Hi Andrew,
Thanks for the quick reply.
> Do you ever need an architecture-specific CONFIG_SITE.local file to match?
Not that I can recall.
Note that building for Windows on a Linux host used to be very slow. I put up with it because the simplicity of a single working directory where I could test Linux and Windows together was worth it.
However, as of the SMB server that is in Centos 7 the performance is excellent. I just timed building all of base-7.0.1 on Windows with the files on my Centos 7 server. It was under 5 minutes. It was using more than 7 on my 8 core Windows machine, so it is now CPU bound and no longer I/O bound like it was when I was running Fedora 15, for example.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Andrew Johnson
> Sent: Monday, December 04, 2017 6:14 PM
> To: [email protected]
> Subject: Re: Problem building base-7.0.1 with Windows on a Linux file system
> Hi Mark,
> On 12/04/2017 05:38 PM, Mark Rivers wrote:
> > I am having trouble building for EPICS_HOST_ARCH=windows-x64-static on a
> > Linux file server. Previously when building EPICS base there were no
> > RELEASE or RELEASE.local files to worry about. This is not the case
> > with 7.0.1.
> Actually your issue isn't really that you're building for Windows on a
> Linux file-system (the file-system itself isn't the problem), as that
> you want to share a single installation of Base between both Linux and
> Windows, and we obviously haven't thought about that configuration
> properly because it just doesn't work at the moment.
> > The file modules/RELEASE.local contains
> > EPICS_BASE = /usr/local/epics/base-7.0.1
> > which is where I put it on Linux.
> Right. This file gets created the first time that GNUmake descends into
> the modules directory. If you had built this on Windows first the
> contents would reflect the path there instead.
> > I tried creating a new file in that directory,
> > RELEASE.local.windows-x64-static. It contains:
> > EPICS_BASE = H:/epics/base-7.0.1
> > which is the correct path for Windows. However, that file does not seem
> > to get included
> Right, it won't, we currently only include a single RELEASE.local file.
> > It would be very nice if all I need to do is to create
> > modules/RELEASE.local.$(EPICS_HOST_ARCH) to define EPICS_BASE and
> > everything else just built out of the box. As it is now I need to edit
> > configure/RELEASE in 9 directories.
> > Perhaps I am missing something?
> No, we just didn't think of this - you're the only person I know who
> uses this particular configuration.
> Then on 12/04/2017 at 05:55 PM, Mark Rivers wrote:
> > Never mind, I came up with a simple solution. I edited
> > modules/RELEASE.local to pull in architecture-specific version from that
> > location:
> > -include $(TOP)/../RELEASE.local.$(EPICS_HOST_ARCH)
> > That works fine, and involves editing just that file and adding the new
> > RELEASE.local.$(EPICS_HOST_ARCH) files.
> > This second line might be added when modules/RELEASE.local is created.
> > It would save others having to reinvent what I just did.
> I will probably just generate RELEASE.local.<host-arch> and modify our
> submodule configure/RELEASE files to pull that in instead. This way the
> solution is automatic and you shouldn't have to do anything for it to
> work (you will get a RELEASE.local.* file for each host-architecture you
> build for).
> Thanks for the report and suggested fix.
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
- Problem building base-7.0.1 with Windows on a Linux file system Mark Rivers
- Re: Problem building base-7.0.1 with Windows on a Linux file system Andrew Johnson
Problem building areaDetector with base7.0.1-rc1 Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
