2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 7.0.1-rc1
To: <[email protected]>
Date: Fri, 15 Dec 2017 10:18:45 -0600
Hi Dirk,
On 12/15/2017 03:14 AM, Dirk Zimoch wrote:
> Thanks for the hint about the .ci directory. I had not noticed it yet.
We seem to be using it for developer scripts as well as continuous
integration files; it will not be included in released tarfiles though.
> I think this situation occurs regularly when updating RELEASE_NOTES.html
> after a change in a submodule. How is the policy for this? I assume
> RELEASE_NOTES.html should be updated for every new feature, right?
We're going to have to split the release notes into separate files for
the 3 Base submodules to resolve that problem. Documentation is one
thing I'm going to want us to work on for the next release, and I see
the release notes issue as part of that.
> I am still quite new with git and have never used submodules before,
> thus it may seem complicated only to me. But I found out that with git
> guessing the next step is usually a bad idea. I often guess wrong and
> and up with a headache and git status I cannot resolve.
Quite often the output from 'git status' gives good information on what
you might want to do next. I do agree that this is complicated, so for
changes that could apply to the older releases you might want to try
developing on one of the older branches (preferably 3.16) and having us
split the work up on merging into 7.
> When you say "set the right submodule branch" that means not core/master
> but what I find in .gitmodules under "branch"? So for database it would
> be modules/database but for pvDatabase just master?
The core/master branch only contains the top-level files, i.e. the build
system and Perl scripts from src/tools. If your changes are to the IOC
code you will be working in the database submodule, which is checked out
from the database/master branch, so your merge request would specify
that this merge should be applied to the database/master branch.
> When making a merge request, do I need a separate repository for each
> feature or do I use separate branches on the same repository, e.g.
> git+ssh://[email protected]/~dirk.zimoch/epics-base ?
You can use different branches of the same repository, it seems to make
more sense even on Launchpad.
> What if I have a merge request of the same feature for multiple versions
> of EPICS base, say 3.15, 3.16, and 7?
If you have changes that we should be merged into one of the older
branches, develop them against the oldest branch that makes sense and
create your merge request for that branch; we (I) will merge them up to
the newer branches. If the newer branches have diverged sufficiently
that there needs to be different code for later branches bring that up
here and we can decide what to do.
In general new features should be developed for the latest branch, but
some changes including bug fixes, build system updates and modifications
to allow the code to build on newer OSs are fair game for the older ones.
HTH,
- Andrew
> On 14.12.2017 18:02, Andrew Johnson wrote:
>> Hi Dirk,
>> If you're likely to be making changes across multiple modules you can
>> also use the checkout-modules.sh script in the core's .ci directory
>> which for each submodule will checkout and pull the branch named in the
>> .gitmodules file for that module. I haven't tried using it when I have
>> made local commits that haven't been merged yet though, it may prompt
>> you for a log message in that case.
>> You are also leading the way with your question about how to do merge
>> proposals with the new structure. Unfortunately I think we may have made
>> this much more complicated for some developers, although as long as your
>> changes only affect one submodule it shouldn't be too bad. You just have
>> to make sure that you set the right submodule branch that you want to
>> merge the change into when you're submitting the proposal to Launchpad.
>> I do want to have a discussion about the process in the new year, we
>> need to properly document it, which we previously did on the Wiki page
>> https://wiki-ext.aps.anl.gov/epics/index.php/How_to_check_out_EPICS_Base_with_Bazaar
>> There are probably many things out of date that are linked from the V4
>> page http://epics-pvdata.sourceforge.net/development.html
>> - Andrew
>> On 12/14/2017 10:21 AM, Michael Davidsaver wrote:
>>> On 12/14/2017 08:48 AM, Dirk Zimoch wrote:
>>>> Hi everyone,
>>>> What I still do not understand is how to work on the EPICS 7
>>>> submodules.
>>>> On 14.12.2017 14:38, Michael Davidsaver wrote:
>>>>> I avoid the redundant download with:
>>>>>> git clone --branch core/master
>>>>>> https://github.com/epics-base/epics-base.git
>>>>>> git submodule update --init --reference .
