Hi:
I followed Michael's instructions from https://github.com/mdavidsaver/v4workspace/tree/pva2pva .
Builds OK, just had to manually edit the RELEASE.local.in into a RELEASE.local, not sure if there's an automake way to handle that.
Also couldn't find "qsrv" as such, but in the end the pva2pva/bin/linux-x86_64/softIocPVA contains a PVA server, there's no need to add anything to the st.cmd.
With that, I can monitor link fields.
Also, not having to add anything to the st.cmd file to get the PVA server started is nice.
So this limited test suggests replacing pvaSrv with qsrv.
Kay
Sent: Monday, May 22, 2017 10:58 AM
To: Ralph Lange; Kasemir, Kay
Cc: EPICS Core Talk
Subject: Re: pvaSrv "can not monitor a link field"
On 05/22/2017 10:48 AM, Ralph Lange wrote:
> Depending on what the release plans for QSRV are (@Michael?),
> You actually might want to add this as an issue to pvaSrv.
I was just about to ask Kay if he would be willing to test QSRV,
> Thanks a lot,
> ~Ralph
> ps. We need more unit tests.
> On Mon, May 22, 2017 at 11:29 PM, Kasemir, Kay <[email protected]
> <mailto:[email protected]>> wrote:
> Hi:
> This came up during the V4 introduction at the recent EPICS meeting.
> I first thought it's a bug in CS-Studio, but instead it's a
> limitation in pvaSrv.
> Assume an IOC with pvaSrv added to it, take any calc or ai record:
> pvget that_record
> -> fine
> pvget that_record.INP (or INPA for a calc record)
> -> fine
> pvget -m that_record
> -> fine
> pvget -m that_record.INP (or INPA for a calc record)
> -> Don't get a value, instead message(can not monitor a link field,
> error)
> monitorConnect(Status [type=ERROR, message=create dbPvMonitor failed])
> Checking the 4.6.0 release of V4, pvaSrv/src/dbPv/[3.14,
> 3.15]/dbPvMonitor.cpp both check for link fields and refuse to
> monitor them with this error message.
> Fundamentally, 'camonitor' can monitor link fields, and there are
> some use cases for doing this:
> Displays (EDM, CSS, ..) sometimes need to put 'INP' links on the
> display so that users can change the input.
> The CSS EPCIS PV Tree tool monitors input links to show the link
> hierarchy.
> Is monitoring link fields supported in QSRV?
> Thanks,
> Kay
- Re: pvaSrv "can not monitor a link field" Michael Davidsaver
- pvaSrv "can not monitor a link field" Kasemir, Kay
- Re: pvaSrv "can not monitor a link field" Ralph Lange
Re: pvaSrv "can not monitor a link field" Kasemir, Kay
<2017>
2025
2026
<2017>
2025
2026
