2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-core » mac #12
To: [email protected]
Date: Tue, 7 Nov 2017 21:40:59 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/12/display/redirect?page=changes>
Changes:
[Andrew Johnson] Make rsrv register itself using a DBD file
[Andrew Johnson] Add EPICS_IOC_IGNORE_SERVERS environment variable
[Andrew Johnson] Added Doxygen comments for dbServer API
[Andrew Johnson] Added some dbServer unit tests
[Andrew Johnson] Set test plan
[Andrew Johnson] Test EPICS_IOC_IGNORE_SERVERS variable
[Andrew Johnson] Release Notes entry
[Andrew Johnson] Add explicit "no servers" message to dbsr()
[Andrew Johnson] dbRegisterServer: Don't ignore sub-string names
[Andrew Johnson] Fix check for double-registration, add test
[Andrew Johnson] Give dbRegisterServer a return value (0/-1)
[Michael Davidsaver] libCom/osi: fetch monotonic time
[Michael Davidsaver] move EPICS_EXPOSE_LIBCOM_MONOTONIC_PRIVATE before all local includes
[Michael Davidsaver] monotonic: fix osx
[Michael Davidsaver] db/test: dbStressTest use monotonic
[Michael Davidsaver] rsrv: epicsExport.h is last import
[Ralph Lange] dbstatic: allow initial value of 65535 for MENU fields
[Ralph Lange] db: add utility functions for simulation mode
[Ralph Lange] rec: improve and streamline simulation mode
[Ralph Lange] rec: add tests for simulation mode
[Ralph Lange] doc: add simulation mode changes to release notes
[Andrew Johnson] Added call to dbStopServers() in iocShutdown()
[Andrew Johnson] Ignore dbServer registrations after init
[Andrew Johnson] Added dbUnregisterServer() routine, plus tests
[Andrew Johnson] Can't dbUnregisterServer() if stopped & no stop() method
[Andrew Johnson] Clarify release entry wording
[Andrew Johnson] Delete unused variable
[Andrew Johnson] Initial VxWorks support code
[Andrew Johnson] dbServer: Only call client() and report() methods when running
[Andrew Johnson] VxWorks osdMonotonic implementation
[Andrew Johnson] rsrv: Fix include list for Windows builds
[Andrew Johnson] Restore dbVerify() to dbStaticLib
[Andrew Johnson] Update PVA modules
[...truncated 940.19 KB...]
make[3]: Nothing to be done for `all'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.ios-arm -f ../Makefile TOP=../../.. T_A=ios-arm
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./modules ios-arm
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./libcom ios-arm
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./configure ios-arm
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/convertRelease.pl> checkRelease
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.ios-arm -f ../Makefile TOP=../.. T_A=ios-arm
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./src ios-arm
make[4]: Nothing to be done for `all'.
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m yajl_parser.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        yajl_parser.o ../../src/yajl/yajl_parser.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m yajl_lex.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        yajl_lex.o ../../src/yajl/yajl_lex.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m yajl_gen.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        yajl_gen.o ../../src/yajl/yajl_gen.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m yajl_encode.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        yajl_encode.o ../../src/yajl/yajl_encode.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m yajl_buf.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        yajl_buf.o ../../src/yajl/yajl_buf.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m yajl_alloc.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        yajl_alloc.o ../../src/yajl/yajl_alloc.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m yajl.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        yajl.o ../../src/yajl/yajl.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m timerQueuePassive.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        timerQueuePassive.o ../../src/timer/timerQueuePassive.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        timerQueueActiveMgr.o ../../src/timer/timerQueueActiveMgr.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m timerQueueActive.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        timerQueueActive.o ../../src/timer/timerQueueActive.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m timerQueue.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        timerQueue.o ../../src/timer/timerQueue.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m timer.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        timer.o ../../src/timer/timer.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsTimer.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsTimer.o ../../src/timer/epicsTimer.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m taskwd.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        taskwd.o ../../src/taskwd/taskwd.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsRingBytes.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsRingBytes.o ../../src/ring/epicsRingBytes.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsRingPointer.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsRingPointer.o ../../src/ring/epicsRingPointer.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m threadPool.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        threadPool.o ../../src/pool/threadPool.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m poolJob.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        poolJob.o ../../src/pool/poolJob.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdFindAddr.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdFindAddr.o ../../src/osi/os/default/osdFindAddr.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdBackTrace.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdBackTrace.o ../../src/osi/os/default/osdBackTrace.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsStackTrace.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsStackTrace.o ../../src/osi/epicsStackTrace.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m devLibVMEOSD.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        devLibVMEOSD.o ../../src/osi/os/default/devLibVMEOSD.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m devLibVME.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        devLibVME.o ../../src/osi/devLibVME.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdMessageQueue.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdMessageQueue.o ../../src/osi/os/default/osdMessageQueue.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdNetIntf.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdNetIntf.o ../../src/osi/os/default/osdNetIntf.