See <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/191/display/redirect>
Started by upstream project "epics-base-3.16-mac" build number 204
originally caused by:
Started by upstream project "epics-base-3.16" build number 207
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/ws/>
[epics-base-3.16-mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/jenkins5171827030424949486.sh
+ make -s clean-tests CROSS_COMPILER_TARGET_ARCHS=
+ ulimit -c unlimited
+ make -sj tapfiles CROSS_COMPILER_TARGET_ARCHS=
log client: connected to log server at "127.0.0.1:55018"
epicsAtomicTest(11890,0x700000081000) malloc: *** error for object 0x7f8b51403ae0: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
epicsAtomicTest(11890,0x700000104000) malloc: *** error for object 0x7f8b51403ae8: incorrect checksum for freed object - object was probably modified after being freed.
/bin/sh: line 1: 11890 Abort trap: 6 perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
chfConfigParseStart: plugin pvt alloc failed
Starting iocInit
Starting iocInit
dbConvertJSON: parse error: trailing garbage
0x10
(right here) ------^
0x10
0x10
0x10
0x10
0x10
0x10
0x10
dbJLinkInit: lexical error: invalid char in json text.
{"x":bbbb}
dbJLinkInit: parse error: premature EOF
{"z":{"good":6}
+ make -s test-results CROSS_COMPILER_TARGET_ARCHS=
Base.tap ........ ok
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=13, Tests=351, 0 wallclock secs ( 0.06 usr 0.01 sys + 0.01 cusr 0.01 csys = 0.09 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap ..........
Failed 29/50 subtests
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
yajlTest.tap ................. ok
Test Summary Report
epicsAtomicTest.tap (Wstat: 0 Tests: 21 Failed: 0)
Parse errors: Bad plan. You planned 50 tests but ran 21.
Files=40, Tests=4006, 1 wallclock secs ( 0.29 usr 0.06 sys + 0.04 cusr 0.06 csys = 0.45 CPU)
Result: FAIL
../../../../configure/RULES_BUILD:356: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../configure/RULES_ARCHS:58: recipe for target 'test-results.darwin-x86' failed
make[2]: *** [test-results.darwin-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'libCom/test.test-results' failed
make[1]: *** [libCom/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.darwin-x86/*.tap
Saving reports...
TAP Reports Processing: FINISH
- Jenkins build is back to normal : epics-base-3.16-mac-test #192 APS Jenkins
Jenkins build became unstable: epics-master » linux32 #46 APS Jenkins
<2018>
2025
2026
Jenkins build is back to stable : epics-master » linux32 #47 APS Jenkins
<2018>
2025
2026
