Subject: |
Build failed in Jenkins: epics-base-3.16-cyg64 #235 |
APS Jenkins via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 25 Oct 2018 15:24:16 -0500 (CDT) |
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/235/display/redirect>
[...truncated 6.70 KB...]
Removing src/ioc/O.cygwin-x86_64/epicsRelease.d
Removing src/ioc/O.cygwin-x86_64/initHooks.d
Removing src/ioc/O.cygwin-x86_64/initHooks.obj
Removing src/ioc/O.cygwin-x86_64/iocInit.d
Removing src/ioc/O.cygwin-x86_64/iocshRegisterCommon.d
Removing src/ioc/O.cygwin-x86_64/makeBpt.d
Removing src/ioc/O.cygwin-x86_64/makeBpt.obj
Removing src/ioc/O.cygwin-x86_64/Makefile
Removing src/ioc/O.cygwin-x86_64/menuAlarmSevr.dbd.d
Removing src/ioc/O.cygwin-x86_64/menuAlarmSevr.h.d
Removing src/ioc/O.cygwin-x86_64/menuAlarmStat.h.d
Removing src/ioc/O.cygwin-x86_64/menuConvert.dbd.d
Removing src/ioc/O.cygwin-x86_64/menuConvert.h.d
Removing src/ioc/O.cygwin-x86_64/menuFtype.h.d
Removing src/ioc/O.cygwin-x86_64/menuIvoa.h.d
Removing src/ioc/O.cygwin-x86_64/menuOmsl.h.d
Removing src/ioc/O.cygwin-x86_64/menuPini.h.d
Removing src/ioc/O.cygwin-x86_64/menuPost.h.d
Removing src/ioc/O.cygwin-x86_64/menuPriority.h.d
Removing src/ioc/O.cygwin-x86_64/menuScan.h.d
Removing src/ioc/O.cygwin-x86_64/menuSimm.dbd.d
Removing src/ioc/O.cygwin-x86_64/menuSimm.h.d
Removing src/ioc/O.cygwin-x86_64/menuYesNo.h.d
Removing src/ioc/O.cygwin-x86_64/miscIocRegister.d
Removing src/ioc/O.cygwin-x86_64/msi.d
Removing src/ioc/O.cygwin-x86_64/online_notify.d
Removing src/ioc/O.cygwin-x86_64/recGbl.d
Removing src/ioc/O.cygwin-x86_64/recGbl.obj
Removing src/ioc/O.cygwin-x86_64/registryCommon.d
Removing src/ioc/O.cygwin-x86_64/registryDeviceSupport.d
Removing src/ioc/O.cygwin-x86_64/registryDriverSupport.d
Removing src/ioc/O.cygwin-x86_64/registryFunction.d
Removing src/ioc/O.cygwin-x86_64/registryIocRegister.d
Removing src/ioc/O.cygwin-x86_64/registryJLinks.d
Removing src/ioc/O.cygwin-x86_64/registryRecordType.d
Removing src/ioc/O.cygwin-x86_64/rsrvIocRegister.d
Removing src/libCom/O.Common/
Removing src/libCom/O.cygwin-x86_64/
Removing src/libCom/RTEMS/O.Common/
Removing src/libCom/RTEMS/O.cygwin-x86_64/
Removing src/libCom/test/O.Common/
Removing src/libCom/test/O.cygwin-x86_64/
Removing src/template/base/O.Common/
Removing src/template/base/O.cygwin-x86_64/
Removing src/template/ext/O.Common/
Removing src/template/ext/O.cygwin-x86_64/
Removing src/tools/O.Common/
Removing src/tools/O.cygwin-x86_64/
Removing src/tools/test/O.Common/
Removing src/tools/test/O.cygwin-x86_64/
Removing templates/
stderr: warning: failed to remove src/ioc/O.cygwin-x86_64/: Directory not empty
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to cyg64-1
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:955)
at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
at com.sun.proxy.$Proxy95.clean(Unknown Source)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:30)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1264)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1798)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
hudson.plugins.git.GitException: Command "git clean -fdx" returned status code 1:
stdout: Removing bin/
Removing configure/O.Common/
Removing configure/O.cygwin-x86_64/
Removing html/
Removing include/
Removing lib/
Removing src/ca/client/O.Common/
Removing src/ca/client/O.cygwin-x86_64/
Removing src/ca/client/tools/O.Common/
Removing src/ca/client/tools/O.cygwin-x86_64/
Removing src/ca/legacy/gdd/O.Common/
Removing src/ca/legacy/gdd/O.cygwin-x86_64/
Removing src/ca/legacy/pcas/build/O.Common/
Removing src/ca/legacy/pcas/build/O.cygwin-x86_64/
Removing src/ca/legacy/pcas/example/directoryService/O.Common/
Removing src/ca/legacy/pcas/example/directoryService/O.cygwin-x86_64/
Removing src/ioc/O.Common/
Removing src/ioc/O.cygwin-x86_64/asCa.d
Removing src/ioc/O.cygwin-x86_64/asCa.obj
Removing src/ioc/O.cygwin-x86_64/ascheck.d
Removing src/ioc/O.cygwin-x86_64/asDbLib.d
Removing src/ioc/O.cygwin-x86_64/asDbLib.obj
Removing src/ioc/O.cygwin-x86_64/asIocRegister.d
Removing src/ioc/O.cygwin-x86_64/asIocRegister.obj
