2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-rtems #311
To: [email protected]
Date: Sat, 24 Feb 2018 21:42:39 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-rtems/311/display/redirect>
[...truncated 364.94 KB...]
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF beaconTimer.d  ../../../../../../src/ca/legacy/pcas/generic/beaconTimer.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF caNetAddr.d  ../../../../../../src/ca/legacy/pcas/generic/caNetAddr.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF pvAttachReturn.d  ../../../../../../src/ca/legacy/pcas/generic/pvAttachReturn.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF pvExistReturn.d  ../../../../../../src/ca/legacy/pcas/generic/pvExistReturn.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casBufferFactory.d  ../../../../../../src/ca/legacy/pcas/generic/casBufferFactory.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF ioBlocked.d  ../../../../../../src/ca/legacy/pcas/generic/st/ioBlocked.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casEventMask.d  ../../../../../../src/ca/legacy/pcas/generic/casEventMask.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casCtx.d  ../../../../../../src/ca/legacy/pcas/generic/casCtx.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF outBuf.d  ../../../../../../src/ca/legacy/pcas/generic/outBuf.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF inBuf.d  ../../../../../../src/ca/legacy/pcas/generic/inBuf.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casMonEvent.d  ../../../../../../src/ca/legacy/pcas/generic/casMonEvent.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casMonitor.d  ../../../../../../src/ca/legacy/pcas/generic/casMonitor.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casEventSys.d  ../../../../../../src/ca/legacy/pcas/generic/casEventSys.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncPVAttachIOI.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVAttachIOI.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncPVAttachIO.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVAttachIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncPVExistIOI.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVExistIOI.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncPVExistIO.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVExistIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncWriteIOI.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncWriteIOI.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncWriteIO.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncWriteIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncReadIOI.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncReadIOI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncReadIO.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncReadIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casAsyncIOI.d  ../../../../../../src/ca/legacy/pcas/generic/casAsyncIOI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casChannelI.d  ../../../../../../src/ca/legacy/pcas/generic/casChannelI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casChannel.d  ../../../../../../src/ca/legacy/pcas/generic/casChannel.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casPVI.d  ../../../../../../src/ca/legacy/pcas/generic/casPVI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casPV.d  ../../../../../../src/ca/legacy/pcas/generic/casPV.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casStrmClient.d  ../../../../../../src/ca/legacy/pcas/generic/casStrmClient.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casDGClient.d  ../../../../../../src/ca/legacy/pcas/generic/casDGClient.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF casCoreClient.d  ../../../../../../src/ca/legacy/pcas/generic/casCoreClient.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF caServerI.d  ../../../../../../src/ca/legacy/pcas/generic/caServerI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -MM -MF caServer.d  ../../../../../../src/ca/legacy/pcas/generic/caServer.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/caServer.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/caServerI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casCoreClient.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casDGClient.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casStrmClient.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casPV.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casPVI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casChannel.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casChannelI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncIOI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncReadIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncReadIOI.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncWriteIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncWriteIOI.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVExistIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVExistIOI.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVAttachIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casAsyncPVAttachIOI.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casEventSys.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casMonitor.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casMonEvent.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/inBuf.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/outBuf.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casCtx.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casEventMask.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/st/ioBlocked.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/casBufferFactory.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/pvExistReturn.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/pvAttachReturn.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/caNetAddr.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/beaconTimer.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/beaconAnomalyGovernor.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/clientBufMemoryManager.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/chanIntfForPV.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/channelDestroyEvent.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/st/casIntfOS.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/st/casDGIntfOS.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/generic/st/casStreamOS.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/io/bsdSocket/caServerIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/io/bsdSocket/casIntfIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc
../../../../../../src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc: In member function 'virtual void casDGIntfIO::sendBeaconIO(char&, unsigned int, aitUint16&, aitUint32&)':
../../../../../../src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc:420: warning: comparison between signed and unsigned integer expressions
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/io/bsdSocket/casStreamIO.cc
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../../../../src/ca/legacy/pcas/generic -I../../../../../../src/ca/legacy/pcas/io/bsdSocket -I../../../../../../src/ca/legacy/pcas/generic/st -I../../../../../../src/ca/client -I../../../../../../include/compiler/gcc -I../../../../../../include/os/RTEMS -I../../../../../../include         -c ../../../../../../src/ca/legacy/pcas/io/bsdSocket/ipIgnoreEntry.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ar rc   libcas.a         caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-ranlib libcas.a
Installing library ../../../../../../lib/RTEMS-uC5282/libcas.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/build/O.RTEMS-uC5282'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/build'
/Jenkins/jenkins/bin/make -C ./example build.RTEMS-uC5282
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example'
/Jenkins/jenkins/bin/make -C ./directoryService build.RTEMS-uC5282
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example/directoryService'
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../../../.. \
    T_A=linux-x86_64 build
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example/directoryService/O.linux-x86_64'
make[5]: Nothing to be done for 'build'.
