See <http://gfa-sls2-test:8080/job/EPICS-7/130/display/redirect>
[...truncated 1.36 MB...]
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > logMsgToErrlog.d ../../src/osi/os/vxWorks/logMsgToErrlog.cpp
/bin/sh: /afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc: No such file or directory
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > veclist.d ../../src/osi/os/vxWorks/veclist.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsDynLink.d ../../src/osi/os/vxWorks/epicsDynLink.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > atReboot.d ../../src/osi/os/vxWorks/atReboot.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osiNTPTime.d ../../src/osi/osiNTPTime.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > yajl_parser.d ../../src/yajl/yajl_parser.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > yajl_lex.d ../../src/yajl/yajl_lex.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > yajl_gen.d ../../src/yajl/yajl_gen.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > yajl_encode.d ../../src/yajl/yajl_encode.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > yajl_buf.d ../../src/yajl/yajl_buf.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > yajl_alloc.d ../../src/yajl/yajl_alloc.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > yajl.d ../../src/yajl/yajl.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > timerQueuePassive.d ../../src/timer/timerQueuePassive.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > timerQueueActiveMgr.d ../../src/timer/timerQueueActiveMgr.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > timerQueueActive.d ../../src/timer/timerQueueActive.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > timerQueue.d ../../src/timer/timerQueue.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > timer.d ../../src/timer/timer.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsTimer.d ../../src/timer/epicsTimer.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > taskwd.d ../../src/taskwd/taskwd.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsRingBytes.d ../../src/ring/epicsRingBytes.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsRingPointer.d ../../src/ring/epicsRingPointer.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > threadPool.d ../../src/pool/threadPool.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > poolJob.d ../../src/pool/poolJob.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdFindAddr.d ../../src/osi/os/default/osdFindAddr.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdBackTrace.d ../../src/osi/os/default/osdBackTrace.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsStackTrace.d ../../src/osi/epicsStackTrace.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > devLibVMEOSD.d ../../src/osi/os/vxWorks/devLibVMEOSD.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > devLibVME.d ../../src/osi/devLibVME.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdMessageQueue.d ../../src/osi/os/vxWorks/osdMessageQueue.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdNetIntf.d ../../src/osi/os/default/osdNetIntf.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdProcess.d ../../src/osi/os/vxWorks/osdProcess.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdMonotonic.d ../../src/osi/os/vxWorks/osdMonotonic.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdTime.d ../../src/osi/os/vxWorks/osdTime.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdEvent.d ../../src/osi/os/vxWorks/osdEvent.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdSpin.d ../../src/osi/os/vxWorks/osdSpin.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdMutex.d ../../src/osi/os/vxWorks/osdMutex.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdThreadHooks.d ../../src/osi/os/default/osdThreadHooks.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdThreadExtra.d ../../src/osi/os/vxWorks/osdThreadExtra.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdThread.d ../../src/osi/os/vxWorks/osdThread.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdStdio.d ../../src/osi/os/vxWorks/osdStdio.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsStdio.d ../../src/osi/epicsStdio.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsTempFile.d ../../src/osi/os/posix/epicsTempFile.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_LEDLIB -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsReadline.d ../../src/osi/epicsReadline.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdEnv.d ../../src/osi/os/vxWorks/osdEnv.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdSignal.d ../../src/osi/os/vxWorks/osdSignal.cpp
/bin/sh: /afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc: No such file or directory
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdPoolStatus.d ../../src/osi/os/vxWorks/osdPoolStatus.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdInterrupt.d ../../src/osi/os/vxWorks/osdInterrupt.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdFindSymbol.d ../../src/osi/os/vxWorks/osdFindSymbol.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdAssert.d ../../src/osi/os/default/osdAssert.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsSocketConvertErrnoToString.d ../../src/osi/os/default/epicsSocketConvertErrnoToString.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > systemCallIntMech.d ../../src/osi/os/posix/systemCallIntMech.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osiSock.d ../../src/osi/osiSock.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdSockAddrReuse.d ../../src/osi/os/posix/osdSockAddrReuse.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osdSock.d ../../src/osi/os/vxWorks/osdSock.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > osiClockTime.d ../../src/osi/osiClockTime.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsGeneralTime.d ../../src/osi/epicsGeneralTime.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsAtomicOSD.d ../../src/osi/os/vxWorks/epicsAtomicOSD.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsMath.d ../../src/osi/epicsMath.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsMessageQueue.d ../../src/osi/epicsMessageQueue.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsTime.d ../../src/osi/epicsTime.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsEvent.d ../../src/osi/epicsEvent.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsMutex.d ../../src/osi/epicsMutex.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsThread.d ../../src/osi/epicsThread.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsUnitTest.d ../../src/misc/epicsUnitTest.