2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 Release Candidate 1
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 3 Dec 2017 23:44:52 +0000
I would like to get this via git rather than a tar file. I tried the following but it failed.  What am I doing wrong?
corvette:/usr/local/epics>git clone --recursive [email protected]:epics-base/epics-base
Cloning into 'epics-base'...
remote: Counting objects: 111721, done.
remote: Total 111721 (delta 0), reused 0 (delta 0), pack-reused 111721
Receiving objects: 100% (111721/111721), 94.60 MiB | 36.32 MiB/s, done.
Resolving deltas: 100% (81268/81268), done.
Submodule 'modules/ca' ([email protected]:epics-base/epics-base/) registered for path 'modules/ca'
Submodule 'modules/database' ([email protected]:epics-base/epics-base/) registered for path 'modules/database'
Submodule 'modules/libcom' ([email protected]:epics-base/epics-base/) registered for path 'modules/libcom'
Submodule 'modules/normativeTypes' (https://github.com/epics-base/normativeTypesCPP) registered for path 'modules/normativeTypes'
Submodule 'modules/pvAccess' (https://github.com/epics-base/pvAccessCPP) registered for path 'modules/pvAccess'
Submodule 'modules/pvData' (https://github.com/epics-base/pvDataCPP) registered for path 'modules/pvData'
Submodule 'modules/pvDatabase' (https://github.com/epics-base/pvDatabaseCPP) registered for path 'modules/pvDatabase'
Submodule 'modules/pva2pva' (https://github.com/epics-base/pva2pva) registered for path 'modules/pva2pva'
Submodule 'modules/pvaClient' (https://github.com/epics-base/pvaClientCPP) registered for path 'modules/pvaClient'
Cloning into 'modules/ca'...
ERROR: Repository not found.
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Clone of '[email protected]:epics-base/epics-base/' into submodule path 'modules/ca' failed
From: [email protected] <[email protected]> on behalf of Andrew Johnson <[email protected]>
Sent: Friday, December 1, 2017 5:37 PM
To: EPICS tech-talk
Subject: EPICS 7 Release Candidate 1
The Core EPICS developers are proud to belatedly announce that the first
(and hopefully only) release candidate version of EPICS 7.0.1 has been
tagged and tarred up and is available for download and testing from the
EPICS website:
    http://www.aps.anl.gov/epics/base/R7-0/1.php
Anyone who has built past EPICS Base releases should have no difficulty
in configuring and building this release from the tar-file, the process
is the same as before although internally the layout of the source code
is a little different. This was done to integrate the EPICS PVA modules
(formerly referred to as EPICS V4 C++ modules) into the build, so while
the complete build takes longer the result now includes support for the
new pvAccess network protocol.
Unfortunately our release documentation is still woefully incomplete.
We want to make the final 7.0.1 release in just over a week's time, so
please report any problems and send any questions here to tech-talk as
soon as possible. The developers will try to answer them as soon as we can.
- Andrew
Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Prev: Jenkins build is back to normal : epics-base-3.14-win64 #224 APS Jenkins
Next: Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
