2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Adding userTag to epicsTimeStamp
To: EPICS Core Talk <[email protected]>
Date: Mon, 9 Oct 2017 16:30:30 +0200
Fine!
Again: I'm not at all against enlarging this specific tag.
I do remember that with respect to new NT types we agreed that the Core Developers team would wait for changes to emerge from the community and be presented with due justification. I would assume changes to the existing types should be handled similarly.
We should not create an administrative body of its own to handle this, but proposed changes to standards should be documented and reviewed, to have an archive of why things were changed and to avoid re-discussing the same topic.
Any ideas about what would be a good forum?
Cheers,
~Ralph
On Mon, Oct 9, 2017 at 4:13 PM, Marty Kraimer <[email protected]> wrote:
On 10/09/2017 09:26 AM, Ralph Lange wrote:
I don't know.
I would expect the user tag to come from a different source than the wall clock time, and be assembled into the NT timeStamp structure.
In the NT discussion we expected 32 bits to be good enough for a user tag. More than four billion different values for a tag seem plenty.
Note also that it is defined to be a signed 32 bit value rather than unsigned.
Marty
In general, the NT types were discussed, reviewed and set over years. I would not expect to see them changed on an ad-hoc basis.
Not saying that this specific tag should not be 64 bits wide, but to change an existing approved design, I would like to see a minimum amount of justification and discussion.
Cheers,
~Ralph
On Mon, Oct 9, 2017 at 2:23 PM, Johnson, Andrew N. <[email protected]> wrote:
I just tried modifying the definition of the epicsTimeStamp object, adding an epicsUInt64 userTag member to it. Everything built without problems and the tests all passed. Then I looked through pvDataCPP and connected this to the userTag in property/timeStamp.cpp.
Any lab that wants to use this would have to set the userTag in their generalTime time provider(s).
Observations:
1. I have not added userTag to the epicsTime class, which is different to an epicsTimeStamp. C++ code tends to pass around epicsTime objects by value, and I’m reluctant to double the size of that object unnecessarily.
2. Some work would be needed to support the userTag in epicsTimeToStrftime(). There are some free conversion format characters left: %i %J %K %L %N %o %q %Q (comparing MacOS and Linux docs plus a few others inline).
3. There are few tests for userTag in pvData/testApp, not sure if any could really check what I did.
4. I used an epicsUInt64 because someone (maybe Dirk Zimoch?) asked for it to be 64 rather than 32 bits. The PVA timeStamp userTag was defined to be 32 bits, should we consider changing it to 64?
Is doing this a good idea, and if so is it the right approach?
- Andrew
Adding userTag to epicsTimeStamp Johnson, Andrew N.
Re: Adding userTag to epicsTimeStamp Ralph Lange
Re: Adding userTag to epicsTimeStamp Marty Kraimer
Prev: Re: Adding userTag to epicsTimeStamp Hill, Bruce
Next: RE: Adding userTag to epicsTimeStamp Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Adding userTag to epicsTimeStamp Marty Kraimer
