2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linking PVA against C++11 stuff
To: Ralph Lange <[email protected]>, EPICS Core Talk <[email protected]>
Date: Fri, 22 Dec 2017 09:12:13 -0600
On 12/22/2017 06:14 AM, Ralph Lange wrote:
> Hi,
> We just found out that we have a set of libraries/applications that use C++11 and thus call the GNU compiler on our RHEL7.4 systems (gcc 4.8.5) with "-std=c==0x".
> When linking, the build searches for pvData/pvAccess functions with the argument type "std::shared_ptr<>", while the EPICS PVA libraries provide the functions for an argument of type "std::tr1::shared_ptr<>", and the linking fails.
> What are our options?
Immediately, in each of the compile units where -std=c++0x is given, define the following before pv/sharedPtr.h is included.
> #define SHARED_FROM_MANUAL
> #include <tr1/memory>
This overrides the logic which selects shared_ptr implementations and always
uses the TR1 implementation directly.  This will work as long as the PVA modules
built with c++98.
Alternately, you can hack pv/sharedPtr.h to make an explicit choice to always use TR1,
or hack Base (the core module) to always default to -std=c++11.
Attachment: signature.asc
Description: OpenPGP digital signature
Linking PVA against C++11 stuff Ralph Lange
Prev: Linking PVA against C++11 stuff Ralph Lange
Next: Problem exiting simDetector IOC with base 7.0.1.1 on windows-x64 Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017>  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 27 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
