2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-win64 #257
To: [email protected]
Date: Tue, 31 Jul 2018 17:49:06 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/257/display/redirect>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
 > C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url lp:epics-base # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from lp:epics-base
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:888)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1155)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
	at hudson.scm.SCM.checkout(SCM.java:504)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
	at hudson.model.Run.execute(Run.java:1794)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:97)
	at hudson.model.Executor.run(Executor.java:429)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe clean -fdx" returned status code 1:
stdout: Removing bin/
Removing configure/O.Common/
Removing configure/O.windows-x64-static/
Removing configure/O.windows-x64/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing src/RTEMS/base/O.Common/
Removing src/RTEMS/base/O.windows-x64-static/
Removing src/RTEMS/base/O.windows-x64/
Removing src/as/O.Common/
Removing src/as/O.windows-x64-static/
Removing src/as/O.windows-x64/
Removing src/bpt/O.Common/
Removing src/bpt/O.windows-x64-static/
Removing src/bpt/O.windows-x64/
Removing src/ca/O.Common/
Removing src/ca/O.windows-x64-static/
Removing src/ca/O.windows-x64/
Removing src/cap5/O.Common/
Removing src/cap5/O.windows-x64-static/
Removing src/cap5/O.windows-x64/
Removing src/cas/build/O.Common/
Removing src/cas/build/O.windows-x64-static/
Removing src/cas/build/O.windows-x64/
Removing src/cas/example/directoryService/O.Common/
Removing src/cas/example/directoryService/O.windows-x64-static/
Removing src/cas/example/directoryService/O.windows-x64/
Removing src/catools/O.Common/
Removing src/catools/O.windows-x64-static/
Removing src/catools/O.windows-x64/
Removing src/db/O.Common/
Removing src/db/O.windows-x64-static/
Removing src/db/O.windows-x64/
Removing src/db/test/O.Common/
Removing src/db/test/O.windows-x64-static/
Removing src/db/test/O.windows-x64/
Removing src/dbStatic/O.Common/
Removing src/dbStatic/O.windows-x64-static/
Removing src/dbStatic/O.windows-x64/
Removing src/dbtools/O.Common/
Removing src/dbtools/O.windows-x64-static/
Removing src/dbtools/O.windows-x64/
Removing src/dev/softDev/O.Common/
Removing src/dev/softDev/O.windows-x64-static/
Removing src/dev/softDev/O.windows-x64/
Removing src/dev/testDev/O.Common/
Removing src/dev/testDev/O.windows-x64-static/
Removing src/dev/testDev/O.windows-x64/
Removing src/excas/O.Common/
Removing src/excas/O.windows-x64-static/
Removing src/excas/O.windows-x64/
Removing src/gdd/O.Common/
Removing src/gdd/O.windows-x64-static/
Removing src/gdd/O.windows-x64/
Removing src/libCom/O.Common/
Removing src/libCom/O.windows-x64-static/
Removing src/libCom/O.windows-x64/
Removing src/libCom/test/O.Common/
Removing src/libCom/test/O.windows-x64-static/
Removing src/libCom/test/O.windows-x64/
Removing src/makeBaseApp/O.Common/
Removing src/makeBaseApp/O.windows-x64-static/
Removing src/makeBaseApp/O.windows-x64/
Removing src/makeBaseExt/O.Common/
Removing src/makeBaseExt/O.windows-x64-static/
Removing src/makeBaseExt/O.windows-x64/
Removing src/misc/O.Common/
Removing src/misc/O.windows-x64-static/
Removing src/misc/O.windows-x64/
Removing src/rec/O.Common/
Removing src/rec/O.windows-x64-static/
Removing src/rec/O.windows-x64/
Removing src/registry/O.Common/
Removing src/registry/O.windows-x64-static/
Removing src/registry/O.windows-x64/
Removing src/rsrv/O.Common/
Removing src/rsrv/O.windows-x64-static/
Removing src/rsrv/O.windows-x64/
Removing src/softIoc/O.Common/
Removing src/softIoc/O.windows-x64-static/
Removing src/softIoc/O.windows-x64/
Removing src/tools/O.Common/
Removing src/tools/O.windows-x64-static/
Removing src/tools/O.windows-x64/
Removing src/toolsComm/antelope/O.Common/
Removing src/toolsComm/antelope/O.windows-x64-static/
Removing src/toolsComm/antelope/O.windows-x64/
Removing src/toolsComm/flex/O.Common/
Removing src/toolsComm/flex/O.windows-x64-static/
Removing src/toolsComm/flex/O.windows-x64/
Removing src/util/O.Common/
Removing src/util/O.windows-x64-static/
Removing src/util/O.windows-x64/
Removing src/vxWorks/O.Common/
Removing src/vxWorks/O.windows-x64-static/
Removing src/vxWorks/O.windows-x64/
Removing templates/makeBaseApp/top/supportApp/Db
Removing templates/makeBaseApp/top/supportApp/Makefile
Removing templates/makeBaseApp/top/supportApp/src
Removing templates/makeBaseApp/top/caClientApp
Removing templates/makeBaseApp/top/caServerApp
Removing templates/makeBaseApp/top/configure
Removing templates/makeBaseApp/top/exampleApp
Removing templates/makeBaseApp/top/exampleBoot
Removing templates/makeBaseApp/top/iocApp
Removing templates/makeBaseApp/top/iocBoot
Removing templates/makeBaseApp/top/Makefile
Removing templates/makeBaseExt
stderr: warning: failed to remove templates/makeBaseApp/top/supportApp: Directory not empty
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2002)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1970)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1966)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1597)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1609)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:787)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:922)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:896)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:853)
	at hudson.remoting.UserRequest.perform(UserRequest.java:207)
	at hudson.remoting.UserRequest.perform(UserRequest.java:53)
	at hudson.remoting.Request$2.run(Request.java:358)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-1
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
		at hudson.remoting.UserResponse.retrieve(UserRequest.java:389)
		at hudson.remoting.Channel.call(Channel.java:955)
		at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
		at com.sun.proxy.$Proxy93.clean(Unknown Source)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
		at hudson.plugins.git.extensions.impl.CleanBeforeCheckout.decorateFetchCommand(CleanBeforeCheckout.java:30)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:884)
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.14-win64 #258 APS Jenkins
Build failed in Jenkins: epics-base-3.14-win64 #256 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-win64s #253 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.14-win64 #258 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.14-win64 #256 APS Jenkins
ANJ, 31 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
