2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: script to make release tar
To: Andrew Johnson <[email protected]>, Ralph Lange <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Tue, 14 Nov 2017 14:08:54 -0600
As discuss this morning, I've added a script 'make-tar.sh' (under .ci/
for lack a better place) which creates a tar file which includes git
submodules.  Usage is:
./.ci/make-tar.sh HEAD epics-blah.tar.gz blah/
Where 'HEAD' can be any revision id, branch, or tag name.
'epics-blah.tar.gz' is the output file name.
'blah/' is a directory prefix added to all files.
This script uses git-archive under the hood, so it won't be effected by
uncommitted changes or other debris in your checkout.  This also means
it respects .gitattributes (eg. export-ignore, export-subst, filter, etc.).
This script has a set of regexs to detect and exclude undesirable files.
 The idea being that export-ignore in .gitattributes is the preferred
mechanism to prevent inclusion in release tars.  This script will then
ignore and warn about common files which should be excluded but aren't.
Also, this script uses 'tar -a' so the compression algorithm is
determined by the file name.  So '.tar.bz2' or '.tar.xz' works as well.
I mention this as a quick test shows:
> $ ll base.tar*
> -rw-r--r-- 1 mdavidsaver mdavidsaver 105M Nov 14 14:05 base.tar
> -rw-r--r-- 1 mdavidsaver mdavidsaver  13M Nov 14 14:06 base.tar.bz2
> -rw-r--r-- 1 mdavidsaver mdavidsaver  18M Nov 14 14:06 base.tar.gz
> -rw-r--r-- 1 mdavidsaver mdavidsaver 6.4M Nov 14 14:06 base.tar.xz
https://github.com/epics-base/epics-base/commit/a1f633fe27f64e36f916a5bd8a779b6936f14c12
Attachment: signature.asc
Description: OpenPGP digital signature
Prev: Re: Travis Builds of Base Johnson, Andrew N.
Next: Build failed in Jenkins: epics-master-windows » DLL,win32 #4 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
