2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Java PvaClientMonitor questions
To: Mark Rivers <[email protected]>, "'[email protected]'" <[email protected]>, "'Shroff, Kunal'" <[email protected]>, "'Kasemir, Kay'" <[email protected]>
Date: Wed, 5 Jul 2017 10:06:35 -0400
On 07/01/2017 09:59 AM, Mark Rivers wrote:
Any V4 experts able to answer my questions?
I have created an issue that describes the problem.
https://github.com/epics-base/pvAccessJava/issues/9
Not a solution but at least the problem should be visible until someone has time to investigate.
Marty
Sent: Tuesday, June 20, 2017 7:07 PM
To: [email protected]; 'Shroff, Kunal'; 'Marty Kraimer'
Subject: Java PvaClientMonitor questions
Marty and I are working on the new ImageJ plugin that uses pvAccess.  I have some questions about the PvaClientMonitor class.
- I have found that calling PvaClientMonitor->stop() does not actually stop the monitor events from the server to the client.  It does stop PvaClientMonitor->waitEvent() from returning any events.  Looking at the network traffic I can see that images are still being sent from the server machine to the client machine after calling stop().  However, if I destroy the PvaClientMonitor object then the network traffic stops.  Is this the intended behavior, and if so is it documented anywhere?
- What does the PvaClientMonitor->unlisten() method do?  Again, is this documented anywhere?
Java PvaClientMonitor questions Mark Rivers
RE: Java PvaClientMonitor questions Mark Rivers
Prev: RE: Java PvaClientMonitor questions Mark Rivers
Next: Build failed in Jenkins: epics-base-3.16-rtems #133 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: error messages in epics-base (core?) Heinz Junkes
