Subject: |
Build failed in Jenkins: epics-master-windows » DLL,win32 #34 |
APS Jenkins <[email protected]> |
To: |
[email protected] |
Date: |
Sun, 25 Feb 2018 01:40:13 -0600 (CST) |
See <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=DLL,OS=win32/34/display/redirect>
Started by upstream project "epics-master-windows" build number 34
originally caused by:
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=DLL,OS=win32/ws/>
> C:/Program Files (x86)/Git/bin/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files (x86)/Git/bin/git.exe config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
> C:/Program Files (x86)/Git/bin/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files (x86)/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base/
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:862)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1129)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1160)
at hudson.scm.SCM.checkout(SCM.java:495)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1202)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1724)
at hudson.matrix.MatrixRun.run(MatrixRun.java:146)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*" returned status code 1:
stdout: Fetching submodule modules/ca
Fetching submodule modules/database
Fetching submodule modules/libcom
Fetching submodule modules/pvAccess
Fetching submodule modules/pvData
Fetching submodule modules/pva2pva
stderr: remote: Counting objects: 86, done.
remote: Compressing objects: 1% (1/86) remote: Compressing objects: 2% (2/86) remote: Compressing objects: 3% (3/86) remote: Compressing objects: 4% (4/86) remote: Compressing objects: 5% (5/86) remote: Compressing objects: 6% (6/86) remote: Compressing objects: 8% (7/86) remote: Compressing objects: 9% (8/86) remote: Compressing objects: 10% (9/86) remote: Compressing objects: 11% (10/86) remote: Compressing objects: 12% (11/86) remote: Compressing objects: 13% (12/86) remote: Compressing objects: 15% (13/86) remote: Compressing objects: 16% (14/86) remote: Compressing objects: 17% (15/86) remote: Compressing objects: 18% (16/86) remote: Compressing objects: 19% (17/86) remote: Compressing objects: 20% (18/86) remote: Compressing objects: 22% (19/86) remote: Compressing objects: 23% (20/86) remote: Compressing objects: 24% (21/86) remote: Compressing objects: 25% (22/86) remote: Compressing objects: 26% (23/86) remote: Compressing objects: 27% (24/86) remote: Compressing objects: 29% (25/86) remote: Compressing objects: 30% (26/86) remote: Compressing objects: 31% (27/86) remote: Compressing objects: 32% (28/86) remote: Compressing objects: 33% (29/86) remote: Compressing objects: 34% (30/86) remote: Compressing objects: 36% (31/86) remote: Compressing objects: 37% (32/86) remote: Compressing objects: 38% (33/86) remote: Compressing objects: 39% (34/86) remote: Compressing objects: 40% (35/86) remote: Compressing objects: 41% (36/86) remote: Compressing objects: 43% (37/86) remote: Compressing objects: 44% (38/86) remote: Compressing objects: 45% (39/86) remote: Compressing objects: 46% (40/86) remote: Compressing objects: 47% (41/86) remote: Compressing objects: 48% (42/86) remote: Compressing objects: 50% (43/86) remote: Compressing objects: 51% (44/86) remote: Compressing objects: 52% (45/86) remote: Compressing objects: 53% (46/86) remote: Compressing objects: 54% (47/86) remote: Compressing objects: 55% (48/86) remote: Compressing objects: 56% (49/86) remote: Compressing objects: 58% (50/86) remote: Compressing objects: 59% (51/86) remote: Compressing objects: 60% (52/86) remote: Compressing objects: 61% (53/86) remote: Compressing objects: 62% (54/86) remote: Compressing objects: 63% (55/86) remote: Compressing objects: 65% (56/86) remote: Compressing objects: 66% (57/86) remote: Compressing objects: 67% (58/86) remote: Compressing objects: 68% (59/86) remote: Compressing objects: 69% (60/86) remote: Compressing objects: 70% (61/86) remote: Compressing objects: 72% (62/86) remote: Compressing objects: 73% (63/86) remote: Compressing objects: 74% (64/86) remote: Compressing objects: 75% (65/86) remote: Compressing objects: 76% (66/86) remote: Compressing objects: 77% (67/86) remote: Compressing objects: 79% (68/86) remote: Compressing objects: 80% (69/86) remote: Compressing objects: 81% (70/86) remote: Compressing objects: 82% (71/86) remote: Compressing objects: 83% (72/86) remote: Compressing objects: 84% (73/86) remote: Compressing objects: 86% (74/86) remote: Compressing objects: 87% (75/86) remote: Compressing objects: 88% (76/86) remote: Compressing objects: 89% (77/86) remote: Compressing objects: 90% (78/86) remote: Compressing objects: 91% (79/86) remote: Compressing objects: 93% (80/86) remote: Compressing objects: 94% (81/86) remote: Compressing objects: 95% (82/86) remote: Compressing objects: 96% (83/86) remote: Compressing objects: 97% (84/86) remote: Compressing objects: 98% (85/86) remote: Compressing objects: 100% (86/86) remote: Compressing objects: 100% (86/86), done.
remote: Total 86 (delta 70), reused 0 (delta 0)
From https://git.launchpad.net/epics-base
de442e9..ac4d5c9 3.14 -> origin/3.14
61296b8..c18b6f2 3.15 -> origin/3.15
cd8fd8a..2921414 3.16 -> origin/3.16
eb683aa..1beafdf ca/master -> origin/ca/master
d550b9d..57acac8 core/master -> origin/core/master
a4f0722..0e0a919 database/master -> origin/database/master
dd15a27..ca0149a libcom/master -> origin/libcom/master
* [new tag] R3.14.12.7 -> R3.14.12.7
fatal: bad object 1beafdf7e5633d255bc1776b48b40d0836a1a3b5
fatal: bad object 0e0a919567b0d98f653589ae95bccba769fb0dd8
fatal: bad object ca0149ab92f99b31e15c3df8ccd6db4445997398
fatal: unable to access 'https://github.com/epics-base/pvAccessCPP/': error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
fatal: unable to access 'https://github.com/epics-base/pvDataCPP/': error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
fatal: unable to access 'https://github.com/epics-base/pva2pva/': error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1996)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1715)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:405)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
at hudson.remoting.UserRequest.perform(UserRequest.java:207)
at hudson.remoting.UserRequest.perform(UserRequest.java:53)
at hudson.remoting.Request$2.run(Request.java:358)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-1
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1693)
at hudson.remoting.UserResponse.retrieve(UserRequest.java:310)
at hudson.remoting.Channel.call(Channel.java:908)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.GeneratedMethodAccessor3893.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy96.execute(Unknown Source)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:860)
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-master-windows » DLL,win32 #35 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-test #78 APS Jenkins
Build failed in Jenkins: epics-master-windows » STATIC,win64 #34 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
