2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Add optimization switch to compiler dependencies
To: EPICS Core Talk <[email protected]>
Date: Mon, 21 Aug 2017 13:45:24 +0200
Short question:
Would it be worthwhile to add a keyword to the EPICS compiler dependent definitions stuff in libCom/osi that switches off optimization for a function?
Especially for things like test code, implementing tricks to keep the compiler from optimizing away code seems a hopeless struggle against compiler developers.
Cheers,
~Ralph
Re: Add optimization switch to compiler dependencies Johnson, Andrew N.
Prev: RE: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Williams Jr., Ernest L.
Next: Re: Add optimization switch to compiler dependencies Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epicsStackTrace on WIN32 freddie.akeroyd
