2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-sol #105
To: [email protected]
Date: Thu, 26 Oct 2017 15:11:21 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/105/display/redirect?page=changes>
Changes:
[Andrew Johnson] Add osiSockOptMcastLoop_t and osiSockTest
[Andrew Johnson] More tests, check both true and false values for options.
[Andrew Johnson] libcom/test: osiSockTest fix for RTEMS
[Andrew Johnson] Release Notes
[Andrew Johnson] Unify rsrv socket errors, add missing error string
[...truncated 280.09 KB...]
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/posix/osdMutex.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/posix/osdSpin.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/posix/osdEvent.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/posix/osdTime.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/posix/osdProcess.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/default/osdNetIntf.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
"../../../src/libCom/osi/os/default/osdMessageQueue.cpp", line 195: Warning: status hides the same name in an outer scope.
"../../../src/libCom/osi/os/default/osdMessageQueue.cpp", line 344: Warning: status hides the same name in an outer scope.
2 Warning(s) detected.
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/devLibVME.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/default/devLibVMEOSD.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/epicsStackTrace.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/solaris/osdBackTrace.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/osi/os/solaris/osdFindAddr.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/pool/poolJob.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/pool/threadPool.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/ring/epicsRingPointer.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/ring/epicsRingBytes.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/taskwd/taskwd.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/timer/epicsTimer.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/timer/timer.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/timer/timerQueue.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/timer/timerQueueActive.cpp
"../../../src/libCom/timer/timerQueueActive.cpp", line 26: Warning: Could not find source for epicsSingleton<timerQueueActiveMgr>::epicsSingleton(const epicsSingleton<timerQueueActiveMgr>&).
"../../../src/libCom/timer/timerQueueActive.cpp", line 26: Warning: Could not find source for epicsSingleton<timerQueueActiveMgr>::operator=(const epicsSingleton<timerQueueActiveMgr>&).
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/timer/timerQueueActiveMgr.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w            -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/timer/timerQueuePassive.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/yajl/yajl.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/yajl/yajl_alloc.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/yajl/yajl_buf.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/yajl/yajl_encode.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/yajl/yajl_gen.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/yajl/yajl_lex.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4               -xcode=pic32 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/yajl/yajl_parser.c
/opt/SUNWspro/bin/CC -xar -o    libCom.a        asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/opt/SUNWspro/bin/CC -o libCom.so.3.15.5 -z defs -G -h libCom.so.3.15.5 -z text -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lposix4 -lpthread    -lm -lCstd -lsocket -lnsl -lumem -lCrun -lc
Installing shared library ../../../lib/solaris-sparc/libCom.so.3.15.5
mkdir ../../../lib/solaris-sparc
ln -s libCom.so.3.15.5 ../../../lib/solaris-sparc/libCom.so
Installing library ../../../lib/solaris-sparc/libCom.a
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/solStudio -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/solaris -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/solStudio -I../../../include/os/solaris -I../../../include         -c ../../../src/libCom/log/iocLogServer.c
/opt/SUNWspro/bin/CC -o iocLogServer  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            iocLogServer.o    -lCom  -lsocket
Expanding ../../../src/libCom/log/S99logServer@ to S99logServer
Installing created executable ../../../bin/solaris-sparc/S99logServer
Installing created executable ../../../bin/solaris-sparc/iocLogServer
Installing html ../../../html/./freeList/freeList.html
mkdir ../../../html/./freeList
Installing html ../../../html/./gpHash/gpHash.html
mkdir ../../../html/./gpHash
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/O.solaris-sparc'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom'>
make -C libCom/RTEMS install.solaris-sparc
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/bin/solaris-sparc/makeMakefile.pl> O.solaris-sparc ../../../..
