2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Possible Access Rights improvement?
To: EPICS Core Talk <[email protected]>
Date: Thu, 24 Aug 2017 15:46:04 +0000
What is the use case?
Assume I have an AI record that reads from a PLC.
So I display that as a text update field on the UI.
Would you routinely display that record as a text entry field?
-Kay
From: [email protected] <[email protected]> on behalf of Ralph Lange <[email protected]>
Sent: Thursday, August 24, 2017 3:34 AM
To: EPICS Core Talk
Subject: Possible Access Rights improvement?
Dear Core-talkers,
There is a possible request from our operations group to show VAL fields of input records as having no write access, if the device support would overwrite any value written at the next record processing.
Technically, these fields are writable.
Functionally, there are issues:
  • The writing client (even using put-callback) will get the new value and show the operation as having succeeded.
  • Other clients doing gets or creating new subscriptions (e.g. newly opened panels) will see the new value.
  • Existing subscriptions (e.g. archivers, gateways, already open panels) will not get an update and have no clue.
  • Depending on the situation (DTYP, SCAN) this inconsistent state may last a while.
What are your thoughts on this?
~Ralph
Re: Possible Access Rights improvement? Ralph Lange
Prev: Improved simulation mode prototype Ralph Lange
Next: Re: Possible Access Rights improvement? Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Possible Access Rights improvement? Ralph Lange
