2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-master-windows » STATIC,win32 #4
To: [email protected]
Date: Wed, 15 Nov 2017 02:43:53 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/4/display/redirect?page=changes>
Changes:
[Andrew Johnson] Submodule build configuration fixes
[Andrew Johnson] Adjust pvAccess dependencies
[Andrew Johnson] Submodule updates
[Andrew Johnson] Move tool configs into module cfg/CONFIG* files
Started by upstream project "epics-master-windows" build number 4
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/>
 > C:/Program Files (x86)/Git/bin/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files (x86)/Git/bin/git.exe config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > C:/Program Files (x86)/Git/bin/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files (x86)/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
Checking out Revision b690e5abbdff891e3ae892b88443160e174fac78 (refs/remotes/origin/core/master)
Commit message: "Move tool configs into module cfg/CONFIG* files"
 > C:/Program Files (x86)/Git/bin/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe checkout -f b690e5abbdff891e3ae892b88443160e174fac78
 > C:/Program Files (x86)/Git/bin/git.exe rev-list 7b71cbee7a346f1ac9743d41a9d9c4e182d844ee # timeout=10
Cleaning workspace
 > C:/Program Files (x86)/Git/bin/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files (x86)/Git/bin/git.exe reset --hard # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe clean -fdx # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule foreach --recursive git reset --hard # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule foreach git clean -fdx # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe remote # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule init # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule sync # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config --get remote.origin.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get-regexp ^submodule\.(.*)\.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/libcom.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/libcom.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/libcom
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/database.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/database.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/database
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/ca.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/ca.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/ca
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/pvData.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/pvData
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/pvAccess.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/pvAccess
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/normativeTypes.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/normativeTypes
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/pvaClient.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/pvaClient
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/pvDatabase.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/pvDatabase
 > C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/pva2pva.url # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/pva2pva
[win32] $ cmd /c call C:\Users\jenkins\hudson6400248784488474607.bat
C:\jenkins\win32-1\workspace\epics-master-windows\LIBRARIES\STATIC\OS\win32>if "STATIC" == "STATIC" set EPICS_HOST_ARCH=win32-x86-static
C:\jenkins\win32-1\workspace\epics-master-windows\LIBRARIES\STATIC\OS\win32>make -O -j4
make -C ./configure install
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/configure'>
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86-static ../..
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/configure'>
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86-static -f ../Makefile TOP=../.. \
    T_A=win32-x86-static install
make[2]: Nothing to be done for 'install'.
make -C ./src install
make -C ./tools install
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/tools'>
perl -CSD ../../src/tools/makeMakefile.pl O.win32-x86-static ../../..
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/tools'>
make -C O.win32-x86-static -f ../Makefile TOP=../../.. \
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/tools/O.win32-x86-static'>
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/tools/O.win32-x86-static'>
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
mkdir ../../../bin
mkdir ../../../bin/win32-x86-static
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
mkdir ../../../lib/pkgconfig
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
mkdir ../../../html/./EPICS
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-win32-x86-static.pc"
make -C template/base install
make -C template/ext install
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/base'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/bin/win32-x86-static/makeMakefile.pl> O.win32-x86-static ../../../..
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/base'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/ext'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/ext'>
make -C O.win32-x86-static -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/base/O.win32-x86-static'>
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
mkdir ../../../../templates/makeBaseApp/top/configure
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/base/O.win32-x86-static'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/ext/O.win32-x86-static'>
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/src/template/ext/O.win32-x86-static'>
mkdir ../../../../templates/makeBaseExt/top/configure
mkdir ../../../../templates/makeBaseApp/top/supportApp
mkdir ../../../../templates/makeBaseApp/top/supportApp/Db
mkdir ../../../../templates/makeBaseApp/top/supportApp/src
mkdir ../../../../templates/makeBaseExt/top/configure/os
mkdir ../../../../templates/makeBaseExt/top/src
mkdir ../../../../templates/makeBaseExt/top/exampleExt
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make -C ./test install
make -C ./modules install
make -C ./libcom install
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/modules/libcom'>
configure/CONFIG:19: /configure/CONFIG: No such file or directory
configure/RULES_TOP:2: /configure/RULES_TOP: No such file or directory
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/modules/libcom'>
make[2]: *** No rule to make target '/configure/RULES_TOP'.  Stop.
../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
make[1]: *** [libcom.install] Error 2
configure/RULES_DIRS:84: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
make: *** Waiting for unfinished jobs....
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/test/tools'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/test/tools'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/test/tools/O.win32-x86-static'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/bin/win32-x86-static/expandVars.pl> -t ../../.. -a win32-x86-static ../Snippets.plt Snippets.t
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/test/tools/O.win32-x86-static'>
C:\jenkins\win32-1\workspace\epics-master-windows\LIBRARIES\STATIC\OS\win32>make -s -j4 tapfiles   || true
../configure/RULES_DIRS:84: recipe for target 'libcom.tapfiles' failed
make[1]: *** [libcom.tapfiles] Error 2
configure/RULES_DIRS:84: recipe for target 'modules.tapfiles' failed
make: *** [modules.tapfiles] Error 2
'true' is not recognized as an internal or external command,
operable program or batch file.
C:\jenkins\win32-1\workspace\epics-master-windows\LIBRARIES\STATIC\OS\win32>make -s test-results   || true
Snippets.tap .. ok
All tests successful.
Files=1, Tests=29,  0 wallclock secs ( 0.06 usr +  0.03 sys =  0.09 CPU)
Result: PASS
../configure/RULES_DIRS:84: recipe for target 'libcom.test-results' failed
make[1]: *** [libcom.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'modules.test-results' failed
make: *** [modules.test-results] Error 2
C:\jenkins\win32-1\workspace\epics-master-windows\LIBRARIES\STATIC\OS\win32>exit 9009
Build step 'Execute Windows batch command' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-master-windows » STATIC,win32 #5 APS Jenkins
Prev: Build failed in Jenkins: epics-master-windows » STATIC,win64 #4 APS Jenkins
Next: Build failed in Jenkins: epics-master-windows » DLL,win64 #4 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-master-windows » STATIC,win64 #5 APS Jenkins
Next: Jenkins build is back to normal : epics-master-windows » STATIC,win32 #5 APS Jenkins