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example/directoryService/O.linux-x86_64'
/Jenkins/jenkins/bin/make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../../../../../.. \
    T_A=RTEMS-uC5282 build
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example/directoryService/O.RTEMS-uC5282'
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example/directoryService/O.RTEMS-uC5282'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example/directoryService'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/example'
/Jenkins/jenkins/bin/make -C ./build RTEMS-uC5282
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/build'
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../../.. T_A=linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/build/O.linux-x86_64'
make[4]: Nothing to be done for 'all'.
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/build/O.linux-x86_64'
/Jenkins/jenkins/bin/make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../../../../.. T_A=RTEMS-uC5282
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas/build/O.RTEMS-uC5282'
make[4]: Nothing to be done for 'default_target'.
/Jenkins/jenkins/bin/make -C ./example RTEMS-uC5282
/Jenkins/jenkins/bin/make -C ./directoryService RTEMS-uC5282
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../../../.. T_A=linux-x86_64
make[5]: Nothing to be done for 'all'.
/Jenkins/jenkins/bin/make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../../../../../.. T_A=RTEMS-uC5282
make[5]: Nothing to be done for 'default_target'.
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ca/legacy/pcas'
/Jenkins/jenkins/bin/make -C ./ioc RTEMS-uC5282
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ioc'
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ioc/O.linux-x86_64'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ioc/O.linux-x86_64'
/Jenkins/jenkins/bin/make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../.. T_A=RTEMS-uC5282
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ioc/O.RTEMS-uC5282'
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF rsrvIocRegister.d  ../../../src/ioc/rsrv/rsrvIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF online_notify.d  ../../../src/ioc/rsrv/online_notify.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF cast_server.d  ../../../src/ioc/rsrv/cast_server.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include    -I../../../src/ca/client     -MM -MF camessage.d  ../../../src/ioc/rsrv/camessage.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF camsgtask.d  ../../../src/ioc/rsrv/camsgtask.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF caservertask.d  ../../../src/ioc/rsrv/caservertask.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include    -I../../../src/ca/client     -MM -MF caserverio.d  ../../../src/ioc/rsrv/caserverio.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF registryIocRegister.d  ../../../src/ioc/registry/registryIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF registryCommon.d  ../../../src/ioc/registry/registryCommon.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF registryFunction.d  ../../../src/ioc/registry/registryFunction.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF registryDriverSupport.d  ../../../src/ioc/registry/registryDriverSupport.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF registryDeviceSupport.d  ../../../src/ioc/registry/registryDeviceSupport.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF registryRecordType.d  ../../../src/ioc/registry/registryRecordType.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF iocshRegisterCommon.d  ../../../src/ioc/misc/iocshRegisterCommon.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dlload.d  ../../../src/ioc/misc/dlload.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF miscIocRegister.d  ../../../src/ioc/misc/miscIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF iocInit.d  ../../../src/ioc/misc/iocInit.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF epicsRelease.d  ../../../src/ioc/misc/epicsRelease.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbtoolsIocRegister.d  ../../../src/ioc/dbtemplate/dbtoolsIocRegister.c
/Jenkins/jenkins/jobs/epics-base-3.15/workspace/bin/linux-x86_64/e_flex -S../../../include/flex.skel.static -8 -I -t ../../../src/ioc/dbtemplate/dbLoadTemplate_lex.l > dbLoadTemplate_lex.yy.c
/bin/mv dbLoadTemplate_lex.yy.c dbLoadTemplate_lex.c
/Jenkins/jenkins/jobs/epics-base-3.15/workspace/bin/linux-x86_64/antelope -bdbLoadTemplate  ../../../src/ioc/dbtemplate/dbLoadTemplate.y
/bin/mv dbLoadTemplate.tab.c dbLoadTemplate.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbLoadTemplate.d  dbLoadTemplate.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbStaticIocRegister.d  ../../../src/ioc/dbStatic/dbStaticIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbStaticRun.d  ../../../src/ioc/dbStatic/dbStaticRun.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbPvdLib.d  ../../../src/ioc/dbStatic/dbPvdLib.c
/Jenkins/jenkins/jobs/epics-base-3.15/workspace/bin/linux-x86_64/e_flex -S../../../include/flex.skel.static -8 -I -t ../../../src/ioc/dbStatic/dbLex.l > dbLex.yy.c
/bin/mv dbLex.yy.c dbLex.c
/Jenkins/jenkins/jobs/epics-base-3.15/workspace/bin/linux-x86_64/antelope -bdbYacc  ../../../src/ioc/dbStatic/dbYacc.y
/bin/mv dbYacc.tab.c dbYacc.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbYacc.d  dbYacc.c
../../../src/ioc/dbStatic/dbYacc.y:268:19: error: dbLex.c: No such file or directory