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdProcess.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdProcess.o ../../src/osi/os/posix/osdProcess.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdMonotonic.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdMonotonic.o ../../src/osi/os/iOS/osdMonotonic.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdTime.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdTime.o ../../src/osi/os/posix/osdTime.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdEvent.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdEvent.o ../../src/osi/os/posix/osdEvent.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdSpin.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdSpin.o ../../src/osi/os/posix/osdSpin.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdMutex.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdMutex.o ../../src/osi/os/posix/osdMutex.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdThreadHooks.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdThreadHooks.o ../../src/osi/os/default/osdThreadHooks.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdThreadExtra.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdThreadExtra.o ../../src/osi/os/posix/osdThreadExtra.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdThread.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdThread.o ../../src/osi/os/posix/osdThread.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdStdio.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdStdio.o ../../src/osi/os/posix/osdStdio.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsStdio.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsStdio.o ../../src/osi/epicsStdio.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsTempFile.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsTempFile.o ../../src/osi/os/posix/epicsTempFile.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsReadline.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsReadline.o ../../src/osi/epicsReadline.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdEnv.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdEnv.o ../../src/osi/os/iOS/osdEnv.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdSignal.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdSignal.o ../../src/osi/os/posix/osdSignal.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdPoolStatus.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdPoolStatus.o ../../src/osi/os/default/osdPoolStatus.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdInterrupt.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdInterrupt.o ../../src/osi/os/default/osdInterrupt.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdFindSymbol.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdFindSymbol.o ../../src/osi/os/posix/osdFindSymbol.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdAssert.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdAssert.o ../../src/osi/os/default/osdAssert.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsSocketConvertErrnoToString.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsSocketConvertErrnoToString.o ../../src/osi/os/default/epicsSocketConvertErrnoToString.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m systemCallIntMech.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        systemCallIntMech.o ../../src/osi/os/posix/systemCallIntMech.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osiSock.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osiSock.o ../../src/osi/osiSock.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdSockAddrReuse.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdSockAddrReuse.o ../../src/osi/os/iOS/osdSockAddrReuse.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osdSock.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osdSock.o ../../src/osi/os/posix/osdSock.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m osiClockTime.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        osiClockTime.o ../../src/osi/osiClockTime.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsGeneralTime.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsGeneralTime.o ../../src/osi/epicsGeneralTime.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsAtomicOSD.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsAtomicOSD.o ../../src/osi/os/posix/epicsAtomicOSD.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsMath.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsMath.o ../../src/osi/epicsMath.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsMessageQueue.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsMessageQueue.o ../../src/osi/epicsMessageQueue.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsTime.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsTime.o ../../src/osi/epicsTime.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsEvent.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsEvent.o ../../src/osi/epicsEvent.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsMutex.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsMutex.o ../../src/osi/epicsMutex.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsThread.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsThread.o ../../src/osi/epicsThread.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsUnitTest.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsUnitTest.o ../../src/misc/epicsUnitTest.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        ipAddrToAsciiAsynchronous.o ../../src/misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m truncateFile.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        truncateFile.o ../../src/misc/truncateFile.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsString.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsString.o ../../src/misc/epicsString.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsStdlib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsStdlib.o ../../src/misc/epicsStdlib.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsExit.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsExit.o ../../src/misc/epicsExit.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsConvert.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsConvert.o ../../src/misc/epicsConvert.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m cantProceed.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        cantProceed.o ../../src/misc/cantProceed.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m adjustment.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        adjustment.o ../../src/misc/adjustment.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m aToIPAddr.