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > ipAddrToAsciiAsynchronous.d ../../src/misc/ipAddrToAsciiAsynchronous.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > truncateFile.d ../../src/misc/truncateFile.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsString.d ../../src/misc/epicsString.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsStdlib.d ../../src/misc/epicsStdlib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsExit.d ../../src/misc/epicsExit.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsConvert.d ../../src/misc/epicsConvert.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > cantProceed.d ../../src/misc/cantProceed.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > adjustment.d ../../src/misc/adjustment.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > aToIPAddr.d ../../src/misc/aToIPAddr.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > alarmString.d ../../src/misc/alarmString.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > macUtil.d ../../src/macLib/macUtil.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > macEnv.d ../../src/macLib/macEnv.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > macCore.d ../../src/macLib/macCore.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > logClient.d ../../src/log/logClient.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > iocLog.d ../../src/log/iocLog.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > libComRegister.d ../../src/iocsh/libComRegister.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > registry.d ../../src/iocsh/registry.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > iocsh.d ../../src/iocsh/iocsh.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > gpHashLib.d ../../src/gpHash/gpHashLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > freeListLib.d ../../src/freeList/freeListLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > fdManager.d ../../src/fdmgr/fdManager.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > fdmgr.d ../../src/fdmgr/fdmgr.cpp
perl -CSD ../../src/error/makeStatTbl.pl ../../src/osi/devLib.h ../../src/osi/epicsTime.h ../../src/as/asLib.h ../../src/misc/epicsStdlib.h ../../src/pool/epicsThreadPool.h ../../src/error/errMdef.h
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > errSymTbl.d errSymTbl.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > errSymLib.d ../../src/error/errSymLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > errlog.d ../../src/error/errlog.c
/bin/sh: /afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc: No such file or directory
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/bldEnvData.pl> -t T2-ppc604 \
-c gcc -s vxWorks <http://gfa-sls2-test:8080/job/EPICS-7/ws/configure>
Generating envData.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > envData.d envData.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > envSubr.d ../../src/env/envSubr.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > ellSort.d ../../src/ellLib/ellSort.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > ellLib.d ../../src/ellLib/ellLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > dbmf.d ../../src/dbmf/dbmf.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > epicsSingletonMutex.d ../../src/cxxTemplates/epicsSingletonMutex.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > resourceLib.d ../../src/cxxTemplates/resourceLib.cpp
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > cvtFast.d ../../src/cvtFast/cvtFast.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > calcPerform.d ../../src/calc/calcPerform.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > postfix.d ../../src/calc/postfix.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > bucketLib.d ../../src/bucketLib/bucketLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > asTrapWrite.d ../../src/as/asTrapWrite.c
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/e_flex> -S<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/flex.skel.static> -8 -I -t ../../src/as/asLib_lex.l > asLib_lex.yy.c
mv asLib_lex.yy.c asLib_lex.c
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -basLib ../../src/as/asLib.y
mv asLib.tab.c asLib.c
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -MM > asLib.d asLib.c
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osiFileName.h>
mkdir <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdSock.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdInterrupt.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdMutex.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdEvent.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/epicsMath.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdMessageQueue.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdStrtod.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdPoolStatus.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdThread.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdTime.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osiUnistd.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdWireFormat.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdWireConfig.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/epicsAtomicOSD.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/epicsGetopt.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/osdVME.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/epicsMMIO.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/epicsMMIODef.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/camacLib.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/epicsDynLink.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/module_types.h>
Installing OS dependent include file <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks/task_params.h>
/afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/vxWorks.h -O0 -Wall -mlongcall -fno-builtin -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/vxWorks -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h -I/afs/psi.ch/project/vxworks/Tornado2.2.1/vxworks-5.5.1/target/h/wrn/coreip -c ../../src/osi/os/vxWorks/vxComLibrary.c
make[4]: /afs/psi.ch/project/vxworks/Tornado2.2.1/gnu/-vxworks-5.5.1/x86-linux2/bin/ccppc: Command not found
make[4]: *** [vxComLibrary.o] Error 127
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.T2-ppc604'>
make[3]: *** [install.T2-ppc604] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src'>
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom'>
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : EPICS-7 #131 Jenkins EPICS PSI
- Build failed in Jenkins: EPICS-7 #129 Jenkins EPICS PSI
<2018>
2025
2026
<2018>
2025
2026