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbStaticLib.d  ../../../src/ioc/dbStatic/dbStaticLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbServer.d  ../../../src/ioc/db/dbServer.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbUnitTest.d  ../../../src/ioc/db/dbUnitTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbState.d  ../../../src/ioc/db/dbState.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF chfPlugin.d  ../../../src/ioc/db/chfPlugin.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbIocRegister.d  ../../../src/ioc/db/dbIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF templateInstances.d  ../../../src/ioc/db/templateInstances.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbContextReadNotifyCache.d  ../../../src/ioc/db/dbContextReadNotifyCache.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbPutNotifyBlocker.d  ../../../src/ioc/db/dbPutNotifyBlocker.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbSubscriptionIO.d  ../../../src/ioc/db/dbSubscriptionIO.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbChannelIO.d  ../../../src/ioc/db/dbChannelIO.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbContext.d  ../../../src/ioc/db/dbContext.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF cvtBpt.d  ../../../src/ioc/db/cvtBpt.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF initHooks.d  ../../../src/ioc/db/initHooks.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbCaTest.d  ../../../src/ioc/db/dbCaTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbCa.d  ../../../src/ioc/db/dbCa.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF callback.d  ../../../src/ioc/db/callback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF recGbl.d  ../../../src/ioc/db/recGbl.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF db_test.d  ../../../src/ioc/db/db_test.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF db_access.d  ../../../src/ioc/db/db_access.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbTest.d  ../../../src/ioc/db/dbTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbEvent.d  ../../../src/ioc/db/dbEvent.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbScan.d  ../../../src/ioc/db/dbScan.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbNotify.d  ../../../src/ioc/db/dbNotify.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbLink.d  ../../../src/ioc/db/dbLink.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbExtractArray.d  ../../../src/ioc/db/dbExtractArray.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbFastLinkConv.d  ../../../src/ioc/db/dbFastLinkConv.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbConvert.d  ../../../src/ioc/db/dbConvert.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbChannel.d  ../../../src/ioc/db/dbChannel.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbBkpt.d  ../../../src/ioc/db/dbBkpt.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbAccess.d  ../../../src/ioc/db/dbAccess.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF dbLock.d  ../../../src/ioc/db/dbLock.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF asIocRegister.d  ../../../src/ioc/as/asIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF asCa.d  ../../../src/ioc/as/asCa.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -MM -MF asDbLib.d  ../../../src/ioc/as/asDbLib.c
/bin/mv: cannot stat ‘dbLex.yy.c’: No such file or directory
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/as/asDbLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/as/asCa.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/as/asIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbLock.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbAccess.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbBkpt.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbChannel.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbConvert.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbFastLinkConv.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbExtractArray.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbLink.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbNotify.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbScan.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbEvent.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/db_access.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/db_test.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/recGbl.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/callback.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbCa.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbCaTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/initHooks.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/cvtBpt.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbContext.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbChannelIO.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbSubscriptionIO.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbPutNotifyBlocker.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbContextReadNotifyCache.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/templateInstances.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbIocRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/chfPlugin.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbState.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbUnitTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/db/dbServer.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/ioc/dbStatic/dbStaticLib.c
make[3]: *** No rule to make target 'dbLex.c', needed by 'dbYacc.c'.  Stop.
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ioc/O.RTEMS-uC5282'
../../configure/RULES_ARCHS:62: recipe for target 'RTEMS-uC5282' failed
make[2]: *** [RTEMS-uC5282] Error 2
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src/ioc'
../configure/RULES_DIRS:84: recipe for target 'ioc.RTEMS-uC5282' failed
make[1]: *** [ioc.RTEMS-uC5282] Error 2
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-base-3.15/workspace/src'
configure/RULES_DIRS:84: recipe for target 'src.RTEMS-uC5282' failed
make: *** [src.RTEMS-uC5282] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.15-rtems #312 APS Jenkins
Prev: Re: Named Event, TSE and GeneralTime Michael Davidsaver
Next: Build failed in Jenkins: epics-base-3.15-mac-test #165 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Jenkins build is back to normal : epics-base-3.15-rtems #312 APS Jenkins
ANJ, 28 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
