2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Build problem
To: "[email protected]" <[email protected]>, EPICS Core Talk <[email protected]>
Date: Sun, 4 Jun 2017 18:25:12 +0000
I just found that I am having another problem which I am quite sure is related.
I want to build GraphicsMagick on all architectures except vxWorks.  I thus have this line in my CONFIG_SITE.local.$(EPICS_HOST_ARCH).$(T_A) i.e. CONFIG_SITE.local.linux-x86.vxWorks-ppc32 file:
WITH_GRAPHICSMAGICK = NO
This should prevent GraphicsMagick from being built on vxWorks.  However, as with GRAPHICSMAGICK_EXTERNAL it seems to be ignored.
However if I add this line to that file
WITH_TIFF = NO
this works correctly, it prevents building ADSupport/supportApp/tiffSrc on vxWorks.  So again the problem seems somehow specific to GraphicsMagick.
Sent: Sunday, June 04, 2017 12:57 PM
To: [email protected]; EPICS Core Talk
Subject: Build problem
I'm having a problem building GraphicsMagick in areaDetector/ADSupport and I'm stumped.
Here's the problem.
The top-level areaDetector/configure/CONFIG_SITE includes these lines:
-include $(AREA_DETECTOR)/configure/CONFIG_SITE.local
-include $(AREA_DETECTOR)/configure/CONFIG_SITE.local.$(OS_CLASS)
-include $(AREA_DETECTOR)/configure/CONFIG_SITE.local.$(EPICS_HOST_ARCH)
-include $(AREA_DETECTOR)/configure/CONFIG_SITE.local.$(EPICS_HOST_ARCH).$(T_A)
So it reads 4 CONFIG_SITE.local.* files if they exist.
ADSupport/configure/CONFIG_SITE includes these lines:
# Get settings from AREA_DETECTOR, so we only have to configure once for all detectors if we want to
-include $(AREA_DETECTOR)/configure/CONFIG_SITE.$(EPICS_HOST_ARCH)
-include $(AREA_DETECTOR)/configure/CONFIG_SITE.$(EPICS_HOST_ARCH).Common
ifdef T_A
  -include $(AREA_DETECTOR)/configure/CONFIG_SITE.Common.$(T_A)
  -include $(AREA_DETECTOR)/configure/CONFIG_SITE.$(EPICS_HOST_ARCH).$(T_A)
endif
So it reads a number of files from$(AREA_DETECTOR)/configure if they exist.  The only one that actually exists is CONFIG_SITE, whose contents I have shown above.
CONFIG_SITE.local includes these lines:
# GraphicsMagick is required for NDFileMagick and the URL driver.
WITH_GRAPHICSMAGICK     = YES
GRAPHICSMAGICK_EXTERNAL = YES
# GraphicsMagick defines many global symbols, and one of these (SetImage) conflicts with a symbol
# in the Andor vendor library.  GraphickMagick provides a solution by allowing all external library
# symbols to be prefixed with "Gm".  Enable using this by default.  However, if a system library
# is used it may not be built with this option so this line should be commented out.
GRAPHICSMAGICK_PREFIX_SYMBOLS = YES
#GRAPHICSMAGICK_INCLUDE =
#GRAPHICSMAGICK_LIB     =
# TIFF is required for the NDFileTIFF plugin.
WITH_TIFF     = YES
TIFF_EXTERNAL = YES
#TIFF_INCLUDE =
#TIFF_LIB     =
# XML2 is required for ADCore so there is no WITH_XML2.
XML2_EXTERNAL = YES
#XML2_INCLUDE =
#XML2_LIB     =
Among other things it defines WITH_GRAPHICSMAGICK=YES, GRAPHICSMAGICK_EXTERNAL=YES, WITH_TIFF=YES, TIFF_EXTERNAL=YES, XML2_EXTERNAL=YES.
My CONFIG_SITE.local.Linux includes these lines:
GRAPHICSMAGICK_EXTERNAL = NO
TIFF_EXTERNAL = NO
XML2_EXTERNAL = NO
So it overrides the CONFIG_SITE.local to set xxx_EXTERNAL for each of these libraries to NO rather than YES.
