2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-sol-test #161
To: [email protected]
Date: Tue, 6 Mar 2018 19:03:32 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/161/display/redirect>
[...truncated 12.95 KB...]
make -C ioc/dbtemplate/test tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test'>
make -C O.solaris-sparc -f ../Makefile TOP=../../../../.. \
    T_A=solaris-sparc tapfiles
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test/O.solaris-sparc'>
perl -CSD msi.t -tap > msi.tap
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/dbtemplate/test'>
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
make -C ./std tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std'>
make -C O.solaris-sparc -f ../Makefile TOP=../../.. \
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/O.solaris-sparc'>
perl -CSD dbLockTest.t -tap > dbLockTest.tap
dbJLinkInit: lexical error: invalid char in json text.
                                  {"x":bbbb}
                     (right here) ------^
dbJLinkInit: parse error: premature EOF
                                       {"z":{"good":6}
make[2]: Nothing to be done for 'tapfiles'.
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std'>
perl -CSD cvtFastTest.t -tap > cvtFastTest.tap
perl -CSD dbStressTest.t -tap > dbStressTest.tap
make -C std/filters/test tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test/O.solaris-sparc'>
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
make -C std/rec/test tapfiles
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test/O.solaris-sparc'>
perl -CSD syncTest.t -tap > syncTest.tap
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/filters/test'>
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD recMiscTest.t -tap > recMiscTest.tap
perl -CSD linkRetargetLinkTest.t -tap > linkRetargetLinkTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD linkInitTest.t -tap > linkInitTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD compressTest.t -tap > compressTest.tap
perl -CSD asyncSoftTest.t -tap > asyncSoftTest.tap
perl -CSD softTest.t -tap > softTest.tap
perl -CSD asTest.t -tap > asTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD regressTest.t -tap > regressTest.tap
dbConvertJSON: parse error: trailing garbage
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/std/rec/test'>
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD osiSockTest.t -tap > osiSockTest.tap
perl -CSD dbCaLinkTest.t -tap > dbCaLinkTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
perl -CSD yajlTest.t -tap > yajlTest.tap
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
rsrv: failed to set mcast ttl 1
epicsThreadRealtimeLock Warning: Unable to lock the virtual address space.
VM page faults may harm real-time performance.
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD dbStaticTest.t -tap > dbStaticTest.tap
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/db/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/ioc/db/test'>
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/libCom/test/O.solaris-sparc'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src/libCom/test'>
make: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-sol-test/ws/src'>
+ make -s test-results
Base.tap ........ ok
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=13, Tests=351,  0 wallclock secs ( 0.10 usr +  0.07 sys =  0.17 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
yajlTest.tap ................. ok
Files=40, Tests=4035,  1 wallclock secs ( 0.58 usr +  0.20 sys =  0.78 CPU)
Result: PASS
dbScanTest.tap ............... ok
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
dbStressTest.tap ............. ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbCaStatsTest.tap ............ ok
dbCaLinkTest.tap ............. ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
dbStaticTest.tap ............. ok
Files=19, Tests=2805,  1 wallclock secs ( 0.43 usr +  0.11 sys =  0.54 CPU)
Result: PASS
msi.tap .. ok
Files=1, Tests=9,  0 wallclock secs ( 0.03 usr +  0.01 sys =  0.04 CPU)
Result: PASS
tsTest.tap .... ok
dbndTest.tap .. ok
arrTest.tap ... ok
syncTest.tap .. ok
Files=4, Tests=1612,  0 wallclock secs ( 0.26 usr +  0.03 sys =  0.29 CPU)
Result: PASS
arrayOpTest.tap ........... ok
recMiscTest.tap ........... ok
linkRetargetLinkTest.tap .. ok
linkInitTest.tap .......... ok
compressTest.tap .......... ok
asyncSoftTest.tap ......... ok
softTest.tap .............. ok
asTest.tap ................
not ok 17 - dbGetString("rec0.OUT") -> 'rec0.DISV' == ''
Failed 1/42 subtests
analogMonitorTest.tap ..... ok
regressTest.tap ........... ok
Test Summary Report
asTest.tap              (Wstat: 0 Tests: 42 Failed: 1)
  Failed test:  17
Files=10, Tests=2502,  0 wallclock secs ( 0.35 usr +  0.06 sys =  0.41 CPU)
Result: FAIL
../../../../../configure/RULES_BUILD:351: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../../configure/RULES_ARCHS:58: recipe for target 'test-results.solaris-sparc' failed
make[2]: *** [test-results.solaris-sparc] Error 2
../configure/RULES_DIRS:84: recipe for target 'std/rec/test.test-results' failed
make[1]: *** [std/rec/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.solaris-sparc/*.tap
Saving reports...
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Jenkins build is back to normal : epics-base-3.16-sol-test #162 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win32-test #154 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win32s-test #162 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.16-win32-test #155 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.16-sol-test #162 APS Jenkins
ANJ, 07 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
