See <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/193/display/redirect>
Started by upstream project "epics-base-3.16-mac" build number 205
originally caused by:
Started by upstream project "epics-base-3.16" build number 208
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/ws/>
[epics-base-3.16-mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/jenkins6351506805207938704.sh
+ make -s clean-tests CROSS_COMPILER_TARGET_ARCHS=
+ ulimit -c unlimited
+ make -sj tapfiles CROSS_COMPILER_TARGET_ARCHS=
log client: connected to log server at "127.0.0.1:61611"
Starting iocInit
chfConfigParseStart: plugin pvt alloc failed
Starting iocInit
dbConvertJSON: parse error: trailing garbage
0x10
(right here) ------^
0x10
0x10
0x10
0x10
0x10
0x10
0x10
dbJLinkInit: lexical error: invalid char in json text.
{"x":bbbb}
dbJLinkInit: parse error: premature EOF
{"z":{"good":6}
+ make -s test-results CROSS_COMPILER_TARGET_ARCHS=
Base.tap ........ ok
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=13, Tests=351, 0 wallclock secs ( 0.06 usr 0.02 sys + 0.01 cusr 0.01 csys = 0.10 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
yajlTest.tap ................. ok
Files=40, Tests=4035, 1 wallclock secs ( 0.29 usr 0.06 sys + 0.03 cusr 0.05 csys = 0.43 CPU)
Result: PASS
dbScanTest.tap ............... ok
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
dbStressTest.tap ............. ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbCaStatsTest.tap ............ ok
dbCaLinkTest.tap ............. ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
dbStaticTest.tap ............. ok
Files=19, Tests=2805, 0 wallclock secs ( 0.21 usr 0.03 sys + 0.01 cusr 0.02 csys = 0.27 CPU)
Result: PASS
msi.tap .. ok
Files=1, Tests=9, 0 wallclock secs ( 0.02 usr + 0.01 sys = 0.03 CPU)
Result: PASS
tsTest.tap .... ok
dbndTest.tap .. ok
arrTest.tap ... ok
syncTest.tap .. ok
Files=4, Tests=1612, 1 wallclock secs ( 0.12 usr + 0.01 sys = 0.13 CPU)
Result: PASS
arrayOpTest.tap ........... ok
recMiscTest.tap ........... ok
linkRetargetLinkTest.tap .. ok
linkInitTest.tap .......... ok
compressTest.tap .......... ok
asyncSoftTest.tap ......... ok
softTest.tap ..............
not ok 222 - value 0 output -> 1
Failed 1/266 subtests
asTest.tap ................ ok
analogMonitorTest.tap ..... ok
regressTest.tap ........... ok
Test Summary Report
softTest.tap (Wstat: 0 Tests: 266 Failed: 1)
Failed test: 222
Files=10, Tests=2502, 0 wallclock secs ( 0.17 usr 0.02 sys + 0.01 cusr 0.01 csys = 0.21 CPU)
Result: FAIL
../../../../../configure/RULES_BUILD:356: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../../configure/RULES_ARCHS:58: recipe for target 'test-results.darwin-x86' failed
make[2]: *** [test-results.darwin-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'std/rec/test.test-results' failed
make[1]: *** [std/rec/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.darwin-x86/*.tap
Saving reports...
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
- Jenkins build is back to normal : epics-base-3.16-mac-test #194 APS Jenkins
Jenkins build is back to stable : epics-master » linux32 #47 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32-test #158 APS Jenkins
<2018>
2025
2026
Jenkins build is back to normal : epics-base-3.16-mac-test #192 APS Jenkins
<2018>
2025
2026