mkdir O.Common
make -C O.solaris-sparc -f ../Makefile TOP=../../../.. \
    T_A=solaris-sparc install
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS/O.solaris-sparc'>
Installing generic include file ../../../../include/epicsRtemsInitHooks.h
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS/O.solaris-sparc'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/RTEMS'>
make -C libCom/test install.solaris-sparc
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test'>
mkdir O.Common
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test/O.solaris-sparc'>
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > cvtFastPerform.d  ../cvtFastPerform.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsAtomicPerform.d  ../epicsAtomicPerform.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > buckTest.d  ../buckTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsMaxThreads.d  ../epicsMaxThreads.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsThreadPerform.d  ../epicsThreadPerform.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > osiSockTest.d  ../osiSockTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > ipAddrToAsciiTest.d  ../ipAddrToAsciiTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsStackTraceTest.d  ../epicsStackTraceTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsMessageQueueTest.d  ../epicsMessageQueueTest.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > blockingSockTest.d  ../blockingSockTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > taskwdTest.d  ../taskwdTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > macLibTest.d  ../macLibTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > macDefExpandTest.d  ../macDefExpandTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsAtomicTest.d  ../epicsAtomicTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsSpinTest.d  ../epicsSpinTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsMutexTest.d  ../epicsMutexTest.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsEventTest.d  ../epicsEventTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > ringBytesTest.d  ../ringBytesTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > ringPointerTest.d  ../ringPointerTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsTimerTest.d  ../epicsTimerTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsExitTest.d  ../epicsExitTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsThreadPoolTest.d  ../epicsThreadPoolTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsThreadHooksTest.d  ../epicsThreadHooksTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsThreadPrivateTest.d  ../epicsThreadPrivateTest.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsThreadPriorityTest.d  ../epicsThreadPriorityTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsThreadOnceTest.d  ../epicsThreadOnceTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsThreadTest.d  ../epicsThreadTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsTimeZoneTest.d  ../epicsTimeZoneTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsTimeTest.d  ../epicsTimeTest.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsStringTest.d  ../epicsStringTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsSockResolveTest.d  ../epicsSockResolveTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsStdlibTest.d  ../epicsStdlibTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsStdioTest.d  ../epicsStdioTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsErrlogTest.d  ../epicsErrlogTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsEnvTest.d  ../epicsEnvTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsEllTest.d  ../epicsEllTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsMMIOTest.d  ../epicsMMIOTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsMathTest.d  ../epicsMathTest.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsAlgorithmTest.d  ../epicsAlgorithmTest.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsCalcTest.d  ../epicsCalcTest.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsInlineTest4.d  ../epicsInlineTest4.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsInlineTest3.d  ../epicsInlineTest3.cpp
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsInlineTest2.d  ../epicsInlineTest2.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsInlineTest1.d  ../epicsInlineTest1.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsTypesTest.d  ../epicsTypesTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -xM1 > epicsUnitTestTest.d  ../epicsUnitTestTest.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsUnitTestTest.c
/opt/SUNWspro/bin/CC -o epicsUnitTestTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsUnitTestTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsTypesTest.c
/opt/SUNWspro/bin/CC -o epicsTypesTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsTypesTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsInlineTest1.c
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsInlineTest2.c
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsInlineTest3.cpp
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsInlineTest4.cpp
/opt/SUNWspro/bin/CC -o epicsInlineTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsInlineTest1.o epicsInlineTest2.o epicsInlineTest3.o epicsInlineTest4.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsCalcTest.cpp
/opt/SUNWspro/bin/CC -o epicsCalcTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsCalcTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsAlgorithmTest.cpp
/opt/SUNWspro/bin/CC -o epicsAlgorithmTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsAlgorithmTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsMathTest.c
/opt/SUNWspro/bin/CC -o epicsMathTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsMathTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsMMIOTest.c
/opt/SUNWspro/bin/CC -o epicsMMIOTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsMMIOTest.o    -lCom  -lsocket
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsEllTest.c
/opt/SUNWspro/bin/CC -o epicsEllTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsEllTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsEnvTest.c
/opt/SUNWspro/bin/CC -o epicsEnvTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsEnvTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsErrlogTest.c
/opt/SUNWspro/bin/CC -o epicsErrlogTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsErrlogTest.o    -lCom  -lsocket
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsStdioTest.c
/opt/SUNWspro/bin/CC -o epicsStdioTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsStdioTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsStdlibTest.c
/opt/SUNWspro/bin/CC -o epicsStdlibTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsStdlibTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsSockResolveTest.c
/opt/SUNWspro/bin/CC -o epicsSockResolveTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsSockResolveTest.o    -lCom  -lsocket
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsStringTest.c
/opt/SUNWspro/bin/CC -o epicsStringTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsStringTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsTimeTest.cpp
/opt/SUNWspro/bin/CC -o epicsTimeTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsTimeTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsTimeZoneTest.c
/opt/SUNWspro/bin/CC -o epicsTimeZoneTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsTimeZoneTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsThreadTest.cpp
/opt/SUNWspro/bin/CC -o epicsThreadTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsThreadTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsThreadOnceTest.c
/opt/SUNWspro/bin/CC -o epicsThreadOnceTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsThreadOnceTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsThreadPriorityTest.cpp
/opt/SUNWspro/bin/CC -o epicsThreadPriorityTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsThreadPriorityTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsThreadPrivateTest.cpp
/opt/SUNWspro/bin/CC -o epicsThreadPrivateTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsThreadPrivateTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsThreadHooksTest.c
/opt/SUNWspro/bin/CC -o epicsThreadHooksTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsThreadHooksTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsThreadPoolTest.c
/opt/SUNWspro/bin/CC -o epicsThreadPoolTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsThreadPoolTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsExitTest.c
/opt/SUNWspro/bin/CC -o epicsExitTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsExitTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsTimerTest.cpp
/opt/SUNWspro/bin/CC -o epicsTimerTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsTimerTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../ringPointerTest.c
/opt/SUNWspro/bin/CC -o ringPointerTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            ringPointerTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../ringBytesTest.c
/opt/SUNWspro/bin/CC -o ringBytesTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            ringBytesTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsEventTest.cpp
/opt/SUNWspro/bin/CC -o epicsEventTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsEventTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsMutexTest.cpp
/opt/SUNWspro/bin/CC -o epicsMutexTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsMutexTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsSpinTest.c
/opt/SUNWspro/bin/CC -o epicsSpinTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsSpinTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsAtomicTest.cpp
"../epicsAtomicTest.cpp", line 141: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 239:     Where: While instantiating "testIncrDecr<int>()".
