Subject: |
Build failed in Jenkins: epics-7.0-windows » STATIC,win32 #48 |
APS Jenkins <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 21 Jun 2018 15:16:38 -0500 (CDT) |
See <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win32/48/display/redirect>
Started by upstream project "epics-7.0-windows" build number 48
originally caused by:
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win32/ws/>
> C:/Program Files/Git/bin/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files/Git/bin/git.exe config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
> C:/Program Files/Git/bin/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
Checking out Revision 1b6ec2676cad32846158fa85a8fb6cd87a6da412 (refs/remotes/origin/7.0)
> C:/Program Files/Git/bin/git.exe config core.sparsecheckout # timeout=10
> C:/Program Files/Git/bin/git.exe checkout -f 1b6ec2676cad32846158fa85a8fb6cd87a6da412
Commit message: "Document branch recombination"
> C:/Program Files/Git/bin/git.exe rev-list --no-walk 1b6ec2676cad32846158fa85a8fb6cd87a6da412 # timeout=10
Cleaning workspace
> C:/Program Files/Git/bin/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files/Git/bin/git.exe reset --hard # timeout=10
> C:/Program Files/Git/bin/git.exe clean -fdx # timeout=10
> C:/Program Files/Git/bin/git.exe submodule foreach --recursive git reset --hard # timeout=10
> C:/Program Files/Git/bin/git.exe submodule foreach git clean -fdx # timeout=10
FATAL: Command "C:/Program Files/Git/bin/git.exe submodule foreach git clean -fdx" returned status code 1:
stdout: Entering 'modules/normativeTypes'
Entering 'modules/pvAccess'
Entering 'modules/pvData'
Entering 'modules/pvDatabase'
Entering 'modules/pva2pva'
stderr: warning: failed to remove testApp/O.win32-x86-static/: Permission denied
Stopping at 'modules/pva2pva'; script returned non-zero status.
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-1
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserResponse.retrieve(UserRequest.java:389)
at hudson.remoting.Channel.call(Channel.java:955)
at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
at com.sun.proxy.$Proxy97.submoduleClean(Unknown Source)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl.submoduleClean(RemoteGitImpl.java:650)
at hudson.plugins.git.extensions.impl.SubmoduleOption.onClean(SubmoduleOption.java:86)
at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:33)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1264)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1794)
at hudson.matrix.MatrixRun.run(MatrixRun.java:153)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
hudson.plugins.git.GitException: Command "C:/Program Files/Git/bin/git.exe submodule foreach git clean -fdx" returned status code 1:
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2002)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1970)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1966)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1597)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.submoduleClean(CliGitAPIImpl.java:1200)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:922)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:896)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:853)
at hudson.remoting.UserRequest.perform(UserRequest.java:207)
at hudson.remoting.UserRequest.perform(UserRequest.java:53)
at hudson.remoting.Request$2.run(Request.java:358)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-7.0-windows » STATIC,win32 #49 APS Jenkins
- Build failed in Jenkins: epics-7.0-windows » STATIC,win32 #47 APS Jenkins
Build failed in Jenkins: epics-7.0-windows » DLL, win64 #47 APS Jenkins
Build failed in Jenkins: epics-7.0-windows » DLL, win32 #48 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
ANJ, 27 Jun 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
