2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Base.t missing (mis-merge?)
To: Andrew Johnson <[email protected]>, Ralph Lange <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Wed, 1 Nov 2017 11:04:13 -0500
FYI, the new branched build of core/master
https://travis-ci.org/epics-base/epics-base/branches
has been failing since
https://github.com/epics-base/epics-base/commit/269e93d284e0a00446767f8718271d057a745579
Which added a test Base.t in test/tools/Makefile while the test code
went into src/tools/test/Base.plt which looks like a mis-merge.
I naively tried to move Base.plt to test/tools/ but this wasn't enough.
> Can't locate DBD/Base.pm in @INC (you may need to install the DBD::Base module) (@INC contains: ../.. /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.24.1 /usr/local/share/perl/5.24.1 /usr/lib/x86_64-linux-gnu/perl5/5.24 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.24 /usr/share/perl/5.24 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at Base.t line 7.
> BEGIN failed--compilation aborted at Base.t line 7.
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Base.t missing (mis-merge?) Andrew Johnson
Prev: Re: pvDataCPP and yajl-2.1.0 Michael Davidsaver
Next: Re: Base.t missing (mis-merge?) Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
