2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-win64 #336
To: [email protected]
Date: Mon, 5 Feb 2018 13:13:34 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/336/display/redirect>
Started by upstream project "epics-base-3.15" build number 355
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/ws/>
 > C:/Program Files (x86)/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files (x86)/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > C:/Program Files (x86)/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files (x86)/Git/cmd/git.exe fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > C:/Program Files (x86)/Git/cmd/git.exe rev-parse "origin/3.15^{commit}" # timeout=10
Checking out Revision 61296b8cff4e0100ba356f5d4af29665b456f759 (origin/3.15)
 > C:/Program Files (x86)/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files (x86)/Git/cmd/git.exe checkout -f 61296b8cff4e0100ba356f5d4af29665b456f759
Commit message: "Merge 3.14 into 3.15"
 > C:/Program Files (x86)/Git/cmd/git.exe rev-list --no-walk ac367398b30e221d3739568e2d7ae5eab08ea33a # timeout=10
Cleaning workspace
 > C:/Program Files (x86)/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files (x86)/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files (x86)/Git/cmd/git.exe clean -fdx # timeout=10
FATAL: Command "C:/Program Files (x86)/Git/cmd/git.exe clean -fdx" returned status code 1:
stdout: Removing bin/windows-x64
Removing bin/windows-x64-static
Removing configure/O.Common/
Removing configure/O.windows-x64-static/
Removing configure/O.windows-x64/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing src/ca/client/O.Common/
Removing src/ca/client/O.windows-x64-static/
Removing src/ca/client/O.windows-x64/
Removing src/ca/client/perl/O.Common/
Removing src/ca/client/perl/O.windows-x64-static/
Removing src/ca/client/perl/O.windows-x64/
Removing src/ca/client/tools/O.Common/
Removing src/ca/client/tools/O.windows-x64-static/
Removing src/ca/client/tools/O.windows-x64/
Removing src/ca/legacy/gdd/O.Common/
Removing src/ca/legacy/gdd/O.windows-x64-static/
Removing src/ca/legacy/gdd/O.windows-x64/
Removing src/ca/legacy/pcas/build/O.Common/
Removing src/ca/legacy/pcas/build/O.windows-x64-static/
Removing src/ca/legacy/pcas/build/O.windows-x64/
Removing src/ca/legacy/pcas/ex/O.Common/
Removing src/ca/legacy/pcas/ex/O.windows-x64-static/
Removing src/ca/legacy/pcas/ex/O.windows-x64/
Removing src/ca/legacy/pcas/example/directoryService/O.Common/
Removing src/ca/legacy/pcas/example/directoryService/O.windows-x64-static/
Removing src/ca/legacy/pcas/example/directoryService/O.windows-x64/
Removing src/ioc/O.Common/
Removing src/ioc/O.windows-x64-static/
Removing src/ioc/O.windows-x64/
Removing src/ioc/db/test/O.Common/
Removing src/ioc/db/test/O.windows-x64-static/
Removing src/ioc/db/test/O.windows-x64/
Removing src/ioc/dbtemplate/test/O.Common/
Removing src/ioc/dbtemplate/test/O.windows-x64-static/
Removing src/ioc/dbtemplate/test/O.windows-x64/
Removing src/libCom/O.Common/
Removing src/libCom/O.windows-x64-static/
Removing src/libCom/O.windows-x64/
Removing src/libCom/RTEMS/O.Common/
Removing src/libCom/RTEMS/O.windows-x64-static/
Removing src/libCom/RTEMS/O.windows-x64/
Removing src/libCom/test/O.Common/
Removing src/libCom/test/O.windows-x64-static/
Removing src/libCom/test/O.windows-x64/
Removing src/std/O.Common/
Removing src/std/O.windows-x64-static/
Removing src/std/O.windows-x64/
Removing src/std/filters/test/O.Common/
Removing src/std/filters/test/O.windows-x64-static/
Removing src/std/filters/test/O.windows-x64/
Removing src/std/rec/test/O.Common/
Removing src/std/rec/test/O.windows-x64-static/
Removing src/std/rec/test/O.windows-x64/
Removing src/template/base/O.Common/
Removing src/template/base/O.windows-x64-static/
Removing src/template/base/O.windows-x64/
Removing src/template/ext/O.Common/
Removing src/template/ext/O.windows-x64-static/
Removing src/template/ext/O.windows-x64/
Removing src/tools/O.Common/
Removing src/tools/O.windows-x64-static/
Removing src/tools/O.windows-x64/
Removing src/tools/test/O.Common/
Removing src/tools/test/O.windows-x64-static/
Removing src/tools/test/O.windows-x64/
Removing templates/makeBaseApp/top
Removing templates/makeBaseExt
stderr: warning: failed to remove bin/
warning: failed to remove templates/makeBaseApp
Also:   hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-1
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1693)
		at hudson.remoting.UserResponse.retrieve(UserRequest.java:310)
		at hudson.remoting.Channel.call(Channel.java:908)
		at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:281)
		at com.sun.proxy.$Proxy91.clean(Unknown Source)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
		at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:30)
		at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1238)
		at hudson.scm.SCM.checkout(SCM.java:495)
		at hudson.model.AbstractProject.checkout(AbstractProject.java:1202)
		at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
		at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
		at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
		at hudson.model.Run.execute(Run.java:1724)
		at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
		at hudson.model.ResourceController.execute(ResourceController.java:97)
		at hudson.model.Executor.run(Executor.java:421)
hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/cmd/git.exe clean -fdx" returned status code 1:
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1990)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1958)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1954)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1592)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1604)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:782)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:922)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:896)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:853)
	at hudson.remoting.UserRequest.perform(UserRequest.java:207)
	at hudson.remoting.UserRequest.perform(UserRequest.java:53)
	at hudson.remoting.Request$2.run(Request.java:358)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.15-win64 #337 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win32 #195 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.15-win64 #337 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.16-win32 #196 APS Jenkins
ANJ, 06 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