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        aToIPAddr.o ../../src/misc/aToIPAddr.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m alarmString.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        alarmString.o ../../src/misc/alarmString.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m macUtil.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        macUtil.o ../../src/macLib/macUtil.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m macEnv.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        macEnv.o ../../src/macLib/macEnv.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m macCore.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        macCore.o ../../src/macLib/macCore.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m logClient.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        logClient.o ../../src/log/logClient.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m iocLog.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        iocLog.o ../../src/log/iocLog.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m libComRegister.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        libComRegister.o ../../src/iocsh/libComRegister.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m registry.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        registry.o ../../src/iocsh/registry.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m iocsh.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        iocsh.o ../../src/iocsh/iocsh.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m gpHashLib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        gpHashLib.o ../../src/gpHash/gpHashLib.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m freeListLib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        freeListLib.o ../../src/freeList/freeListLib.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m fdManager.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        fdManager.o ../../src/fdmgr/fdManager.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m fdmgr.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        fdmgr.o ../../src/fdmgr/fdmgr.cpp
perl -CSD ../../src/error/makeStatTbl.pl  ../../src/osi/devLib.h ../../src/osi/epicsTime.h ../../src/as/asLib.h ../../src/misc/epicsStdlib.h ../../src/pool/epicsThreadPool.h ../../src/error/errMdef.h
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m errSymTbl.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        errSymTbl.o errSymTbl.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m errSymLib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        errSymLib.o ../../src/error/errSymLib.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m errlog.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        errlog.o ../../src/error/errlog.c
perl -CSD ../../src/env/bldEnvData.pl  -t ios-arm \
		-c clang -s iOS ../../../../configure
Generating envData.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m envData.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        envData.o envData.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m envSubr.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        envSubr.o ../../src/env/envSubr.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m ellSort.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        ellSort.o ../../src/ellLib/ellSort.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m ellLib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        ellLib.o ../../src/ellLib/ellLib.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m dbmf.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        dbmf.o ../../src/dbmf/dbmf.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m epicsSingletonMutex.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        epicsSingletonMutex.o ../../src/cxxTemplates/epicsSingletonMutex.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m resourceLib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        resourceLib.o ../../src/cxxTemplates/resourceLib.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m cvtFast.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        cvtFast.o ../../src/cvtFast/cvtFast.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m calcPerform.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        calcPerform.o ../../src/calc/calcPerform.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m postfix.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        postfix.o ../../src/calc/postfix.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m bucketLib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        bucketLib.o ../../src/bucketLib/bucketLib.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m asTrapWrite.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        asTrapWrite.o ../../src/as/asTrapWrite.c
<https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/e_flex> -S../../../../include/flex.skel.static -8 -I -t ../../src/as/asLib_lex.l > asLib_lex.yy.c
mv asLib_lex.yy.c asLib_lex.c
<https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/antelope> -basLib  ../../src/as/asLib.y
mv asLib.tab.c asLib.c
perl -CSD <https://jenkins.aps.anl.gov/job/epics-core/OS=mac/ws/bin/darwin-x86/mkmf.pl>  -m asLib.d -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang  -I../../../../include        asLib.o asLib.c
Installing generic include file ../../../../include/os/iOS/osiFileName.h
mkdir ../../../../include/os/iOS
Installing generic include file ../../../../include/os/iOS/osdSock.h
Installing OS dependent include file ../../../../include/os/iOS/osdInterrupt.h
Installing OS dependent include file ../../../../include/os/iOS/osdMutex.h
Installing OS dependent include file ../../../../include/os/iOS/osdEvent.h
Installing generic include file ../../../../include/os/iOS/epicsMath.h
Installing OS dependent include file ../../../../include/os/iOS/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/iOS/osdStrtod.h
Installing OS dependent include file ../../../../include/os/iOS/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/iOS/osdThread.h
Installing generic include file ../../../../include/os/iOS/osdTime.h
Installing OS dependent include file ../../../../include/os/iOS/osiUnistd.h
Installing OS dependent include file ../../../../include/os/iOS/osdWireFormat.h
Installing OS dependent include file ../../../../include/os/iOS/osdWireConfig.h
Installing OS dependent include file ../../../../include/os/iOS/epicsAtomicOSD.h
Installing OS dependent include file ../../../../include/os/iOS/epicsGetopt.h
Installing OS dependent include file ../../../../include/os/iOS/osdVME.h
Installing OS dependent include file ../../../../include/os/iOS/epicsMMIO.h
