See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/214/display/redirect>
Started by upstream project "epics-base-3.14" build number 262
originally caused by:
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
> C:/Program Files (x86)/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files (x86)/Git/cmd/git.exe config remote.origin.url lp:epics-base # timeout=10
Cleaning workspace
> C:/Program Files (x86)/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files (x86)/Git/cmd/git.exe reset --hard # timeout=10
> C:/Program Files (x86)/Git/cmd/git.exe clean -fdx # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from lp:epics-base
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:809)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1076)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1107)
at hudson.scm.SCM.checkout(SCM.java:496)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1281)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:604)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
at hudson.model.Run.execute(Run.java:1728)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:98)
at hudson.model.Executor.run(Executor.java:405)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/cmd/git.exe clean -fdx" returned status code 1:
stdout: Removing bin/
Removing configure/O.Common/
Removing configure/O.windows-x64-static/
Removing configure/O.windows-x64/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/perl
Removing lib/windows-x64
Removing lib/windows-x64-static
Removing src/RTEMS/base/O.Common/
Removing src/RTEMS/base/O.windows-x64-static/
Removing src/RTEMS/base/O.windows-x64/
Removing src/as/O.Common/
Removing src/as/O.windows-x64-static/
Removing src/as/O.windows-x64/
Removing src/bpt/O.Common/
Removing src/bpt/O.windows-x64-static/
Removing src/bpt/O.windows-x64/
Removing src/ca/O.Common/
Removing src/ca/O.windows-x64-static/
Removing src/ca/O.windows-x64/
Removing src/cap5/O.Common/
Removing src/cap5/O.windows-x64-static/
Removing src/cap5/O.windows-x64/
Removing src/cas/build/O.Common/
Removing src/cas/build/O.windows-x64-static/
Removing src/cas/build/O.windows-x64/
Removing src/cas/example/directoryService/O.Common/
Removing src/cas/example/directoryService/O.windows-x64-static/
Removing src/cas/example/directoryService/O.windows-x64/
Removing src/catools/O.Common/
Removing src/catools/O.windows-x64-static/
Removing src/catools/O.windows-x64/
Removing src/db/O.Common/
Removing src/db/O.windows-x64-static/
Removing src/db/O.windows-x64/
Removing src/db/test/O.Common/
Removing src/db/test/O.windows-x64-static/
Removing src/db/test/O.windows-x64/
Removing src/dbStatic/O.Common/
Removing src/dbStatic/O.windows-x64-static/
Removing src/dbStatic/O.windows-x64/
Removing src/dbtools/O.Common/
Removing src/dbtools/O.windows-x64-static/
Removing src/dbtools/O.windows-x64/
Removing src/dev/softDev/O.Common/
Removing src/dev/softDev/O.windows-x64-static/
Removing src/dev/softDev/O.windows-x64/
Removing src/dev/testDev/O.Common/
Removing src/dev/testDev/O.windows-x64-static/
Removing src/dev/testDev/O.windows-x64/
Removing src/excas/O.Common/
Removing src/excas/O.windows-x64-static/
Removing src/excas/O.windows-x64/
Removing src/gdd/O.Common/
Removing src/gdd/O.windows-x64-static/
Removing src/gdd/O.windows-x64/
Removing src/libCom/O.Common/
Removing src/libCom/O.windows-x64-static/
Removing src/libCom/O.windows-x64/
Removing src/libCom/test/O.Common/
Removing src/libCom/test/O.windows-x64-static/
Removing src/libCom/test/O.windows-x64/
Removing src/makeBaseApp/O.Common/
Removing src/makeBaseApp/O.windows-x64-static/
Removing src/makeBaseApp/O.windows-x64/
Removing src/makeBaseExt/O.Common/
Removing src/makeBaseExt/O.windows-x64-static/
Removing src/makeBaseExt/O.windows-x64/
Removing src/misc/O.Common/
Removing src/misc/O.windows-x64-static/
Removing src/misc/O.windows-x64/
Removing src/rec/O.Common/
Removing src/rec/O.windows-x64-static/
Removing src/rec/O.windows-x64/
Removing src/registry/O.Common/
Removing src/registry/O.windows-x64-static/
Removing src/registry/O.windows-x64/
Removing src/rsrv/O.Common/
Removing src/rsrv/O.windows-x64-static/
Removing src/rsrv/O.windows-x64/
Removing src/softIoc/O.Common/
Removing src/softIoc/O.windows-x64-static/
Removing src/softIoc/O.windows-x64/
Removing src/tools/O.Common/
Removing src/tools/O.windows-x64-static/
Removing src/tools/O.windows-x64/
Removing src/toolsComm/antelope/O.Common/
Removing src/toolsComm/antelope/O.windows-x64-static/
Removing src/toolsComm/antelope/O.windows-x64/
Removing src/toolsComm/flex/O.Common/
Removing src/toolsComm/flex/O.windows-x64-static/
Removing src/toolsComm/flex/O.windows-x64/
Removing src/util/O.Common/
Removing src/util/O.windows-x64-static/
Removing src/util/O.windows-x64/
Removing src/vxWorks/O.Common/
Removing src/vxWorks/O.windows-x64-static/
Removing src/vxWorks/O.windows-x64/
Removing templates/
stderr: warning: failed to remove lib/
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1877)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1845)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1841)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1486)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1498)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:711)
at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:894)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:869)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:828)
at hudson.remoting.UserRequest.perform(UserRequest.java:153)
at hudson.remoting.UserRequest.perform(UserRequest.java:50)
at hudson.remoting.Request$2.run(Request.java:336)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at ......remote call to win64-1(Native Method)
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1545)
at hudson.remoting.UserResponse.retrieve(UserRequest.java:253)
at hudson.remoting.Channel.call(Channel.java:830)
at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:257)
at com.sun.proxy.$Proxy83.clean(Unknown Source)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
at hudson.plugins.git.extensions.impl.CleanBeforeCheckout.decorateFetchCommand(CleanBeforeCheckout.java:32)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:805)
... 11 more
ERROR: null
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : epics-base-3.14-win64 #215 APS Jenkins
Build failed in Jenkins: epics-base-3.16-mac-test #114 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-mac-test #115 APS Jenkins
<2017>
2025
2026
<2017>
2025
2026
