2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-rtems #124
To: [email protected]
Date: Sat, 27 May 2017 21:05:57 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-rtems/124/display/redirect>
[...truncated 423.79 KB...]
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devI64inSoftCallback.d  ../../../src/std/dev/devI64inSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devBiSoftCallback.d  ../../../src/std/dev/devBiSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devAiSoftCallback.d  ../../../src/std/dev/devAiSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devGeneralTime.d  ../../../src/std/dev/devGeneralTime.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devWfSoft.d  ../../../src/std/dev/devWfSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devSoSoft.d  ../../../src/std/dev/devSoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devSiSoft.d  ../../../src/std/dev/devSiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devSASoft.d  ../../../src/std/dev/devSASoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devPrintfSoft.d  ../../../src/std/dev/devPrintfSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbboSoftRaw.d  ../../../src/std/dev/devMbboSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbboSoft.d  ../../../src/std/dev/devMbboSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbboDirectSoftRaw.d  ../../../src/std/dev/devMbboDirectSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbboDirectSoft.d  ../../../src/std/dev/devMbboDirectSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbbiSoftRaw.d  ../../../src/std/dev/devMbbiSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbbiSoft.d  ../../../src/std/dev/devMbbiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbbiDirectSoftRaw.d  ../../../src/std/dev/devMbbiDirectSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devMbbiDirectSoft.d  ../../../src/std/dev/devMbbiDirectSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devLsoSoft.d  ../../../src/std/dev/devLsoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devLsiSoft.d  ../../../src/std/dev/devLsiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devLoSoft.d  ../../../src/std/dev/devLoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devLiSoft.d  ../../../src/std/dev/devLiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devI64outSoft.d  ../../../src/std/dev/devI64outSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devI64inSoft.d  ../../../src/std/dev/devI64inSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devHistogramSoft.d  ../../../src/std/dev/devHistogramSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devEventSoft.d  ../../../src/std/dev/devEventSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devCalcoutSoft.d  ../../../src/std/dev/devCalcoutSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devBoDbState.d  ../../../src/std/dev/devBoDbState.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devBoSoftRaw.d  ../../../src/std/dev/devBoSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devBoSoft.d  ../../../src/std/dev/devBoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devBiDbState.d  ../../../src/std/dev/devBiDbState.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devBiSoftRaw.d  ../../../src/std/dev/devBiSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devBiSoft.d  ../../../src/std/dev/devBiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devAoSoftRaw.d  ../../../src/std/dev/devAoSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devAoSoft.d  ../../../src/std/dev/devAoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devAiSoftRaw.d  ../../../src/std/dev/devAiSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devAiSoft.d  ../../../src/std/dev/devAiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devAaoSoft.d  ../../../src/std/dev/devAaoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF devAaiSoft.d  ../../../src/std/dev/devAaiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF waveformRecord.d  ../../../src/std/rec/waveformRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF subArrayRecord.d  ../../../src/std/rec/subArrayRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF subRecord.d  ../../../src/std/rec/subRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF stringoutRecord.d  ../../../src/std/rec/stringoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF stringinRecord.d  ../../../src/std/rec/stringinRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF stateRecord.d  ../../../src/std/rec/stateRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF seqRecord.d  ../../../src/std/rec/seqRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF selRecord.d  ../../../src/std/rec/selRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF printfRecord.d  ../../../src/std/rec/printfRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF permissiveRecord.d  ../../../src/std/rec/permissiveRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF mbboDirectRecord.d  ../../../src/std/rec/mbboDirectRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF mbboRecord.d  ../../../src/std/rec/mbboRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF mbbiDirectRecord.d  ../../../src/std/rec/mbbiDirectRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF mbbiRecord.d  ../../../src/std/rec/mbbiRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF lsoRecord.d  ../../../src/std/rec/lsoRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF lsiRecord.d  ../../../src/std/rec/lsiRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF longoutRecord.d  ../../../src/std/rec/longoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF longinRecord.d  ../../../src/std/rec/longinRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF int64outRecord.d  ../../../src/std/rec/int64outRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF int64inRecord.d  ../../../src/std/rec/int64inRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF histogramRecord.d  ../../../src/std/rec/histogramRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF fanoutRecord.d  ../../../src/std/rec/fanoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF eventRecord.d  ../../../src/std/rec/eventRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dfanoutRecord.d  ../../../src/std/rec/dfanoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF compressRecord.d  ../../../src/std/rec/compressRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF calcoutRecord.d  ../../../src/std/rec/calcoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF calcRecord.d  ../../../src/std/rec/calcRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF boRecord.d  ../../../src/std/rec/boRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF biRecord.d  ../../../src/std/rec/biRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF aSubRecord.d  ../../../src/std/rec/aSubRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF aoRecord.d  ../../../src/std/rec/aoRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF aiRecord.d  ../../../src/std/rec/aiRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF aaoRecord.d  ../../../src/std/rec/aaoRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF aaiRecord.d  ../../../src/std/rec/aaiRecord.c
FINAL_LOCATION=/Jenkins/jenkins/jobs/epics-base-3.16/workspace
perl -CSD ../../../src/std/softIoc/makeInstallDir.pl "/Jenkins/jenkins/jobs/epics-base-3.16/workspace" > epicsInstallDir.h
