See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/260/display/redirect>
Started by upstream project "epics-base-3.14" build number 299
originally caused by:
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
> C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files/Git/cmd/git.exe config remote.origin.url lp:epics-base # timeout=10
Cleaning workspace
> C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
> C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from lp:epics-base
> C:/Program Files/Git/cmd/git.exe --version # timeout=10
using GIT_SSH to set credentials Jenkins account SSH key
> C:/Program Files/Git/cmd/git.exe fetch --tags --progress lp:epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from lp:epics-base
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:888)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1155)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1798)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe fetch --tags --progress lp:epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1735)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:420)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
at hudson.remoting.UserRequest.perform(UserRequest.java:207)
at hudson.remoting.UserRequest.perform(UserRequest.java:53)
at hudson.remoting.Request$2.run(Request.java:358)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-1
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserResponse.retrieve(UserRequest.java:389)
at hudson.remoting.Channel.call(Channel.java:955)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy95.execute(Unknown Source)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:886)
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : epics-base-3.14-win64 #261 APS Jenkins
Core Developers Telecon on the hour Andrew Johnson
Build failed in Jenkins: epics-base-3.14-ios #198 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
