2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #76
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 29 Nov 2018 00:05:43 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/76/display/redirect>
[...truncated 17.57 KB...]
stdout: Removing bin/windows-x64-static/acctst.exe
Removing bin/windows-x64-static/antelope.exe
Removing bin/windows-x64-static/ascheck.exe
Removing bin/windows-x64-static/assembleSnippets.pl
Removing bin/windows-x64-static/bldEnvData.pl
Removing bin/windows-x64-static/caConnTest.exe
Removing bin/windows-x64-static/caEventRate.exe
Removing bin/windows-x64-static/caget.exe
Removing bin/windows-x64-static/cainfo.exe
Removing bin/windows-x64-static/camonitor.exe
Removing bin/windows-x64-static/caput.exe
Removing bin/windows-x64-static/casw.exe
Removing bin/windows-x64-static/catime.exe
Removing bin/windows-x64-static/ca_test.exe
Removing bin/windows-x64-static/check_consist.exe
Removing bin/windows-x64-static/convertRelease.pl
Removing bin/windows-x64-static/cvsclean.pl
Removing bin/windows-x64-static/databaseModuleDirs.pm
Removing bin/windows-x64-static/dbdExpand.pl
Removing bin/windows-x64-static/dbdToHtml.pl
Removing bin/windows-x64-static/dbdToMenuH.pl
Removing bin/windows-x64-static/dbdToRecordtypeH.pl
Removing bin/windows-x64-static/dbExpand.pl
Removing bin/windows-x64-static/depclean.pl
Removing bin/windows-x64-static/dos2unix.pl
Removing bin/windows-x64-static/epicsMakeMemFs.pl
Removing bin/windows-x64-static/expandVars.pl
Removing bin/windows-x64-static/e_flex.exe
Removing bin/windows-x64-static/fullPathName.pl
Removing bin/windows-x64-static/genVersionHeader.pl
Removing bin/windows-x64-static/installEpics.pl
Removing bin/windows-x64-static/iocLogServer.exe
Removing bin/windows-x64-static/libcomModuleDirs.pm
Removing bin/windows-x64-static/makeBaseApp.pl
Removing bin/windows-x64-static/makeBaseExt.pl
Removing bin/windows-x64-static/makeBpt.exe
Removing bin/windows-x64-static/makeIncludeDbd.pl
Removing bin/windows-x64-static/makeMakefile.pl
Removing bin/windows-x64-static/makeTestfile.pl
Removing bin/windows-x64-static/mkmf.pl
Removing bin/windows-x64-static/msi.exe
Removing bin/windows-x64-static/munch.pl
Removing bin/windows-x64-static/p2p.exe
Removing bin/windows-x64-static/podRemove.pl
Removing bin/windows-x64-static/podToHtml.pl
Removing bin/windows-x64-static/pvcall.exe
Removing bin/windows-x64-static/pvget.exe
Removing bin/windows-x64-static/pvinfo.exe
Removing bin/windows-x64-static/pvlist.exe
Removing bin/windows-x64-static/pvmonitor.exe
Removing bin/windows-x64-static/pvput.exe
Removing bin/windows-x64-static/registerRecordDeviceDriver.pl
Removing bin/windows-x64-static/replaceVAR.pl
Removing bin/windows-x64-static/S99caRepeater
Removing bin/windows-x64-static/S99logServer
Removing bin/windows-x64-static/softIoc.exe
Removing bin/windows-x64-static/softIocPVA.exe
Removing bin/windows-x64-static/tap-to-junit-xml.pl
Removing bin/windows-x64-static/useManifestTool.pl
Removing cfg/
Removing configure/O.Common/
Removing configure/O.windows-x64-static/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing modules/RELEASE.windows-x64-static.local
Removing modules/ca/configure/O.Common/
Removing modules/ca/configure/O.windows-x64-static/
Removing modules/ca/src/client/O.Common/
Removing modules/ca/src/client/O.windows-x64-static/
Removing modules/ca/src/perl/O.Common/
Removing modules/ca/src/perl/O.windows-x64-static/
Removing modules/ca/src/template/O.Common/
Removing modules/ca/src/template/O.windows-x64-static/
Removing modules/ca/src/tools/O.Common/
Removing modules/ca/src/tools/O.windows-x64-static/
Removing modules/database/configure/O.Common/
Removing modules/database/configure/O.windows-x64-static/
Removing modules/database/src/ioc/O.Common/
Removing modules/database/src/ioc/O.windows-x64-static/
Removing modules/database/src/std/O.Common/
Removing modules/database/src/std/O.windows-x64-static/
Removing modules/database/src/template/O.Common/
Removing modules/database/src/template/O.windows-x64-static/
Removing modules/database/src/tools/O.Common/
Removing modules/database/src/tools/O.windows-x64-static/
Removing modules/database/test/ioc/db/O.Common/
Removing modules/database/test/ioc/db/O.windows-x64-static/
Removing modules/database/test/ioc/dbtemplate/O.Common/
Removing modules/database/test/ioc/dbtemplate/O.windows-x64-static/
Removing modules/database/test/std/filters/O.Common/
Removing modules/database/test/std/filters/O.windows-x64-static/
Removing modules/database/test/std/rec/O.Common/
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64-static/analogMonitorTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64-static/arrayOpTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/arrayOpTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/arrayOpTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/arrayOpTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/arrayOpTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/asTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/asTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/asTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/asTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/asTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/asTestIoc.dbd.d
Removing modules/database/test/std/rec/O.windows-x64-static/asTestIoc_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64-static/asTestIoc_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64-static/asTestIoc_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64-static/asTestLib.d
Removing modules/database/test/std/rec/O.windows-x64-static/asTestLib.obj
