com/xiaoqiangwang/epics-base/commit/f1367b28c6e620f2b4abb276812df854c47e3a48
Best
Xiaoqiang
Re: Fwd: bugfix of PCAS library Andrew Johnson
Prev: Re: Fwd: bugfix of PCAS library Bruce Hill
Next: Re: Fwd: bugfix of PCAS library Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
