2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: a short reference of the time zone abbreviation in CONFIG_SITE_ENV
To: [email protected]
Date: Fri, 22 Sep 2017 10:00:15 +0200
   I thought few times where this subjects are belong to....
Then I decided to use core-talk instead of tech-talk and github issue. If you think, I am wrong, please let me know.
   Anyway, as you know, CONFIG_SITE_ENV in EPICS base has EPICS_TIMEZONE:
---- snip snip -----
# Time service:
# EPICS_TIMEZONE
#	Local timezone info for vxWorks and RTEMS.  The format is
#	    <name>::<minutesWest>:<start daylight>:<end daylight>
#	where the start and end are mmddhh - that is month,day,hour
#	e.g. for ANL in 2018: EPICS_TIMEZONE=CUS::360:031102:110402
#	The future dates below assume the rules don't get changed;
#	see http://www.timeanddate.com/time/dst/2018.html to check.
I think, it uses the time zone abbreviation as <name>. And I could find them quite easily and quickly, However, if we can have the link in that file (CONFIG_SITE_ENV) in the same way of DST, for example,
<name> is the Time Zone Abbreviation;
see https://en.wikipedia.org/wiki/List_of_time_zone_abbreviations
it may give users an easy way to access them.
What do you think?
Best,
Han
Re: a short reference of the time zone abbreviation in CONFIG_SITE_ENV Andrew Johnson
Prev: Jenkins build is back to normal : epics-base-3.16-win64s #169 APS Jenkins
Next: Re: a short reference of the time zone abbreviation in CONFIG_SITE_ENV Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