"../epicsAtomicTest.cpp", line 239:     Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 143: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 240:     Where: While instantiating "testIncrDecr<unsigned>()".
"../epicsAtomicTest.cpp", line 240:     Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 173: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 241:     Where: While instantiating "testAddSub<int>()".
"../epicsAtomicTest.cpp", line 241:     Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 175: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 242:     Where: While instantiating "testAddSub<unsigned>()".
"../epicsAtomicTest.cpp", line 242:     Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 208: Warning (Anachronism): Formal argument funptr of type extern "C" void(*)(void*) in call to epicsThreadCreate(const char*, unsigned, unsigned, extern "C" void(*)(void*), void*) is being passed void(*)(void*).
"../epicsAtomicTest.cpp", line 243:     Where: While instantiating "testCAS<int>()".
"../epicsAtomicTest.cpp", line 243:     Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 244:     Where: While instantiating "testCAS<unsigned>()".
"../epicsAtomicTest.cpp", line 244:     Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 245:     Where: While instantiating "testCAS<void*>()".
"../epicsAtomicTest.cpp", line 245:     Where: Instantiated from non-template code.
"../epicsAtomicTest.cpp", line 51: Warning: Could not find source for TestDataAddSub<int>::delta.
"../epicsAtomicTest.cpp", line 51: Warning: Could not find source for TestDataAddSub<unsigned>::delta.
13 Warning(s) detected.
/opt/SUNWspro/bin/CC -o epicsAtomicTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsAtomicTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../macDefExpandTest.c
/opt/SUNWspro/bin/CC -o macDefExpandTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            macDefExpandTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../macLibTest.c
/opt/SUNWspro/bin/CC -o macLibTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            macLibTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../taskwdTest.c
/opt/SUNWspro/bin/CC -o taskwdTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            taskwdTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../blockingSockTest.cpp
/opt/SUNWspro/bin/CC -o blockingSockTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            blockingSockTest.o    -lCom  -lsocket
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsMessageQueueTest.cpp
/opt/SUNWspro/bin/CC -o epicsMessageQueueTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsMessageQueueTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../epicsStackTraceTest.c
/opt/SUNWspro/bin/CC -o epicsStackTraceTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            epicsStackTraceTest.o    -lCom
/opt/SUNWspro/bin/CC               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__   -O   +w             -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../ipAddrToAsciiTest.cpp
/opt/SUNWspro/bin/CC -o ipAddrToAsciiTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            ipAddrToAsciiTest.o    -lCom
/opt/SUNWspro/bin/cc               -DUNIX  -DSOLARIS=10 -mt  -D__EXTENSIONS__  -xc99 -D_POSIX_C_SOURCE=200112L -xO4                -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/solStudio -I../../../../include/os/solaris -I../../../../include         -c ../osiSockTest.c
/opt/SUNWspro/bin/CC -o osiSockTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc> -R<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/lib/solaris-sparc>           -mt  -z ignore -z combreloc -z lazyload            osiSockTest.o    -lCom
Undefined			first referenced
 symbol  			    in file
__xnet_getsockopt                   osiSockTest.o  (symbol belongs to implicit dependency /lib/libsocket.so.1)
setsockopt                          osiSockTest.o  (symbol belongs to implicit dependency /lib/libsocket.so.1)
ld: fatal: symbol referencing errors. No output written to osiSockTest
../../../../configure/RULES_BUILD:201: recipe for target 'osiSockTest' failed
make[3]: *** [osiSockTest] Error 1
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test/O.solaris-sparc'>
../../../configure/RULES_ARCHS:58: recipe for target 'install.solaris-sparc' failed
make[2]: *** [install.solaris-sparc] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src/libCom/test'>
../configure/RULES_DIRS:84: recipe for target 'libCom/test.install.solaris-sparc' failed
make[1]: *** [libCom/test.install.solaris-sparc] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/src'>
configure/RULES_DIRS:84: recipe for target 'src.install.solaris-sparc' failed
make: *** [src.install.solaris-sparc] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.15-sol #106 APS Jenkins
Prev: Re: pva2pva build on APS Jenkins Michael Davidsaver
Next: Jenkins build is back to normal : epics-base-3.15-test #33 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Jenkins build is back to normal : epics-base-3.15-sol #106 APS Jenkins