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF softMain.d  ../../../src/std/softIoc/softMain.cpp
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../dbd    -o softIoc_registerRecordDeviceDriver.cpp ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-base-3.16/workspace
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF softIoc_registerRecordDeviceDriver.d  softIoc_registerRecordDeviceDriver.cpp
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/O.RTEMS-uC5282'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/O.RTEMS-uC5282'
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/aaiRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/aaoRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/aiRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/aoRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/aSubRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/biRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/boRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/calcRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/calcoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/compressRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/dfanoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/eventRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/fanoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/histogramRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/int64inRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/int64outRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/longinRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/longoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/lsiRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/lsoRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/mbbiRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/mbbiDirectRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/mbboRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/mbboDirectRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/permissiveRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/printfRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/selRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/seqRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/stateRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/stringinRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/stringoutRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/subRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/subArrayRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/rec/waveformRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAaiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAaoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAiSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAoSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBiSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBiDbState.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBoSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBoDbState.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devCalcoutSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devEventSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devHistogramSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devI64inSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devI64outSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devLiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devLoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devLsiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devLsoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbbiDirectSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbbiDirectSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbbiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbbiSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbboDirectSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbboDirectSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbboSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbboSoftRaw.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devPrintfSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devSASoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devSiSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devSoSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devWfSoft.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devGeneralTime.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAiSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBiSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devI64inSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devLiSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbbiDirectSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbbiSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devSiSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devAoSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devBoSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devCalcoutSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devI64outSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devLoSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devLsoSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbboSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devMbboDirectSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devPrintfSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devSoSoftCallback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devTimestamp.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devStdio.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/devEnviron.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/dev/asSubRecordFunctions.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/filters/ts.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/filters/dbnd.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/filters/arr.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/filters/sync.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/link/lnkConst.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/link/lnkCalc.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ar rc   libdbRecStd.a        aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o int64inRecord.o int64outRecord.o longinRecord.o longoutRecord.o lsiRecord.o lsoRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o printfRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBiDbState.o devBoSoft.o devBoSoftRaw.o devBoDbState.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devI64inSoft.o devI64outSoft.o devLiSoft.o devLoSoft.o devLsiSoft.o devLsoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devPrintfSoft.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devGeneralTime.o devAiSoftCallback.o devBiSoftCallback.o devI64inSoftCallback.o devLiSoftCallback.o devMbbiDirectSoftCallback.o devMbbiSoftCallback.o devSiSoftCallback.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devI64outSoftCallback.o devLoSoftCallback.o devLsoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devPrintfSoftCallback.o devSoSoftCallback.o devTimestamp.o devStdio.o devEnviron.o asSubRecordFunctions.o ts.o dbnd.o arr.o sync.o lnkConst.o lnkCalc.o
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ranlib libdbRecStd.a
