2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-test #40
To: [email protected]
Date: Wed, 23 May 2018 02:29:54 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-test/40/display/redirect>
[...truncated 862 B...]
+ make -j4 --no-print-directory junitfiles CROSS_COMPILER_TARGET_ARCHS=
make -C ./configure junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 junitfiles
make[2]: Nothing to be done for 'junitfiles'.
make -C ./src junitfiles
make -C ./tools junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Nothing to be done for 'junitfiles'.
make -C ./makeBaseApp junitfiles
make -C ./makeBaseExt junitfiles
make -C ./libCom junitfiles
make -C ./toolsComm junitfiles
make -C ./ca junitfiles
make -C ./RTEMS junitfiles
make -C ./antelope junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make -C ./base junitfiles
make -C ./util junitfiles
make -C ./gdd junitfiles
make[4]: Nothing to be done for 'junitfiles'.
make -C ./flex junitfiles
make -C libCom/test junitfiles
make -C ./dbStatic junitfiles
perl epicsUnitTestTest.t -tap > epicsUnitTestTest.tap
perl epicsCalcTest.t -tap > epicsCalcTest.tap
perl epicsAlgorithmTest.t -tap > epicsAlgorithmTest.tap
perl epicsMathTest.t -tap > epicsMathTest.tap
perl epicsEllTest.t -tap > epicsEllTest.tap
perl epicsEnvTest.t -tap > epicsEnvTest.tap
perl epicsErrlogTest.t -tap > epicsErrlogTest.tap
perl epicsStdioTest.t -tap > epicsStdioTest.tap
perl epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
perl epicsStringTest.t -tap > epicsStringTest.tap
make -C ./registry junitfiles
perl epicsTimeTest.t -tap > epicsTimeTest.tap
make -C ./bpt junitfiles
perl epicsTimeZoneTest.t -tap > epicsTimeZoneTest.tap
perl epicsThreadTest.t -tap > epicsThreadTest.tap
perl epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
make -C ./catools junitfiles
Recursive epicsThreadOnce() initialization
Thread recurse (0xac2840) can't proceed, suspending.
make -C ./cas junitfiles
make -C ./build junitfiles
make -C ./example junitfiles
make -C ./directoryService junitfiles
make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
make[5]: Nothing to be done for 'junitfiles'.
make -C ./cap5 junitfiles
make -C ./db junitfiles
make -C ./as junitfiles
perl epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
make -C ./dbtools junitfiles
make -C ./rsrv junitfiles
make -C ./rec junitfiles
make -C db/test junitfiles
perl callbackTest.t -tap > callbackTest.tap
perl epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
perl epicsExitTest.t -tap > epicsExitTest.tap
perl epicsTimerTest.t -tap > epicsTimerTest.tap
perl ringPointerTest.t -tap > ringPointerTest.tap
perl ringBytesTest.t -tap > ringBytesTest.tap
perl epicsEventTest.t -tap > epicsEventTest.tap
perl epicsMutexTest.t -tap > epicsMutexTest.tap
perl macEnvExpandTest.t -tap > macEnvExpandTest.tap
macLib: macro FOO is undefined (expanding string ${FOO})
macLib: macro FOO is undefined (expanding string ${FOO,BAR})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=$(FOO)})
macLib: macro FOO is undefined (expanding string ${FOO,FOO})
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding macro FOO)
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz,FUM})
macLib: macro BAZ is undefined (expanding string ${FOO})
macLib: string ${FOO} is recursive (expanding environment variable FOO)
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding environment variable FOO)
perl macLibTest.t -tap > macLibTest.tap
perl taskwdTest.t -tap > taskwdTest.tap
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output callbackTest.xml --input callbackTest.tap callbackTest
make -C ./excas junitfiles
make -C ./misc junitfiles
perl blockingSockTest.t -tap > blockingSockTest.tap
make -C ./dev junitfiles
make -C ./softDev junitfiles
make -C ./testDev junitfiles
perl epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
Thread testTask2 (0xdd2690) suspended
perl ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
make -C ./vxWorks junitfiles
make -C ./softIoc junitfiles