Removing src/ioc/O.cygwin-x86_64/callback.d
Removing src/ioc/O.cygwin-x86_64/callback.obj
Removing src/ioc/O.cygwin-x86_64/camessage.d
Removing src/ioc/O.cygwin-x86_64/camsgtask.d
Removing src/ioc/O.cygwin-x86_64/caserverio.d
Removing src/ioc/O.cygwin-x86_64/caservertask.d
Removing src/ioc/O.cygwin-x86_64/cast_server.d
Removing src/ioc/O.cygwin-x86_64/chfPlugin.d
Removing src/ioc/O.cygwin-x86_64/cvtBpt.d
Removing src/ioc/O.cygwin-x86_64/cvtBpt.obj
Removing src/ioc/O.cygwin-x86_64/dbAccess.d
Removing src/ioc/O.cygwin-x86_64/dbAccess.obj
Removing src/ioc/O.cygwin-x86_64/dbBkpt.d
Removing src/ioc/O.cygwin-x86_64/dbBkpt.obj
Removing src/ioc/O.cygwin-x86_64/dbCa.d
Removing src/ioc/O.cygwin-x86_64/dbCa.obj
Removing src/ioc/O.cygwin-x86_64/dbCaTest.d
Removing src/ioc/O.cygwin-x86_64/dbCaTest.obj
Removing src/ioc/O.cygwin-x86_64/dbChannel.d
Removing src/ioc/O.cygwin-x86_64/dbChannel.obj
Removing src/ioc/O.cygwin-x86_64/dbChannelIO.d
Removing src/ioc/O.cygwin-x86_64/dbChannelIO.obj
Removing src/ioc/O.cygwin-x86_64/dbCommon.h.d
Removing src/ioc/O.cygwin-x86_64/dbConstLink.d
Removing src/ioc/O.cygwin-x86_64/dbConstLink.obj
Removing src/ioc/O.cygwin-x86_64/dbContext.d
Removing src/ioc/O.cygwin-x86_64/dbContext.obj
Removing src/ioc/O.cygwin-x86_64/dbContextReadNotifyCache.d
Removing src/ioc/O.cygwin-x86_64/dbConvert.d
Removing src/ioc/O.cygwin-x86_64/dbConvert.obj
Removing src/ioc/O.cygwin-x86_64/dbConvertJSON.d
Removing src/ioc/O.cygwin-x86_64/dbConvertJSON.obj
Removing src/ioc/O.cygwin-x86_64/dbDbLink.d
Removing src/ioc/O.cygwin-x86_64/dbDbLink.obj
Removing src/ioc/O.cygwin-x86_64/dbEvent.d
Removing src/ioc/O.cygwin-x86_64/dbEvent.obj
Removing src/ioc/O.cygwin-x86_64/dbExtractArray.d
Removing src/ioc/O.cygwin-x86_64/dbExtractArray.obj
Removing src/ioc/O.cygwin-x86_64/dbFastLinkConv.d
Removing src/ioc/O.cygwin-x86_64/dbFastLinkConv.obj
Removing src/ioc/O.cygwin-x86_64/dbIocRegister.d
Removing src/ioc/O.cygwin-x86_64/dbJLink.d
Removing src/ioc/O.cygwin-x86_64/dbJLink.obj
Removing src/ioc/O.cygwin-x86_64/dbLex.c
Removing src/ioc/O.cygwin-x86_64/dbLink.d
Removing src/ioc/O.cygwin-x86_64/dbLink.obj
Removing src/ioc/O.cygwin-x86_64/dbLoadTemplate.c
Removing src/ioc/O.cygwin-x86_64/dbLoadTemplate.d
Removing src/ioc/O.cygwin-x86_64/dbLoadTemplate_lex.c
Removing src/ioc/O.cygwin-x86_64/dbLock.d
Removing src/ioc/O.cygwin-x86_64/dbLock.obj
Removing src/ioc/O.cygwin-x86_64/dbNotify.d
Removing src/ioc/O.cygwin-x86_64/dbNotify.obj
Removing src/ioc/O.cygwin-x86_64/dbPutNotifyBlocker.d
Removing src/ioc/O.cygwin-x86_64/dbPvdLib.d
Removing src/ioc/O.cygwin-x86_64/dbScan.d
Removing src/ioc/O.cygwin-x86_64/dbScan.obj
Removing src/ioc/O.cygwin-x86_64/dbServer.d
Removing src/ioc/O.cygwin-x86_64/dbState.d
Removing src/ioc/O.cygwin-x86_64/dbStaticIocRegister.d
Removing src/ioc/O.cygwin-x86_64/dbStaticLib.d
Removing src/ioc/O.cygwin-x86_64/dbStaticRun.d
Removing src/ioc/O.cygwin-x86_64/dbSubscriptionIO.d
Removing src/ioc/O.cygwin-x86_64/dbSubscriptionIO.obj
Removing src/ioc/O.cygwin-x86_64/dbTest.d
Removing src/ioc/O.cygwin-x86_64/dbTest.obj
Removing src/ioc/O.cygwin-x86_64/dbtoolsIocRegister.d
Removing src/ioc/O.cygwin-x86_64/dbUnitTest.d
Removing src/ioc/O.cygwin-x86_64/dbYacc.c
Removing src/ioc/O.cygwin-x86_64/dbYacc.d
Removing src/ioc/O.cygwin-x86_64/db_access.d
Removing src/ioc/O.cygwin-x86_64/db_access.obj
Removing src/ioc/O.cygwin-x86_64/db_test.d
Removing src/ioc/O.cygwin-x86_64/db_test.obj
Removing src/ioc/O.cygwin-x86_64/dlload.d
Removing templates/
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1984)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1980)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1612)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1624)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:802)
at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : epics-base-3.16-cyg64 #236 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-3.16-win64 #235 APS Jenkins via Core-talk
Jenkins build is back to normal : epics-base-3.16-win64 #236 APS Jenkins via Core-talk
<2018>
2025
2026
<2018>
2025
2026