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest.d
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest.t
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64-static/asyncproctest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64-static/asyncSoftTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/asyncSoftTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/asyncSoftTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/asyncSoftTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/asyncSoftTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/compressTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/compressTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/compressTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/compressTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/compressTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/dbRecStdTest.lib
Removing modules/database/test/std/rec/O.windows-x64-static/linkInitTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/linkInitTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/linkInitTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/linkInitTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/linkInitTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/linkRetargetLinkTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/linkRetargetLinkTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/linkRetargetLinkTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/linkRetargetLinkTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/linkRetargetLinkTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/Makefile
Removing modules/database/test/std/rec/O.windows-x64-static/mbbioDirectTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/mbbioDirectTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/mbbioDirectTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/mbbioDirectTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/mbbioDirectTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/netget.t
Removing modules/database/test/std/rec/O.windows-x64-static/netget.tap
Removing modules/database/test/std/rec/O.windows-x64-static/recMiscTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/recMiscTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/recMiscTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/recMiscTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/recMiscTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/recTestIoc.dbd.d
Removing modules/database/test/std/rec/O.windows-x64-static/recTestIoc_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64-static/recTestIoc_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64-static/recTestIoc_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64-static/regressTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64-static/scanEventTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest.db.d
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64-static/simmTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64-static/softTest.d
Removing modules/database/test/std/rec/O.windows-x64-static/softTest.exe
Removing modules/database/test/std/rec/O.windows-x64-static/softTest.obj
Removing modules/database/test/std/rec/O.windows-x64-static/softTest.t
Removing modules/database/test/std/rec/O.windows-x64-static/softTest.tap
Removing modules/database/test/std/rec/O.windows-x64-static/testspec
Removing modules/database/test/tools/O.Common/
Removing modules/database/test/tools/O.windows-x64-static/
Removing modules/libcom/RTEMS/O.Common/
Removing modules/libcom/RTEMS/O.windows-x64-static/
Removing modules/libcom/configure/O.Common/
Removing modules/libcom/configure/O.windows-x64-static/
Removing modules/libcom/src/O.Common/
Removing modules/libcom/src/O.windows-x64-static/
Removing modules/libcom/test/O.Common/
Removing modules/libcom/test/O.windows-x64-static/
Removing modules/libcom/vxWorks/O.Common/
Removing modules/libcom/vxWorks/O.windows-x64-static/
Removing src/template/base/O.Common/
Removing src/template/base/O.windows-x64-static/
Removing src/template/ext/O.Common/
Removing src/template/ext/O.windows-x64-static/
Removing src/tools/O.Common/
Removing src/tools/O.windows-x64-static/
Removing templates/
Removing test/tools/O.Common/
Removing test/tools/O.windows-x64-static/
stderr: warning: failed to remove bin/windows-x64-static/caRepeater.exe: Invalid argument
warning: failed to remove modules/database/test/std/rec/O.windows-x64-static/: Permission denied
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1984)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1980)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1612)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1624)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:802)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:922)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:896)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:853)
	at hudson.remoting.UserRequest.perform(UserRequest.java:207)
	at hudson.remoting.UserRequest.perform(UserRequest.java:53)
	at hudson.remoting.Request$2.run(Request.java:358)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #77 APS Jenkins via Core-talk
Prev: Jenkins build is back to normal : EPICS-7 #172 Jenkins EPICS PSI via Core-talk
Next: Jenkins build is back to normal : epics-7.0-windows » STATIC,win32 #76 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build became unstable: epics-7.0 » linux64 #84 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #77 APS Jenkins via Core-talk
ANJ, 29 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