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsUnitTestTest.xml --input epicsUnitTestTest.tap epicsUnitTestTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsCalcTest.xml --input epicsCalcTest.tap epicsCalcTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsAlgorithmTest.xml --input epicsAlgorithmTest.tap epicsAlgorithmTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsMathTest.xml --input epicsMathTest.tap epicsMathTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsEllTest.xml --input epicsEllTest.tap epicsEllTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsEnvTest.xml --input epicsEnvTest.tap epicsEnvTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsErrlogTest.xml --input epicsErrlogTest.tap epicsErrlogTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsStdioTest.xml --input epicsStdioTest.tap epicsStdioTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsSockResolveTest.xml --input epicsSockResolveTest.tap epicsSockResolveTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsStringTest.xml --input epicsStringTest.tap epicsStringTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsTimeTest.xml --input epicsTimeTest.tap epicsTimeTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsTimeZoneTest.xml --input epicsTimeZoneTest.tap epicsTimeZoneTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadTest.xml --input epicsThreadTest.tap epicsThreadTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadOnceTest.xml --input epicsThreadOnceTest.tap epicsThreadOnceTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadPriorityTest.xml --input epicsThreadPriorityTest.tap epicsThreadPriorityTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsThreadPrivateTest.xml --input epicsThreadPrivateTest.tap epicsThreadPrivateTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsExitTest.xml --input epicsExitTest.tap epicsExitTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsTimerTest.xml --input epicsTimerTest.tap epicsTimerTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output ringPointerTest.xml --input ringPointerTest.tap ringPointerTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output ringBytesTest.xml --input ringBytesTest.tap ringBytesTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsEventTest.xml --input epicsEventTest.tap epicsEventTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsMutexTest.xml --input epicsMutexTest.tap epicsMutexTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output macEnvExpandTest.xml --input macEnvExpandTest.tap macEnvExpandTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output macLibTest.xml --input macLibTest.tap macLibTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output blockingSockTest.xml --input blockingSockTest.tap blockingSockTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output ipAddrToAsciiTest.xml --input ipAddrToAsciiTest.tap ipAddrToAsciiTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output taskwdTest.xml --input taskwdTest.tap taskwdTest
perl ../../../../bin/linux-x86_64/tap-to-junit-xml.pl --puretap --output epicsMessageQueueTest.xml --input epicsMessageQueueTest.tap epicsMessageQueueTest
+ make -s test-results CROSS_COMPILER_TARGET_ARCHS=
epicsUnitTestTest.tap ........ ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap ..........
not ok  6 - pvt.count (1) == 2 (2)
not ok  7 - pvt2.count (0) == 1 (1)
Failed 2/25 subtests
epicsStdioTest.tap ........... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
macEnvExpandTest.tap ......... ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
ipAddrToAsciiTest.tap ........ ok
Test Summary Report
epicsErrlogTest.tap        (Wstat: 0 Tests: 25 Failed: 2)
  Failed tests:  6-7
Files=28, Tests=2298,  0 wallclock secs ( 0.20 usr  0.02 sys +  0.01 cusr  0.02 csys =  0.25 CPU)
Result: FAIL
../../../../configure/RULES_BUILD:360: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../configure/RULES_ARCHS:61: recipe for target 'test-results.linux-x86_64' failed
make[2]: *** [test-results.linux-x86_64] Error 2
../configure/RULES_DIRS:83: recipe for target 'libCom/test.test-results' failed
make[1]: *** [libCom/test.test-results] Error 2
configure/RULES_DIRS:83: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
Recording test results
Jenkins build is back to normal : epics-base-3.14-test #41 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.14-win64s #245 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.14-test #41 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.14-win32 #279 APS Jenkins
ANJ, 24 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
