2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: git question
To: Dirk Zimoch <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Nov 2017 16:16:00 +0000
Hi:
Missed a key idea..
> Like this:
> Create a PSI branch.
> On that branch you can do any PSI-specific changes. The PSI branch is never merged back into master.
> For bugfixes, create branches like "FixBug123", "FixBug456". When done, these branches are merged
For bugfixes, create branches like "FixBug123", “FixBug456” off the master(!) branch. When done, these branches are merged
> 1) Into master
> 2) Into the PSI branch. Actually, you could either merge FixBug123 into PSI, or just merge master back into PSI which already contains the FixBug123 merge.
> In case you do develop something of general interest on the PSI branch, something that should be merged into master:
> Create a "FeatureXYZ" branch off master. Cherry-pick the commits for the new something from PSI into FeatureXYZ, then merge FeatureXYZ into master.
> When a new EPICS update comes out on master, you again merge master into PSI. It will keep your config file changes from the PSI branch.
> In theory, that works great. In practice, it actually works quite well, but of course there will be merge conflicts when the master branch updated the structure of a config file, so then there are changes to the file on both master and in the PSI branch which you will need to sort out.
> -Kay
git question Dirk Zimoch
Re: git question Kasemir, Kay
Prev: Re: git question Dirk Zimoch
Next: Re: git question Kasemir, Kay
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: git question Niklas Claesson
Next: EPICS 7.0.1-pre1 (dbJLinkInit: lexical error: invalid char in json text. ) on Fedora 26 Williams Jr., Ernest L.
