2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-master-windows » STATIC,win64 #8
To: [email protected]
Date: Thu, 16 Nov 2017 18:40:18 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win64/8/display/redirect>
Started by upstream project "epics-master-windows" build number 8
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win64/ws/>
 > C:/Program Files (x86)/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files (x86)/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > C:/Program Files (x86)/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files (x86)/Git/cmd/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
Checking out Revision ba8bbbd0988af2fd435b4ac3badb1aa5f2a8a687 (refs/remotes/origin/core/master)
Commit message: "update make-tar.sh"
 > C:/Program Files (x86)/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files (x86)/Git/cmd/git.exe checkout -f ba8bbbd0988af2fd435b4ac3badb1aa5f2a8a687
 > C:/Program Files (x86)/Git/cmd/git.exe rev-list df4c8b4935ab45e4d781f55d40263d4099e0fc40 # timeout=10
Cleaning workspace
 > C:/Program Files (x86)/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files (x86)/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files (x86)/Git/cmd/git.exe clean -fdx # timeout=10
 > C:/Program Files (x86)/Git/cmd/git.exe submodule foreach --recursive git reset --hard # timeout=10
 > C:/Program Files (x86)/Git/cmd/git.exe submodule foreach git clean -fdx # timeout=10
FATAL: Command "C:/Program Files (x86)/Git/cmd/git.exe submodule foreach git clean -fdx" returned status code 1:
stdout: Entering 'modules/ca'
Removing configure/O.Common/
Removing configure/O.windows-x64-static/
Removing src/client/O.Common/
Removing src/client/O.windows-x64-static/
Removing src/perl/O.Common/
Removing src/perl/O.windows-x64-static/
Removing src/template/O.Common/
Removing src/template/O.windows-x64-static/
Removing src/tools/O.Common/
Removing src/tools/O.windows-x64-static/
Entering 'modules/database'
Removing src/ioc/O.Common/
Removing src/ioc/O.windows-x64-static/
Removing src/std/O.Common/
Removing src/std/O.windows-x64-static/
Removing test/ioc/db/O.Common/
Removing test/ioc/db/O.windows-x64-static/
Removing test/ioc/dbtemplate/O.Common/
Removing test/ioc/dbtemplate/O.windows-x64-static/
Removing test/std/filters/O.Common/
Removing test/std/filters/O.windows-x64-static/
Removing test/std/rec/O.Common/
Removing test/std/rec/O.windows-x64-static/
Removing test/tools/O.Common/
Removing test/tools/O.windows-x64-static/
Entering 'modules/libcom'
Removing RTEMS/O.Common/
Removing RTEMS/O.windows-x64-static/
Removing src/O.Common/
Removing src/O.windows-x64-static/
Removing test/O.Common/
Removing test/O.windows-x64-static/
Removing vxWorks/O.Common/
Removing vxWorks/O.windows-x64-static/
Entering 'modules/normativeTypes'
Entering 'modules/pvAccess'
Removing examples/O.Common/
Removing examples/O.windows-x64-static/
Removing pvtoolsSrc/O.Common/
Removing pvtoolsSrc/O.windows-x64-static/
Removing src/O.Common/pv
Removing src/ca/O.Common/
Removing src/ca/O.windows-x64-static/
Removing testApp/O.Common/
Removing testApp/O.windows-x64-static/
stderr: warning: failed to remove src/O.Common/
Stopping at 'modules/pvAccess'; script returned non-zero status.
hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/cmd/git.exe submodule foreach git clean -fdx" returned status code 1:
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1924)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1892)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1888)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1533)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.submoduleClean(CliGitAPIImpl.java:1136)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:895)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:870)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:829)
	at hudson.remoting.UserRequest.perform(UserRequest.java:153)
	at hudson.remoting.UserRequest.perform(UserRequest.java:50)
	at hudson.remoting.Request$2.run(Request.java:336)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	at ......remote call to win64-1(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1545)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:253)
	at hudson.remoting.Channel.call(Channel.java:830)
	at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:257)
	at com.sun.proxy.$Proxy83.submoduleClean(Unknown Source)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl.submoduleClean(RemoteGitImpl.java:650)
	at hudson.plugins.git.extensions.impl.SubmoduleOption.onClean(SubmoduleOption.java:86)
	at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:33)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1188)
	at hudson.scm.SCM.checkout(SCM.java:496)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1281)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:604)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
	at hudson.model.Run.execute(Run.java:1728)
	at hudson.matrix.MatrixRun.run(MatrixRun.java:146)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:405)
[WARNINGS] Skipping publisher since build result is FAILURE
Prev: EPICS 7.0.1-pre1 Andrew Johnson
Next: Jenkins build is back to normal : epics-master-windows » STATIC,win64 #10 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.1-pre1 Heinz Junkes