The Makefiles in ADSupport look at the xxx_EXTERNAL flag to decide whether or not to actually build that library.  If it is not NO then it does not build the library.
CONFIG_SITE.local.WIN32 does the same thing for Windows, and again it defines all of the xxx_EXTERNAL flags to NO.
This whole mechanism is generally working fine.  If, for example I comment out the TIFF_EXTERNAL=NO or XML2_EXTERNAL=NO lines in CONFIG_SITE.local.Linux then ADSupport will not build those libraries when I run make in those directories.
The exception to the correct operation is GRAPHICSMAGICK_EXTERNAL=NO.  This flag is correctly obeyed if it set in CONFIG_SITE.local or CONFIG_SITE.local.$(EPICS_HOST_ARCH),  e.g. CONFIG_SITE.local.linux-x86_64.  However, when this flag is set in CONFIG_SITE.local.Linux then it is being ignored.  I am completely baffled by this, since it seems to be equivalent to each of the other flags like XML2_EXTERNAL=NO which are being picked up correctly from CONFIG_SITE.local.Linux.
I have the same problem on Windows.  XM2_EXTERNAL=NO is picked up correctly from CONFIG_SITE.local.WIN32, but GRAPHICSMAGICK_EXTERNAL=NO seems to be ignored in this file.  But it is working correctly if it is defined in CONFIG_SITE.local or CONFIG_SITE.local.$(EPICS_HOST_ARCH), e.g. CONFIG_SITE.local.windows-x64-static.
This is the ADSupport/supportApp/GraphicsMagick/Makefile
TOP = ../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
ifeq ($(WITH_GRAPHICSMAGICK),YES)
  ifeq ($(GRAPHICSMAGICK_EXTERNAL),NO)
    DIRS += filters
    filters_DEPEND_DIRS += magick ttf
    DIRS += wmf
    DIRS += webp
    DIRS += png
    png_DEPEND_DIRS += bzlib
    DIRS += jp2
    DIRS += jbig
    DIRS += coders
    coders_DEPEND_DIRS += bzlib jbig jp2 magick png ttf webp wmf
    DIRS += lcms
    DIRS += bzlib
    DIRS += ttf
    DIRS += magick
    magick_DEPEND_DIRS += bzlib lcms ttf
    DIRS += Magick++
    Magick++_DEPEND_DIRS += magick coders
  endif # ($(GRAPHICSMAGICK_EXTERNAL),NO)
endif # ($(WITH_GRAPHICSMAGICK),YES)
include $(TOP)/configure/RULES_DIRS
#  ADD RULES AFTER THIS LINE
It looks just like the tiffSrc/Makefile
TOP=../..
ifeq ($(WITH_TIFF),YES)
  ifeq ($(TIFF_EXTERNAL),NO)
    INC += tiff.h
    INC += tiffio.h
    INC += tiffvers.h
    INC += tiffconf.h
    tiff_SRCS += tif_write.c
    tiff_SRCS += tif_zip.c
    tiff_SRCS_Linux += tif_unix.c
    tiff_SRCS_WIN32 += tif_win32.c
    tiff_SRCS_vxWorks += tif_vxWorks.c
  endif # ($(TIFF_EXTERNAL),NO)
endif # ($(WITH_TIFF),YES)
But tiffSrc is behaving like it should and GraphicsMagick is not.
All of the areaDetector/configure/CONFIG* files I am using are identical to the configure/EXAMPLE_CONFIG* on the master branch on Github except for CONFIG_SITE.local.Linux where I have uncommented all of the xxx_EXTERNAL=NO lines.  ADSupport is identical to the master branch on Github.
I have search the entire areaDetector tree (actually the entire synApps tree as well) to see if GRAPHICSMAGICK_EXTERNAL might be defined somewhere else, but it is not.
Any ideas on how to track down this problem would be most appreciated!
Re: Build problem Ralph Lange
Build problem Mark Rivers
Prev: Build problem Mark Rivers
Next: Re: Build problem Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
