2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: exporting module versions
To: <[email protected]>
Date: Thu, 2 Nov 2017 13:42:47 +0100
On 02.11.2017 11:18, Ralph Lange wrote:
Hi Dirk,
On Thu, Nov 2, 2017 at 10:23 AM, Dirk Zimoch <[email protected]
<mailto:[email protected]>> wrote:
    [...]  I also opt for binary backward compatibility, so that it is
    always possible to replace a dynamic library with a newer version
    without needing to re-build all programs. Forcing a program to link
    only with a very specific library version is, in my opinion, not
    very maintenance friendly.
As you seem to have experience with that: which tools / methodology do
you suggest to detect and track ABI changes in libraries, especially
libraries created from C++ sources?
~Ralph
I don't know any tools to support compatibility checks, but here is what I try to do:
* Never remove API functions (declaring them depreciated is OK)
* Never change the signature of an existing (extern C) function (...in an incompatible way. Signedness change is often OK. Adding const or volatile where appropriate is also often OK. Changing 32 bit args (like int) to potentially 64 bit args (e.g. size_t) is only OK if no 64 bit was supported previously, but that is already ancient history.) * Never change the semantics of an existing function (e.g. swap src and dest parameters in some copy function) * Never remove, re-order, or change size of the fields of a structure that is used in an API. * Add new fields only ever at the end of structure passed to API functions by reference (and then handle cases gracefully where the fields don't exist). * Never remove or re-order virtual methods (the same for non-C++ function tables like in asyn). * Expose as little as possible in the API. Not all functions are API functions, not all structures/classes are used in the API. Not all Macros are part of the API. Keep public and private header files separate. Do not install private headers. This allows to change any non API function, class, etc. at any time without breaking the API. * Do not put private fields/methods in API classes. If private members are needed, inherit from a API base class without private members. APIs are not private.
As it is often not feasible to be so strictly backward compatible, I suggest (any use in my software) the following rules:
* A version consists of 3 numbers: major.minor.patch
* Whenever a change is not binary backward compatible, the major number increases.
* Whenever there are new features, the minor number increases.
* Whenever a bug is fixed without a new feature, the patch number increases. (A bugfix may be incompatible in so far that the incompatibility was the actual bug that has been fixed.) * In linking use the major number in the file name to ensure no incompatible version can be used. * Do not use the minor number or patch number in linking in order to allow upgrading the library.
See also how Linux (or GNU) does it: /bin/bash on my computer is linked to libtinfo.so.5 which is a symbolic link to libtinfo.so.5.7. Note that is is not linked to version 5.7 but only to version 5. This allows to upgrade the library to 5.8 but not to 6.0 without having to rebuild the executable.
Or: softIoc on my computer is linked to libstdc++.so.6 which is a symbolic link to libstdc++.so.6.0.13.
I have no idea how to automatically check for backward compatibility when releasing a new version. I can imagine checking function and structure/class signatures automatically. But how to check for semantic changes?
Dirk
Re: exporting module versions Mark Rivers
RE: exporting module versions Mark Rivers
exporting module versions Michael Davidsaver
Re: exporting module versions Andrew Johnson
Re: exporting module versions Dirk Zimoch
Re: exporting module versions Ralph Lange
Prev: Re: exporting module versions Ralph Lange
Next: Re: exporting module versions Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
