2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Travis emails?
To: Andrew Johnson <[email protected]>, EPICS core-talk <[email protected]>
Date: Fri, 14 Sep 2018 16:04:31 -0700
On 09/14/2018 02:10 PM, Andrew Johnson wrote:
> So why hasn't Travis been sending me emails about the broken epics-base
> builds that I've been pushing? It's a shame that the final 3.14.12.8
> build failed on Travis, but I'm not going to fix it and re-tag. I
> assumed that the absence of emails from it was an indication of no build
> problems, but no... (I haven't even checked Appveyor).
> I really don't understand how/when Travis (and Appveyor for that matter)
> decide when they should email me; can anyone explain where/how I should
> change my settings to ensure that it does?
https://docs.travis-ci.com/user/notifications/
maybe @anl.gov is treating these as spam?
> Travis CI only sends build notifications to email addresses registered on GitHub
Or maybe you've given github.com a different primary email?
> The most common cause for not receiving build notifications ...
> is the use of an email address that’s not registered and verified on GitHub
> If there’s a setting specified, Travis CI only sends an emails to the addresses specified there, rather than to the committer and author.
FYI, I've avoided configuring email notifications via .travis.yml because of
I find this behavior unhelpful in the case pull requests, when the author/committer
should find out first.
Re: Travis emails? Johnson, Andrew N.
Travis emails? Andrew Johnson
Prev: Travis emails? Andrew Johnson
Next: Re: Travis emails? Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
