2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in mbbo and mbbi records in Base 7.0
Date: Mon, 24 Sep 2018 22:59:30 +0000
Just a heads up that I found there is a bug in the mbbo and mbbi records in 7.0 today.  The problem is that one cannot modify the ZRVL through FFVL fields at run-time, which is a problem on our beamlines.
Andrew found the problem in the special() functions in these records and should have a patch soon.
Re: Bug in mbbo and mbbi records in Base 7.0 Johnson, Andrew N.
Prev: Build failed in Jenkins: EPICS-7 #109 Jenkins Epics PSI
Next: Re: Bug in mbbo and mbbi records in Base 7.0 Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-7 #114 Jenkins Epics PSI
ANJ, 29 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
