2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Make targets for CI
To: EPICS core-talk <[email protected]>
Date: Fri, 19 May 2017 17:56:29 -0500
I just added 2 more make targets to all 3 branches that are intended for
CI use: clean-tests and test-results. Check out the Release Notes for
info; test-results runs 'prove --failures' in each test dir, and
clean-tests deletes old .tap and .xml files (allowing you to re-run all
the tests without having to do a rebuild).
I'll be on vacation next week, but I might still be active since it's
supposed to get a bit wet.
- Andrew
Prev: Jenkins build is back to normal : epics-base-3.16-win64-test #69 APS Jenkins
Next: Jenkins build is back to stable : epics-base-3.14 #256 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-base-3.14 #256 APS Jenkins
Next: pvaSrv "can not monitor a link field" Kasemir, Kay