Installing library ../../../lib/RTEMS-uC5282/libdbRecStd.a
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c softIoc_registerRecordDeviceDriver.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/link -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/std/softIoc/softMain.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -o softIoc -static -L/Jenkins/jenkins/jobs/epics-base-3.16/workspace/lib/RTEMS-uC5282           -mcpu=5282 -u Init /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-dpmem.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-mp.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-part.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-signal.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-rtmon.rel            softIoc_registerRecordDeviceDriver.o softMain.o    -ldbRecStd -ldbCore -lca -lCom      -lreadline -lncurses -lm -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm -lgcc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-objcopy -O binary -R .comment -S softIoc softIoc.boot
Installing created executable ../../../bin/RTEMS-uC5282/softIoc
Installing created executable ../../../bin/RTEMS-uC5282/softIoc.boot
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std'
make -C std/filters/test RTEMS-uC5282
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/filters/test'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. T_A=linux-x86_64
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/filters/test/O.linux-x86_64'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/filters/test/O.linux-x86_64'
make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../../../.. T_A=RTEMS-uC5282
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/filters/test/O.RTEMS-uC5282'
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../xRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../arrRecord.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ar rc   libRecs.a        xRecord.o arrRecord.o
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ranlib libRecs.a
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c filterTest_registerRecordDeviceDriver.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../tsTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../dbndTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../arrTest.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../syncTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../epicsRunFilterTests.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../rtemsTestHarness.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -o filterTestHarness -static -L/Jenkins/jenkins/jobs/epics-base-3.16/workspace/lib/RTEMS-uC5282 -L/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/filters/test/O.RTEMS-uC5282           -mcpu=5282 -u Init /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-dpmem.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-mp.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-part.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-signal.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-rtmon.rel            filterTest_registerRecordDeviceDriver.o tsTest.o dbndTest.o arrTest.o syncTest.o epicsRunFilterTests.o rtemsTestHarness.o    -lRecs -ldbRecStd -ldbCore -lca -lCom      -lreadline -lncurses -lm -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm -lgcc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-objcopy -O binary -R .comment -S filterTestHarness filterTestHarness.boot
Installing created executable ../../../../../bin/RTEMS-uC5282/filterTestHarness
Installing created executable ../../../../../bin/RTEMS-uC5282/filterTestHarness.boot
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/filters/test/O.RTEMS-uC5282'
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/filters/test'
make -C std/rec/test RTEMS-uC5282
make[2]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test/O.linux-x86_64'
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test/O.linux-x86_64'
make[3]: Entering directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test/O.RTEMS-uC5282'
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../asTestLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ar rc   libdbRecStdTest.a        asTestLib.o
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ranlib libdbRecStdTest.a
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c recTestIoc_registerRecordDeviceDriver.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c asTestIoc_registerRecordDeviceDriver.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../arrayOpTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../recMiscTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../linkRetargetLinkTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../linkInitTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../compressTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../asyncSoftTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../asTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../analogMonitorTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c analogMonitorTest_registerRecordDeviceDriver.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282         -DUSE_TYPED_RSET         -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/RTEMS -I../../../../../include         -c ../epicsRunRecordTests.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -o recordTestHarness -static -L/Jenkins/jenkins/jobs/epics-base-3.16/workspace/lib/RTEMS-uC5282 -L/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test/O.RTEMS-uC5282           -mcpu=5282 -u Init /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-dpmem.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-mp.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-part.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-signal.rel /usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/no-rtmon.rel            recTestIoc_registerRecordDeviceDriver.o asTestIoc_registerRecordDeviceDriver.o arrayOpTest.o recMiscTest.o linkRetargetLinkTest.o linkInitTest.o compressTest.o asyncSoftTest.o asTest.o analogMonitorTest.o analogMonitorTest_registerRecordDeviceDriver.o epicsRunRecordTests.o rtemsTestHarness.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom      -lreadline -lncurses -lm -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm -lgcc
asyncSoftTest.o: In function `recMiscTest':
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test/O.RTEMS-uC5282/../asyncSoftTest.c:160: multiple definition of `recMiscTest'
recMiscTest.o:/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test/O.RTEMS-uC5282/../recMiscTest.c:64: first defined here
collect2: ld returned 1 exit status
make[3]: *** [recordTestHarness] Error 1
make[3]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test/O.RTEMS-uC5282'
make[2]: *** [RTEMS-uC5282] Error 2
make[2]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src/std/rec/test'
make[1]: *** [std/rec/test.RTEMS-uC5282] Error 2
make[1]: Leaving directory `/Jenkins/jenkins/jobs/epics-base-3.16/workspace/src'
make: *** [src.RTEMS-uC5282] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.16-rtems #125 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-vx68 #124 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-vx69 #124 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.16-vx68 #125 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.16-rtems #125 APS Jenkins