>>>>> Note that the second line ends with a dot '.'.
>>>> After that, what is the state of the submodule? Latest commit? I
>>>> found that git tells me that they are "not on any branch". Is that a
>>>> problem?
>>> When 'git status' reports no changes in the super-module, then each
>>> of the submodules are at the commit associated with the super-module
>>> commit.  This will often be a detached HEAD (aka. not on any
>>> branch).  This is fine if you're just going to build.  If you want
>>> to do work, then generally the first step is to go into a submodule
>>> (eg. modules/ca) and create a branch.  eg.
>>>> cd modules/ca
>>>> git checkout -b mybranchname
>>> This will create a new branch at the present rev without modifying
>>> the working tree (it's safe).
>>> You can then move that branch around as necessary.  eg.
>>>> git merge --ff-only origin/ca/master
>>> Which is the safe way to jump to the latest rev.  If will abort if
>>> the current branch has diverged,
>>> or if uncommitted changes would be clobbered.
>>>> So when I want to propose a change for merge, what should I do?
>>>> Create a new branch I suppose but in the submodule or in the main
>>>> directory?
>>> If you're only changing one submodule, then go into the submodule
>>> directory and forget about
>>> the supermodule while you're working.  To continue my modules/ca
>>> example:
>>>> cd modules/ca
>>>> ... file changes ...
>>>> git commit -m 'Make CA great again"
>>>> git remote add md https://github.com/mdavidsaver/epics-base.git
>>>> git push md mybranchname
>>>> Then pushing the merge request, will I push from the submodule or
>>>> from the main directory?
>>>> The whole work flow with submodules is still very unclear to me.
>>>> Dirk
>>>>> On 12/14/2017 02:20 AM, Torsten Bögershausen wrote:
>>>>>> Hej,
>>>>>> Yesterday I was sitting on a 3Mbit/sec line I was cloning base
>>>>>> from Git,
>>>>>> I realized that "base" needs to be transferred 4 times.
>>>>>> I got 4 pack files, each 95M.
>>>>>> One for base, modules/ca, modules/database, modules/libcom/
>>>>>> 99 234 251
>>>>>> ./.git/modules/modules/ca/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
>>>>>> 99234251
>>>>>> ./.git/modules/modules/database/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
>>>>>> 99234251
>>>>>> ./.git/modules/modules/libcom/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
>>>>>> 99234251
>>>>>> ./.git/objects/pack/pack-08cf7dbc8f8108176628acb637cfa5d864f0aa43.pack
>>>>>> I think this is because the modularization was done without running
>>>>>> "git filter-branch".
>>>>>> My first question:
>>>>>> Does anybody else feels that this is a problem to download
>>>>>> 4*95 Mbyte, when 1*95 Mbyte enough ?
>>>>>> And if yes, what should we do about it?
>>>>>> a) Undo the modularization.  Keep ca, database, libcom in the same
>>>>>>    Git as before ?
>>>>>> b) Run Git filter-branch and try a surgery on the Gits?
>>>>>> c) Leave everything as it is ?
>>>>>> Any thoughts and opinions ?
>>>>>> On 01/12/17 01:20, Andrew Johnson wrote:
>>>>>>> I just tagged, tarred, tested uploaded and pushed the -rc1, but I
>>>>>>> don't
>>>>>>> have time to write the announcement email for tech-talk tonight.
>>>>>>> If no
>>>>>>> one else feels like doing so I'll get to it tomorrow morning.
>>>>>>> - Andrew
7.0.1-rc1 Andrew Johnson
Re: 7.0.1-rc1 Torsten Bögershausen
Re: 7.0.1-rc1 Michael Davidsaver
Re: 7.0.1-rc1 Dirk Zimoch
Re: 7.0.1-rc1 Andrew Johnson
Prev: Re: 7.0.1 Final Mark Rivers
Next: Re: 7.0.1 Final Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 7.0.1-rc1 Dirk Zimoch
Next: Re: 7.0.1-rc1 Dirk Zimoch
