2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: moving initHooks into libCom
To: <[email protected]>
Date: Fri, 8 Dec 2017 14:29:05 -0600
Michael,
In case your Inbox filters out Jenkins emails the epics-master-windows
APS job is now demonstrating the pva2pva build failure.
- Andrew
On 12/08/2017 02:09 PM, Andrew Johnson wrote:
> On 12/08/2017 01:57 PM, Mark Rivers wrote:
>> I forget exactly what CALL does, but I don't think it's necessary.  It's
>> worth trying I guess.
> Yes, that fixed it. Jenkins runs build commands inside its own .BAT
> file, and apparently executing one .BAT file inside another stops the
> parent script. It's currently compiling using
>> Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
> as against
>> Microsoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64
>> Can you try the command interactively on that machine?
> I can't open a command window with the Jenkins build environment, the
> Jenkins agent sets up the shell environment by itself, and it's
> complicated by the fact that it's all running inside a JVM too.
> - Andrew
Re: moving initHooks into libCom Michael Davidsaver
Re: moving initHooks into libCom Andrew Johnson
RE: moving initHooks into libCom Mark Rivers
Prev: Build failed in Jenkins: epics-master-windows » STATIC,win64 #22 APS Jenkins
Next: Re: moving initHooks into libCom Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: moving initHooks into libCom Andrew Johnson