Installing OS dependent include file ../../../../include/os/iOS/epicsMMIODef.h
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c asLib.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/as/asTrapWrite.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/bucketLib/bucketLib.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/calc/postfix.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/calc/calcPerform.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/cvtFast/cvtFast.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/cxxTemplates/resourceLib.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/cxxTemplates/epicsSingletonMutex.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/dbmf/dbmf.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/ellLib/ellLib.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/ellLib/ellSort.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/env/envSubr.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c envData.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/error/errlog.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/error/errSymLib.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c errSymTbl.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/fdmgr/fdmgr.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/fdmgr/fdManager.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/freeList/freeListLib.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/gpHash/gpHashLib.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/iocsh/iocsh.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/iocsh/registry.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/iocsh/libComRegister.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/log/iocLog.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/log/logClient.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/macLib/macCore.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/macLib/macEnv.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/macLib/macUtil.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/alarmString.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/aToIPAddr.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/adjustment.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/cantProceed.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/epicsConvert.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/epicsExit.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/epicsStdlib.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/epicsString.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/truncateFile.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/ipAddrToAsciiAsynchronous.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/misc/epicsUnitTest.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsThread.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsMutex.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsEvent.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsTime.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsMessageQueue.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsMath.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/epicsAtomicOSD.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsGeneralTime.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/osiClockTime.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdSock.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/iOS/osdSockAddrReuse.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/osiSock.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/systemCallIntMech.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/default/epicsSocketConvertErrnoToString.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/default/osdAssert.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdFindSymbol.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/default/osdInterrupt.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/default/osdPoolStatus.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdSignal.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/iOS/osdEnv.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS    -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsReadline.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/epicsTempFile.cpp
../../src/osi/os/posix/epicsTempFile.cpp:23:14: warning: 'tmpnam' is deprecated: This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of tmpnam(3), it is highly recommended that you use mkstemp(3) instead. [-Wdeprecated-declarations]
        if ( tmpnam ( nameBuf ) ) {
/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk/usr/include/stdio.h:276:7: note: 'tmpnam' has been explicitly marked deprecated here
char    *tmpnam(char *);
1 warning generated.
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/epicsStdio.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdStdio.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdThread.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdThreadExtra.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/default/osdThreadHooks.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdMutex.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdSpin.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdEvent.c
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/posix/osdTime.cpp
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang              -DUNIX      -O3 -g   -Wall       -arch armv7 -arch armv7s -arch arm64 -fno-common -Wno-unused-value   -fno-inline-functions -miphoneos-version-min=8.0 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS.sdk -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/clang -I../../src/osi/compiler/default -I. -I../../src/osi/os/iOS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include -I../../../../include/compiler/clang -I../../../../include/os/iOS -I../../../../include        -c ../../src/osi/os/iOS/osdMonotonic.c
../../src/osi/os/iOS/osdMonotonic.c:29:5: warning: implicit declaration of function 'absolutetime_to_nanoseconds' is invalid in C99 [-Wimplicit-function-declaration]
    absolutetime_to_nanoseconds(val, &ret);
../../src/osi/os/iOS/osdMonotonic.c:29:5: error: implicit declaration of function 'absolutetime_to_nanoseconds' is invalid in C99 [-Werror,-Wimplicit-function-declaration]
1 error generated.
make[4]: *** [osdMonotonic.o] Error 1
make[3]: *** [ios-arm] Error 2
make[2]: *** [src.ios-arm] Error 2
make[1]: *** [libcom.ios-arm] Error 2
make: *** [modules.ios-arm] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-core » mac #13 APS Jenkins
Prev: Re: Base status Michael Davidsaver
Next: Jenkins build is back to normal : epics-core » mac #13 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-core » linux64 #10 APS Jenkins
