2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building example application on windows-x64
To: 'EPICS core-talk' <[email protected]>
Date: Wed, 27 Dec 2017 18:05:15 +0000
I just did this again, but running makeBaseApp.pl with Windows rather than Linux.  I get the same problem. It looks like the problem is that testVersion.h is changing because the timestamp is incrementing by 1 second between the time it is created and checked?
Sent: Wednesday, December 27, 2017 11:52 AM
To: EPICS core-talk
Subject: Problem building example application on windows-x64
I am having a problem building the example application from makeBaseApp in 7.0.1.1 on windows-x64.
I first ran the following on linux-x86_64:
/usr/local/epics-devel/base-7.0.1/bin/linux-x86_64/makeBaseApp.pl -t example test
/usr/local/epics-devel/base-7.0.1/bin/linux-x86_64/makeBaseApp.pl -i -t example test
I then built the IOC application and ran it fine on linux-x86_64.
I then edited example/configure/RELEASE to define EPICS_BASE for the location for windows-x64.
Running on a Windows machine with EPICS_HOST_ARCH=windows-x64 I did
make clean uninstall
That worked OK as follows:
J:\epics\devel\example>make clean uninstall
make -C ./configure clean
make[1]: Entering directory 'J:/epics/devel/example/configure'
perl -CSD -MExtUtils::Command -e rm_rf O.windows-x64 O.Common
make[1]: Leaving directory 'J:/epics/devel/example/configure'
make -C ./testApp clean
make[1]: Entering directory 'J:/epics/devel/example/testApp'
make -C ./src clean
make[2]: Entering directory 'J:/epics/devel/example/testApp/src'
make[2]: Leaving directory 'J:/epics/devel/example/testApp/src'
make -C ./Db clean
make[2]: Entering directory 'J:/epics/devel/example/testApp/Db'
make[2]: Leaving directory 'J:/epics/devel/example/testApp/Db'
make[1]: Leaving directory 'J:/epics/devel/example/testApp'
make -C ./iocBoot clean
make[1]: Entering directory 'J:/epics/devel/example/iocBoot'
make -C ./ioctest clean
make[2]: Entering directory 'J:/epics/devel/example/iocBoot/ioctest'
perl -CSD -MExtUtils::Command -e rm_f cdCommands envPaths dllPath.bat relPaths.sh
make[2]: Leaving directory 'J:/epics/devel/example/iocBoot/ioctest'
make[1]: Leaving directory 'J:/epics/devel/example/iocBoot'
perl -CSD -MExtUtils::Command -e rm_rf ./bin/windows-x64
perl -CSD -MExtUtils::Command -e rm_rf ./lib/windows-x64
perl -CSD -MExtUtils::Command -e rm_rf ./dbd ./include ./doc ./html ./templates ./db ./adl ./alh ./cfg ./edl ./lib/perl ./lib/pkgconfig
However, there is a problem when I then run make as follows:
make -C ./configure install
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'J:/epics/devel/example/configure/O.windows-x64'
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/convertRelease.pl checkRelease
make[2]: Leaving directory 'J:/epics/devel/example/configure/O.windows-x64'
make -C ./testApp install
make -C ./src install
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'J:/epics/devel/example/testApp/src/O.windows-x64'
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../dbd -IH:/epics-devel/base-7.0.1/dbd -o xxxRecord.h ../xxxRecord.dbd
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m initTrace.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        initTrace.obj ../initTrace.c
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m testHello.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        testHello.obj ../testHello.c
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/genVersionHeader.pl  -t ../../.. -N testVERSION -V "" ../O.Common/testVersion.h
Creating VCS header ../O.Common/testVersion.h
    testVERSION = "2017-12-27T11:39:26"
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m devtestVersion.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../..
/../include -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        devtestVersion.obj ../devtestV
ersion.c
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m dbSubExample.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../.
./include -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        dbSubExample.obj ../dbSubExample
.c
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m devXxxSoft.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../
include -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        devXxxSoft.obj ../devXxxSoft.c
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m xxxRecord.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../i
nclude -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        xxxRecord.obj ../xxxRecord.c
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m testMain.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../in
clude -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        testMain.obj ../testMain.cpp
"Creating dbd file test.dbd"
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -IH:/epics-devel/base-7.0.1/dbd -o test.dbd base.dbd xxxSupport.dbd dbSubExample.dbd devtestVersion.dbd testHello.dbd initTrace.dbd PVAServerRegister.dbd qsrv.dbd
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -IH:/epics-devel/base-7.0.1/dbd    -o test_registerRecordDeviceDriver.cpp ../O.Common/test.dbd test_registerRecordDeviceDriver J:/epics/devel/example
perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl  -m test_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include
/os/WIN32 -I../../../include -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        test_registerRecordDeviceDriver.obj test_registerRecordDeviceDriver.cpp
Updating VCS header ../O.Common/testVersion.h
    testVERSION = "2017-12-27T11:39:33"
/../include -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        devtestVersion.obj ../devtestVersion.c
    testVERSION = "2017-12-27T11:39:34"
    testVERSION = "2017-12-27T11:39:35"
    testVERSION = "2017-12-27T11:39:37"
    testVERSION = "2017-12-27T11:39:38"
    testVERSION = "2017-12-27T11:39:40"
    testVERSION = "2017-12-27T11:39:41"
    testVERSION = "2017-12-27T11:39:42"
As you can see above it gets into an infinite loop with testVersion.c.
Am I doing something wrong?
Re: Problem building example application on windows-x64 Andrew Johnson
Problem building example application on windows-x64 Mark Rivers
Prev: Problem building example application on windows-x64 Mark Rivers
Next: Re: Problem building example application on windows-x64 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 27 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
