2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 7.0.1-rc1
To: EPICS Core Talk <[email protected]>
Date: Fri, 15 Dec 2017 09:57:08 +0100
Upstream repository is Git on Launchpad, GitHub clone is synchronized via a mirroring job.
As mentioned on the GitHub page, no recent changes.
~Ralph
On Fri, Dec 15, 2017 at 9:48 AM, Dirk Zimoch <[email protected]> wrote:
Hi Michael,
Thanks for the explanations.
I noticed that you used github in your example, not lauchpad. Has this changed recently?
Dirk
On 14.12.2017 17:21, Michael Davidsaver wrote:
On 12/14/2017 08:48 AM, Dirk Zimoch wrote:
Hi everyone,
What I still do not understand is how to work on the EPICS 7 submodules.
On 14.12.2017 14:38, Michael Davidsaver wrote:
I avoid the redundant download with:
git clone --branch core/master https://github.com/epics-base/epics-base.git
git submodule update --init --reference .
Note that the second line ends with a dot '.'.
After that, what is the state of the submodule? Latest commit? I found that git tells me that they are "not on any branch". Is that a problem?
When 'git status' reports no changes in the super-module, then each of the submodules are at the commit associated with the super-module
commit.  This will often be a detached HEAD (aka. not on any branch).  This is fine if you're just going to build.  If you want
to do work, then generally the first step is to go into a submodule (eg. modules/ca) and create a branch.  eg.
cd modules/ca
git checkout -b mybranchname
This will create a new branch at the present rev without modifying the working tree (it's safe).
You can then move that branch around as necessary.  eg.
git merge --ff-only origin/ca/master
Which is the safe way to jump to the latest rev.  If will abort if the current branch has diverged,
or if uncommitted changes would be clobbered.
So when I want to propose a change for merge, what should I do?
Create a new branch I suppose but in the submodule or in the main directory?
If you're only changing one submodule, then go into the submodule directory and forget about
the supermodule while you're working.  To continue my modules/ca example:
cd modules/ca
... file changes ...
git commit -m 'Make CA great again"
git remote add md https://github.com/mdavidsaver/epics-base.git
git push md mybranchname
Then pushing the merge request, will I push from the submodule or from the main directory?
The whole work flow with submodules is still very unclear to me.
Dirk
On 12/14/2017 02:20 AM, Torsten Bögershausen wrote:
Hej,
Yesterday I was sitting on a 3Mbit/sec line I was cloning base from Git,
I realized that "base" needs to be transferred 4 times.
I got 4 pack files, each 95M.
One for base, modules/ca, modules/database, modules/libcom/
99 234 251 ./.git/modules/modules/ca/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
99234251 ./.git/modules/modules/database/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
99234251 ./.git/modules/modules/libcom/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
99234251 ./.git/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
I think this is because the modularization was done without running
"git filter-branch".
My first question:
Does anybody else feels that this is a problem to download
4*95 Mbyte, when 1*95 Mbyte enough ?
And if yes, what should we do about it?
a) Undo the modularization.  Keep ca, database, libcom in the same
   Git as before ?
b) Run Git filter-branch and try a surgery on the Gits?
c) Leave everything as it is ?
Any thoughts and opinions ?
On 01/12/17 01:20, Andrew Johnson wrote:
I just tagged, tarred, tested uploaded and pushed the -rc1, but I don't
have time to write the announcement email for tech-talk tonight. If no
one else feels like doing so I'll get to it tomorrow morning.
- Andrew
Re: 7.0.1-rc1 Dirk Zimoch
7.0.1-rc1 Andrew Johnson
Re: 7.0.1-rc1 Torsten Bögershausen
Re: 7.0.1-rc1 Michael Davidsaver
Prev: Re: 7.0.1-rc1 Dirk Zimoch
Next: Re: 7.0.1-rc1 Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
